13namespace uhd {
namespace rfnoc {
Definition: noc_block_base.hpp:42
Definition: null_block_control.hpp:16
virtual void issue_stream_cmd(const uhd::stream_cmd_t &stream_cmd)=0
virtual void reset_counters()=0
virtual void set_throttle_cycles(const uint32_t cycs)=0
static const uint32_t REG_SRC_PKT_CNT_LO
Definition: null_block_control.hpp:33
static const uint32_t REG_SRC_THROTTLE_CYC
Definition: null_block_control.hpp:26
virtual uint32_t get_throttle_cycles()=0
static const uint32_t REG_SRC_PKT_CNT_HI
Definition: null_block_control.hpp:34
static const uint32_t REG_SRC_LINE_CNT_HI
Definition: null_block_control.hpp:32
virtual uint64_t get_count(const port_type_t port_type, const count_type_t count_type)=0
static const uint32_t REG_SRC_LINE_CNT_LO
Definition: null_block_control.hpp:31
static const uint32_t REG_SNK_LINE_CNT_HI
Definition: null_block_control.hpp:28
virtual uint32_t get_bytes_per_packet()=0
virtual void set_bytes_per_packet(const uint32_t bpp)=0
static const uint32_t REG_CTRL_STATUS
Definition: null_block_control.hpp:23
count_type_t
Definition: null_block_control.hpp:21
virtual uint32_t get_lines_per_packet()=0
static const uint32_t REG_LOOP_LINE_CNT_HI
Definition: null_block_control.hpp:36
static const uint32_t REG_SRC_LINES_PER_PKT
Definition: null_block_control.hpp:24
port_type_t
Definition: null_block_control.hpp:20
static const uint32_t REG_LOOP_LINE_CNT_LO
Definition: null_block_control.hpp:35
static const uint32_t REG_LOOP_PKT_CNT_HI
Definition: null_block_control.hpp:38
static const uint32_t REG_SNK_PKT_CNT_HI
Definition: null_block_control.hpp:30
static const uint32_t REG_SRC_BYTES_PER_PKT
Definition: null_block_control.hpp:25
static const uint32_t REG_SNK_PKT_CNT_LO
Definition: null_block_control.hpp:29
static const uint32_t REG_LOOP_PKT_CNT_LO
Definition: null_block_control.hpp:37
static const uint32_t REG_SNK_LINE_CNT_LO
Definition: null_block_control.hpp:27
Definition: config.h:67
Definition: build_info.hpp:12
#define RFNOC_DECLARE_BLOCK(CLASS_NAME)
Definition: noc_block_base.hpp:21
Definition: stream_cmd.hpp:36
