uhd::rfnoc::property_t< data_t > Class Template Reference
#include <uhd/rfnoc/property.hpp>
Inheritance diagram for uhd::rfnoc::property_t< data_t >:
uhd::rfnoc::property_base_t
using value_type = data_t
 We want to be good C++ citizens. More...
- Public Types inherited from uhd::rfnoc::property_base_t
enum  access_t { NONE , RO = 0x1 , RW = 0x3 , RWLOCKED = 0x5 }
 property_t (const std::string &id, data_t &&value, const res_source_info &source_info)
 property_t (const std::string &id, const data_t &value, const res_source_info &source_info)
 property_t (const std::string &id, const res_source_info &source_info)
 property_t (const property_t< data_t > &prop)=default
bool is_dirty () const override
 Returns the dirty state of this property. More...
bool is_valid () const override
 Query this property's valid flag. More...
bool equal (property_base_t *rhs) const override
 Return true if rhs has the same type and value. More...
std::unique_ptr< property_base_t > clone (res_source_info new_src_info) override
 Create a copy of this property. More...
void set_from_str (const std::string &new_val_str) override
void set (const data_t &value)
 Returns the source info for the property. More...
void force_dirty () override
const data_t & get () const
 Get the value of this property. More...
 operator const data_t & () const
bool operator== (const data_t &rhs)
property_t< data_t > & operator= (const data_t &value)
- Public Member Functions inherited from uhd::rfnoc::property_base_t
 property_base_t (const std::string &id, const res_source_info &source_info)
virtual ~property_base_t ()
const std::string & get_id () const
 Gets the ID (name) of this property. More...
const res_source_info & get_src_info () const
 Return the source info for this property. More...
virtual bool is_dirty () const =0
 Query this property's dirty flag. More...
virtual bool is_valid () const =0
bool read_access_granted () const
 Returns true if this property can be read. More...
bool write_access_granted () const
 Returns true if this property can be written to. More...
access_t get_access_mode () const
 Return the current access mode. More...
virtual bool equal (property_base_t *rhs) const =0
virtual std::unique_ptr< property_base_t > clone (res_source_info)
virtual void force_dirty ()=0
virtual void set_from_str (const std::string &new_val_str)=0
template<typename data_t>
class uhd::rfnoc::property_t< data_t >
An encapsulation class for a block property.
◆ value_type
template<typename data_t >
using uhd::rfnoc::property_t< data_t >::value_type = data_t
◆ property_t() [1/4]
uhd::rfnoc::property_t< data_t >::property_t ( const std::string &  id,
data_t &&  value,
const res_source_info &  source_info
◆ property_t() [2/4]
const data_t &  value,
◆ property_t() [3/4]
◆ property_t() [4/4]
uhd::rfnoc::property_t< data_t >::property_t ( const property_t< data_t > &  prop)
default
◆ clone()
std::unique_ptr< property_base_t > uhd::rfnoc::property_t< data_t >::clone ( res_source_info  )
inlineoverridevirtual
Reimplemented from uhd::rfnoc::property_base_t.
◆ equal()
bool uhd::rfnoc::property_t< data_t >::equal ( property_base_t *  rhs) const
Implements uhd::rfnoc::property_base_t.
◆ force_dirty()
void uhd::rfnoc::property_t< data_t >::force_dirty ( )
const data_t & uhd::rfnoc::property_t< data_t >::get ( void  ) const
◆ is_dirty()
bool uhd::rfnoc::property_t< data_t >::is_dirty ( ) const
◆ is_valid()
bool uhd::rfnoc::property_t< data_t >::is_valid ( ) const
◆ operator const data_t &()
uhd::rfnoc::property_t< data_t >::operator const data_t & ( ) const
◆ operator=()
property_t< data_t > & uhd::rfnoc::property_t< data_t >::operator= ( const data_t &  value)
◆ operator==()
bool uhd::rfnoc::property_t< data_t >::operator== ( const data_t &  rhs)
void uhd::rfnoc::property_t< data_t >::set ( const data_t &  value)
Set the value of this property
◆ set_from_str()
void uhd::rfnoc::property_t< data_t >::set_from_str ( const std::string &  new_val_str)
Set this property's value using a string
This requires the underlying property type to be convertible from a string.
Exceptions
uhd::runtime_errorif the underlying type has no conversion from a string
