|   | meta_range_t (void) |
|   | A default constructor for an empty meta-range.  More...
| template<typename InputIterator >  |
|   | meta_range_t (InputIterator first, InputIterator last) |
|   | meta_range_t (double start, double stop, double step=0) |
| double  | start (void) const |
|   | Get the overall start value for this meta-range.  More...
| double  | stop (void) const |
|   | Get the overall stop value for this meta-range.  More...
| double  | step (void) const |
|   | Get the overall step value for this meta-range.  More...
| double  | clip (double value, bool clip_step=false) const |
| const std::string  | to_pp_string (void) const |
|   | Convert this meta-range to a printable string.  More...
A meta-range object holds a list of individual ranges.
◆ meta_range_t() [1/3]
          | uhd::meta_range_t::meta_range_t  |
          void  |
◆ meta_range_t() [2/3]
          InputIterator  |
          first,  |
          InputIterator  |
          last  |
inline   |
Input iterator constructor: Makes boost::assign::list_of work.
- Parameters
    | first | the begin iterator  |
    | last | the end iterator  |
◆ meta_range_t() [3/3]
          double  |
          start,  |
          double  |
          stop,  |
          double  |
          step = 0  |
A convenience constructor for a single range. A step size of zero implies infinite precision.
- Parameters
    | start | the minimum value for this range  |
    | stop | the maximum value for this range  |
    | step | the step size for this range  |
◆ clip()
          | double uhd::meta_range_t::clip  |
          double  |
          value,  |
          bool  |
          clip_step = false  |
           |  const |
Clip the target value to a possible range value.
- Parameters
    | value | the value to clip to this range  |
    | clip_step | if true, clip to steps as well  |
- Returns
 - a value that is in one of the ranges
◆ start()
          | double uhd::meta_range_t::start  |
          void  |
           const |
◆ step()
          | double uhd::meta_range_t::step  |
          void  |
           const |
◆ stop()
          | double uhd::meta_range_t::stop  |
          void  |
           const |
◆ to_pp_string()
          | const std::string uhd::meta_range_t::to_pp_string  |
          void  |
           const |
