12namespace uhd {
namespace rfnoc {
   19static const std::string PROP_KEY_MAGNITUDE    =
"magnitude";
   20static const std::string PROP_KEY_DIRECTION    =
"direction";
   21static const std::string PROP_KEY_LENGTH       =
"length";
   22static const std::string PROP_KEY_FFT_SCALING  =
"fft_scaling";
   23static const std::string PROP_KEY_SHIFT_CONFIG =
"shift_config";
   44    static const uint32_t REG_RESET_ADDR;
   45    static const uint32_t REG_LENGTH_LOG2_ADDR;
   46    static const uint32_t REG_MAGNITUDE_OUT_ADDR;
   47    static const uint32_t REG_DIRECTION_ADDR;
   48    static const uint32_t REG_SCALING_ADDR;
   49    static const uint32_t REG_SHIFT_CONFIG_ADDR;
  122    virtual
void set_scaling(const uint16_t scaling) = 0;
  130    virtual uint16_t get_scaling() const = 0;
  140    virtual
void set_length(const
size_t length) = 0;
  148    virtual
size_t get_length() const = 0;
Definition: fft_block_control.hpp:40
Definition: noc_block_base.hpp:42
Definition: config.h:67
fft_magnitude
Definition: fft_block_control.hpp:16
fft_shift
Definition: fft_block_control.hpp:14
fft_direction
Definition: fft_block_control.hpp:15
UHD_INLINE size_t shift(const soft_reg_field_t field)
Definition: soft_register.hpp:81
Definition: build_info.hpp:12
#define RFNOC_DECLARE_BLOCK(CLASS_NAME)
Definition: noc_block_base.hpp:21
