uhd::range_t Class Reference
 range_t (double value=0)
 range_t (double start, double stop, double step=0)
double start (void) const
 Get the start value for this range. More...
double stop (void) const
 Get the stop value for this range. More...
double step (void) const
 Get the step value for this range. More...
const std::string to_pp_string (void) const
 Convert this range to a printable string. More...
bool operator== (const range_t &other) const
 Equality operator. More...
bool operator!= (const range_t &other) const
 Inequality operator. More...
A range object describes a set of discrete values of the form: y = start + step*n, where n is an integer between 0 and (stop - start)/step
◆ range_t() [1/2]
uhd::range_t::range_t ( double  value = 0)
Create a range from a single value. The step size will be taken as zero.
valuethe only possible value in this range
◆ range_t() [2/2]
uhd::range_t::range_t ( double  start,
double  stop,
double  step = 0
Create a range from a full set of values. A step size of zero implies infinite precision.
startthe minimum value for this range
stopthe maximum value for this range
stepthe step size for this range
◆ operator!=()
bool uhd::range_t::operator!= ( const range_t &  other) const
◆ operator==()
bool uhd::range_t::operator== ( const range_t &  other) const
Equality operator.
◆ start()
double uhd::range_t::start ( void  ) const
◆ step()
double uhd::range_t::step ( void  ) const
◆ stop()
double uhd::range_t::stop ( void  ) const
◆ to_pp_string()
const std::string uhd::range_t::to_pp_string ( void  ) const
