uhd::rfnoc::noc_block_base Class Reference
#include <uhd/rfnoc/noc_block_base.hpp>
Inheritance diagram for uhd::rfnoc::noc_block_base:
uhd::rfnoc::node_t uhd::rfnoc::register_iface_holder uhd::rfnoc::addsub_block_control uhd::rfnoc::block_control uhd::rfnoc::ddc_block_control uhd::rfnoc::dmafifo_block_control uhd::rfnoc::duc_block_control uhd::rfnoc::fft_block_control uhd::rfnoc::fir_filter_block_control uhd::rfnoc::fosphor_block_control uhd::rfnoc::keep_one_in_n_block_control uhd::rfnoc::logpwr_block_control uhd::rfnoc::moving_average_block_control uhd::rfnoc::null_block_control uhd::rfnoc::radio_control uhd::rfnoc::replay_block_control uhd::rfnoc::siggen_block_control uhd::rfnoc::split_stream_block_control uhd::rfnoc::switchboard_block_control uhd::rfnoc::vector_iir_block_control uhd::rfnoc::window_block_control
Classes
struct  make_args_t
register_iface & regs ()
The primary interface to a NoC block in the FPGA
The block supports three types of data access:
  • Low-level register access
  • High-level property access
  • Action execution
The main difference between this class and its parent is the direct access to registers, and the NoC&block IDs.
◆ make_args_ptr
Opaque pointer to the constructor arguments.
A shared pointer to allow easy access to this class and for automatic memory management.
◆ ~noc_block_base()
uhd::rfnoc::noc_block_base::~noc_block_base ( )
override
◆ noc_block_base()
uhd::rfnoc::noc_block_base::noc_block_base ( make_args_ptr  make_args)
◆ deinit()
virtual void uhd::rfnoc::noc_block_base::deinit ( )
protectedvirtual
Safely de-initialize the block
This function is called by the framework when the RFNoC session is about to finish to allow blocks to safely perform actions to shut down a block. For example, if your block is producing samples, like a radio or signal generator, this is a good place to issue a "stop" command.
After this function is called, register access is no more possible. So make sure not to interact with regs() after this was called. Future access to regs() won't throw, but will print error messages and do nothing.
The rationale for having this separate from the destructor is because rfnoc_graph allows exporting references to blocks, and this function ensures that blocks are safely shut down when the rest of the device control goes away.
◆ get_block_args()
uhd::device_addr_t uhd::rfnoc::noc_block_base::get_block_args ( ) const
Return the arguments that were passed into this block from the framework
◆ get_block_id()
const block_id_t & uhd::rfnoc::noc_block_base::get_block_id ( ) const
Returns the unique block ID for this block.
block_id The block ID of this block (e.g. "0/FFT#1")
◆ get_mb_controller()
std::shared_ptr< mb_controller > uhd::rfnoc::noc_block_base::get_mb_controller ( )
Get access to the motherboard controller for this block's motherboard
This will return a nullptr if this block doesn't have access to the motherboard. In order to gain access to the motherboard, the block needs to have requested access to the motherboard during the registration procedure. See also registry.hpp.
Even if this block requested access to the motherboard controller, there is no guarantee that UHD will honour that request. It is therefore important to verify that the returned pointer is valid.
◆ get_mtu()
size_t uhd::rfnoc::noc_block_base::get_mtu ( const res_source_info &  edge)
Return the current MTU on a given edge
The MTU is determined by the block itself (i.e., how big of a packet can this block handle on this edge), but also the neighboring block, and possibly the transport medium between the blocks. This value can thus be lower than what the block defines as MTU, but never higher.
edgeThe edge on which the MTU is queried. edge.type must be INPUT_EDGE or OUTPUT_EDGE!
the MTU as determined by the overall graph on this edge
Exceptions
uhd::value_errorif edge is not referring to a valid edge
◆ get_mtu_prop_ref()
property_base_t * uhd::rfnoc::noc_block_base::get_mtu_prop_ref ( const res_source_info &  edge)
Return a reference to an MTU property
This can be used to make the MTU an input to a property resolver. For example, blocks that have an spp property, such as the radio, can now trigger a property resolver based on the MTU.
◆ get_noc_id()
noc_id_t uhd::rfnoc::noc_block_base::get_noc_id ( ) const
Return the NoC ID for this block.
noc_id The 32-bit NoC ID of this block
◆ get_num_input_ports()
size_t uhd::rfnoc::noc_block_base::get_num_input_ports ( ) const
inlineoverridevirtual
Number of input ports. Note: This gets passed into this block from the.
Implements uhd::rfnoc::node_t.
◆ get_num_output_ports()
size_t uhd::rfnoc::noc_block_base::get_num_output_ports ( ) const
Number of output ports. Note: This gets passed outto this block from the.
◆ get_tick_rate()
double uhd::rfnoc::noc_block_base::get_tick_rate ( ) const
Returns the tick rate of the current time base
Note there is only ever one time base (or tick rate) per block.
◆ get_tree() [1/2]
uhd::property_tree::sptr & uhd::rfnoc::noc_block_base::get_tree ( )
Return a reference to this block's subtree (non-const version)
◆ get_tree() [2/2]
uhd::property_tree::sptr & uhd::rfnoc::noc_block_base::get_tree ( ) const
Return a reference to this block's subtree.
◆ get_unique_id()
std::string uhd::rfnoc::noc_block_base::get_unique_id ( ) const
Unique ID for an RFNoC block is its block ID.
Reimplemented from uhd::rfnoc::node_t.
◆ set_mtu()
void uhd::rfnoc::noc_block_base::set_mtu ( const res_source_info &  edge,
const size_t  new_mtu
Update the MTU
This is another data point in the MTU discovery process. This means that the MTU cannot be increased using the method, only decreased.
◆ set_mtu_forwarding_policy()
void uhd::rfnoc::noc_block_base::set_mtu_forwarding_policy ( const forwarding_policy_t  policy)
Change the way MTUs are forwarded
The policy will have the following effect:
  • DROP: This means that the MTU of one port has no bearing on the MTU of another port. This is usually a valid choice if the FPGA is repacking data, for example, a block could be consuming continous streams of data, and producing small packets of a different type.
  • ONE_TO_ONE: This means the MTU is passed through from input to output and vice versa. This is typically a good choice if packets are being passed through without modifying their size. The DDC/DUC blocks will choose this policy, because the want to relay MTU information to the radio.
  • ONE_TO_ALL: This means the MTU is being set to the same value on all ports.
  • ONE_TO_FAN: This means the MTU is forwarded from any input port to all opposite side ports. This is an appropriate policy for the split-stream block.
The default policy is DROP.
Note: The MTU forwarding policy can only be set ONCE per instance of a noc_block_base. If an RFNoC block subclassing noc_block_base wants to modify the MTU forwarding policy, it would typically call this function in its constructor. Once set, however, the MTU forwarding policy cannot be changed. This represents a change in behaviour from UHD 4.0. Violations of this restriction will result in a uhd::runtime_error being thrown.
◆ set_num_input_ports()
void uhd::rfnoc::noc_block_base::set_num_input_ports ( const size_t  num_ports)
Update number of input ports.
◆ set_num_output_ports()
void uhd::rfnoc::noc_block_base::set_num_output_ports ( const size_t  num_ports)
Update number of output ports.
◆ set_tick_rate()
void uhd::rfnoc::noc_block_base::set_tick_rate ( const double  tick_rate)
Update tick rate for this node and all the connected nodes
Careful: Calling this function will trigger a property propagation to any block this block is connected to.
