uhd::math::fp_compare::fp_compare_delta< float_t > Class Template Reference
#include <uhd/utils/math.hpp>
UHD_INLINE fp_compare_delta (float_t value)
UHD_INLINE fp_compare_delta (float_t value, float_t delta)
UHD_INLINE fp_compare_delta (const fp_compare_delta< float_t > &copy)
UHD_INLINE ~fp_compare_delta ()
UHD_INLINE void operator= (const fp_compare_delta &copy)
UHD_INLINE fp_compare_delta (float value)
UHD_INLINE fp_compare_delta (double value)
Public Attributes
float_t _value
float_t _delta
template<typename float_t>
class uhd::math::fp_compare::fp_compare_delta< float_t >
Class for floating-point comparisons using a delta.
At construction, you can specify the delta to use for the comparisons. This class, combined with the operators under it, allow for delta-comparisons of floats. An example is:
// Compare floats 'x' and 'y'. bool x_equals_y = (fp_compare_delta<float>(x) == y);
// Compare doubles 'x' and 'y'. bool x_equals_y = (fp_compare_delta<double>(x) == y);
◆ fp_compare_delta() [1/5]
template<typename float_t >
UHD_INLINE uhd::math::fp_compare::fp_compare_delta< float_t >::fp_compare_delta ( float_t  value)
◆ fp_compare_delta() [2/5]
UHD_INLINE uhd::math::fp_compare::fp_compare_delta< float_t >::fp_compare_delta ( float_t  value,
float_t  delta
◆ fp_compare_delta() [3/5]
UHD_INLINE uhd::math::fp_compare::fp_compare_delta< float_t >::fp_compare_delta ( const fp_compare_delta< float_t > &  copy)
◆ ~fp_compare_delta()
UHD_INLINE uhd::math::fp_compare::fp_compare_delta< float_t >::~fp_compare_delta
◆ fp_compare_delta() [4/5]
UHD_INLINE uhd::math::fp_compare::fp_compare_delta< float >::fp_compare_delta ( float  value)
◆ fp_compare_delta() [5/5]
UHD_INLINE uhd::math::fp_compare::fp_compare_delta< double >::fp_compare_delta ( double  value)
◆ operator=()
UHD_INLINE void uhd::math::fp_compare::fp_compare_delta< float_t >::operator= ( const fp_compare_delta< float_t > &  copy)
◆ _delta
float_t uhd::math::fp_compare::fp_compare_delta< float_t >::_delta
◆ _value
float_t uhd::math::fp_compare::fp_compare_delta< float_t >::_value
