#include <uhd/stream.hpp>
typedef std::shared_ptr< rx_streamersptr
virtual ~rx_streamer (void)
virtual void issue_stream_cmd (const stream_cmd_t &stream_cmd)=0
◆ buffs_type
typedef std::shared_ptr<rx_streamer> uhd::rx_streamer::sptr
◆ ~rx_streamer()
virtual uhd::rx_streamer::~rx_streamer ( void  )
virtual
◆ get_max_num_samps()
◆ get_num_channels()
◆ issue_stream_cmd()
virtual void uhd::rx_streamer::issue_stream_cmd ( const stream_cmd_t stream_cmd)
◆ recv()
rx_metadata_t metadata,
const double  timeout = 0.1,
Receive handles fragmentation as follows: If the buffer has insufficient space to hold all samples that were received in a single packet over-the-wire, then the buffer will be completely filled and the implementation will hold a pointer into the remaining portion of the packet. Subsequent calls will load from the remainder of the packet, and will flag the metadata to show that this is a fragment. The next call to receive, after the remainder becomes exhausted, will perform an over-the-wire receive as usual. See the rx metadata fragment flags and offset fields for details.
Note on threading: recv() is not thread-safe, to avoid locking overhead. The application calling recv() is responsible for making sure that not more than one thread can call recv() on the same streamer at the same time. If there are multiple streamers, receiving from different sources, then those may be called from different threads simultaneously.
