uhd::rfnoc::siggen_block_control Member List
This is the complete list of members for uhd::rfnoc::siggen_block_control, including all inherited members.
get_amplitude(const size_t port) const =0uhd::rfnoc::siggen_block_controlpure virtual
get_constant(const size_t port) const =0uhd::rfnoc::siggen_block_controlpure virtual
get_enable(const size_t port) const =0uhd::rfnoc::siggen_block_controlpure virtual
get_mb_controller()uhd::rfnoc::noc_block_baseprotected
get_samples_per_packet(const size_t port) const =0uhd::rfnoc::siggen_block_controlpure virtual
get_sine_phase_increment(const size_t port) const =0uhd::rfnoc::siggen_block_controlpure virtual
get_waveform(const size_t port) const =0uhd::rfnoc::siggen_block_controlpure virtual
node_t()uhd::rfnoc::node_t
REG_BLOCK_SIZEuhd::rfnoc::siggen_block_controlstatic
REG_CARTESIAN_OFFSETuhd::rfnoc::siggen_block_controlstatic
REG_CONSTANT_OFFSETuhd::rfnoc::siggen_block_controlstatic
REG_ENABLE_OFFSETuhd::rfnoc::siggen_block_controlstatic
REG_GAIN_OFFSETuhd::rfnoc::siggen_block_controlstatic
REG_PHASE_INC_OFFSETuhd::rfnoc::siggen_block_controlstatic
REG_SPP_OFFSETuhd::rfnoc::siggen_block_controlstatic
REG_WAVEFORM_OFFSETuhd::rfnoc::siggen_block_controlstatic
RFNOC_DECLARE_BLOCK(siggen_block_control)uhd::rfnoc::siggen_block_control
set_amplitude(const double amplitude, const size_t port)=0uhd::rfnoc::siggen_block_controlpure virtual
set_constant(const std::complex< double > constant, const size_t port)=0uhd::rfnoc::siggen_block_controlpure virtual
set_enable(const bool enable, const size_t port)=0uhd::rfnoc::siggen_block_controlpure virtual
set_samples_per_packet(const size_t spp, const size_t port)=0uhd::rfnoc::siggen_block_controlpure virtual
set_sine_frequency(const double frequency, const double sample_rate, const size_t port)uhd::rfnoc::siggen_block_controlinline
set_sine_phase_increment(const double phase_inc, const size_t port)=0uhd::rfnoc::siggen_block_controlpure virtual
set_waveform(const siggen_waveform type, const size_t port)=0uhd::rfnoc::siggen_block_controlpure virtual
