uhd::rfnoc::chdr::strs_payload Class Reference
 strs_payload ()=default
 strs_payload (const strs_payload &rhs)=default
 strs_payload (strs_payload &&rhs)=default
strs_payload & operator= (const strs_payload &rhs)=default
void populate_header (chdr_header &header) const
 Populate the header for this type of packet. More...
size_t serialize (uint64_t *buff, size_t max_size_bytes, const std::function< uint64_t(uint64_t)> &conv_byte_order) const
 Serialize the payload to a uint64_t buffer. More...
size_t serialize (uint64_t *buff, size_t max_size_bytes) const
 Serialize the payload to a uint64_t buffer (no conversion function) More...
void deserialize (const uint64_t *buff, size_t num_elems, const std::function< uint64_t(uint64_t)> &conv_byte_order)
 Deserialize the payload from a uint64_t buffer. More...
void deserialize (const uint64_t *buff, size_t num_elems)
 Deserialize the payload from a uint64_t buffer (no conversion function) More...
size_t get_length () const
 Get the serialized size of this payload in 64 bit words. More...
bool operator== (const strs_payload &rhs) const
 Comparison operator (==) More...
bool operator!= (const strs_payload &rhs) const
 Comparison operator (!=) More...
const std::string to_string () const
 Return a string representation of this object. More...
Public Attributes
uint16_t src_epid = 0
 The source EPID for the stream (16 bits) More...
strs_status_t status = STRS_OKAY
 The status of the stream (4 bits) More...
uint64_t capacity_bytes = 0
 Buffer capacity in bytes (40 bits) More...
uint32_t capacity_pkts = 0
 Buffer capacity in packets (24 bits) More...
uint64_t xfer_count_bytes = 0
 Transfer count in bytes (64 bits) More...
uint64_t xfer_count_pkts = 0
 Transfer count in packets (40 bits) More...
uint16_t buff_info = 0
 Buffer info (16 bits) More...
uint64_t status_info = 0
 Extended status info (48 bits) More...
◆ strs_payload() [1/3]
uhd::rfnoc::chdr::strs_payload::strs_payload ( )
default
◆ strs_payload() [2/3]
uhd::rfnoc::chdr::strs_payload::strs_payload ( const strs_payload &  rhs)
default
◆ strs_payload() [3/3]
uhd::rfnoc::chdr::strs_payload::strs_payload ( strs_payload &&  rhs)
default
◆ deserialize() [1/2]
void uhd::rfnoc::chdr::strs_payload::deserialize ( const uint64_t *  buff,
size_t  num_elems
◆ deserialize() [2/2]
size_t  num_elems,
const std::function< uint64_t(uint64_t)> &  conv_byte_order
◆ get_length()
size_t uhd::rfnoc::chdr::strs_payload::get_length ( ) const
◆ operator!=()
bool uhd::rfnoc::chdr::strs_payload::operator!= ( const strs_payload &  rhs) const
◆ operator=()
strs_payload & uhd::rfnoc::chdr::strs_payload::operator= ( const strs_payload &  rhs)
default
◆ operator==()
bool uhd::rfnoc::chdr::strs_payload::operator== ( const strs_payload &  rhs) const
◆ populate_header()
void uhd::rfnoc::chdr::strs_payload::populate_header ( chdr_header &  header) const
◆ serialize() [1/2]
size_t uhd::rfnoc::chdr::strs_payload::serialize ( uint64_t *  buff,
) const
◆ serialize() [2/2]
) const
◆ to_string()
const std::string uhd::rfnoc::chdr::strs_payload::to_string ( ) const
◆ buff_info
uint16_t uhd::rfnoc::chdr::strs_payload::buff_info = 0
◆ capacity_bytes
uint64_t uhd::rfnoc::chdr::strs_payload::capacity_bytes = 0
◆ capacity_pkts
uint32_t uhd::rfnoc::chdr::strs_payload::capacity_pkts = 0
◆ src_epid
uint16_t uhd::rfnoc::chdr::strs_payload::src_epid = 0
◆ status
strs_status_t uhd::rfnoc::chdr::strs_payload::status = STRS_OKAY
◆ status_info
uint64_t uhd::rfnoc::chdr::strs_payload::status_info = 0
◆ xfer_count_bytes
uint64_t uhd::rfnoc::chdr::strs_payload::xfer_count_bytes = 0
◆ xfer_count_pkts
uint64_t uhd::rfnoc::chdr::strs_payload::xfer_count_pkts = 0
