#include <uhd/rfnoc/noc_block_base.hpp>
Classes | |
| struct | make_args_t |
Public Types | |
| enum class | forwarding_policy_t { ONE_TO_ONE , ONE_TO_FAN , ONE_TO_ALL_IN , ONE_TO_ALL_OUT , ONE_TO_ALL , DROP , USE_MAP } |
| Number of input ports. Note: This gets passed into this block from the. More... | |
| Number of output ports. Note: This gets passed outto this block from the. More... | |
| Return a unique identifier string for this node. In every RFNoC graph,. More... | |
Protected Member Functions | |
| Update number of input ports. More... | |
| Update number of output ports. More... | |
The primary interface to a NoC block in the FPGA
The block supports three types of data access:
The main difference between this class and its parent is the direct access to registers, and the NoC&block IDs.
| using uhd::rfnoc::noc_block_base::make_args_ptr = std::unique_ptr<make_args_t> |
Opaque pointer to the constructor arguments.
| using uhd::rfnoc::noc_block_base::sptr = std::shared_ptr<noc_block_base> |
A shared pointer to allow easy access to this class and for automatic memory management.
virtual |
protected |
protectedvirtual |
Safely de-initialize the block
This function is called by the framework when the RFNoC session is about to finish to allow blocks to safely perform actions to shut down a block. For example, if your block is producing samples, like a radio or signal generator, this is a good place to issue a "stop" command.
After this function is called, register access is no more possible. So make sure not to interact with regs() after this was called. Future access to regs() won't throw, but will print error messages and do nothing.
The rationale for having this separate from the destructor is because rfnoc_graph allows exporting references to blocks, and this function ensures that blocks are safely shut down when the rest of the device control goes away.
inline |
Return the arguments that were passed into this block from the framework
inline |
Returns the unique block ID for this block.
protected |
Get access to the motherboard controller for this block's motherboard
This will return a nullptr if this block doesn't have access to the motherboard. In order to gain access to the motherboard, the block needs to have requested access to the motherboard during the registration procedure. See also registry.hpp.
Even if this block requested access to the motherboard controller, there is no guarantee that UHD will honour that request. It is therefore important to verify that the returned pointer is valid.
| size_t uhd::rfnoc::noc_block_base::get_mtu | ( | const res_source_info & | edge | ) |
Return the current MTU on a given edge
The MTU is determined by the block itself (i.e., how big of a packet can this block handle on this edge), but also the neighboring block, and possibly the transport medium between the blocks. This value can thus be lower than what the block defines as MTU, but never higher.
| edge | The edge on which the MTU is queried. edge.type must be INPUT_EDGE or OUTPUT_EDGE! |
| uhd::value_error | if edge is not referring to a valid edge |
protected |
Return a reference to an MTU property
This can be used to make the MTU an input to a property resolver. For example, blocks that have an spp property, such as the radio, can now trigger a property resolver based on the MTU.
inline |
Return the NoC ID for this block.
inlinevirtual |
Implements uhd::rfnoc::node_t.
inlinevirtual |
| double uhd::rfnoc::noc_block_base::get_tick_rate | ( | ) | const |
Returns the tick rate of the current time base
Note there is only ever one time base (or tick rate) per block.
inline |
Return a reference to this block's subtree (non-const version)
inline |
Return a reference to this block's subtree.
inlinevirtual |
Unique ID for an RFNoC block is its block ID.
Reimplemented from uhd::rfnoc::node_t.
protected |
Update the MTU
This is another data point in the MTU discovery process. This means that the MTU cannot be increased using the method, only decreased.
protected |
Change the way MTUs are forwarded
The policy will have the following effect:
The default policy is DROP.
protected |
protected |
protected |
Update tick rate for this node and all the connected nodes
Careful: Calling this function will trigger a property propagation to any block this block is connected to.
