uhd::time_spec_t Class Reference
#include <uhd/types/time_spec.hpp>
Inheritance diagram for uhd::time_spec_t:
 time_spec_t (double secs=0)
 time_spec_t (int64_t full_secs, double frac_secs=0)
 time_spec_t (int64_t full_secs, long tick_count, double tick_rate)
long get_tick_count (double tick_rate) const
long long to_ticks (const double tick_rate) const
double get_real_secs (void) const
int64_t get_full_secs (void) const
double get_frac_secs (void) const
time_spec_t & operator+= (const time_spec_t &)
 Implement addable interface. More...
time_spec_t & operator+= (double &)
time_spec_t & operator-= (const time_spec_t &)
 Implement subtractable interface. More...
time_spec_t & operator-= (double &)
static time_spec_t from_ticks (long long ticks, double tick_rate)
static constexpr double ASAP = 0.0
A time_spec_t holds a seconds and a fractional seconds time value. Depending upon usage, the time_spec_t can represent absolute times, relative times, or time differences (between absolute times).
The time_spec_t provides clock-domain independent time storage, but can convert fractional seconds to/from clock-domain specific units.
The fractional seconds are stored as double precision floating point. This gives the fractional seconds enough precision to unambiguously specify a clock-tick/sample-count up to rates of several petahertz.
◆ time_spec_t() [1/3]
uhd::time_spec_t::time_spec_t ( double  secs = 0)
Create a time_spec_t from a real-valued seconds count.
secsthe real-valued seconds count (default = 0)
◆ time_spec_t() [2/3]
uhd::time_spec_t::time_spec_t ( int64_t  full_secs,
double  frac_secs = 0
Create a time_spec_t from whole and fractional seconds.
full_secsthe whole/integer seconds count
frac_secsthe fractional seconds count (default = 0)
◆ time_spec_t() [3/3]
long  tick_count,
double  tick_rate
Create a time_spec_t from whole seconds and fractional ticks. Translation from clock-domain specific units.
tick_countthe fractional seconds tick count
tick_ratethe number of ticks per second
◆ from_ticks()
static time_spec_t uhd::time_spec_t::from_ticks ( long long  ticks,
double  tick_rate
Create a time_spec_t from a 64-bit tick count. Translation from clock-domain specific units.
ticksan integer count of ticks
◆ get_frac_secs()
UHD_INLINE double uhd::time_spec_t::get_frac_secs ( void  ) const
Get the fractional part of the time in seconds.
◆ get_full_secs()
UHD_INLINE int64_t uhd::time_spec_t::get_full_secs ( void  ) const
Get the whole/integer part of the time in seconds.
◆ get_real_secs()
double uhd::time_spec_t::get_real_secs ( void  ) const
Get the time as a real-valued seconds count. Note: If this time_spec_t represents an absolute time, the precision of the fractional seconds may be lost.
◆ get_tick_count()
long uhd::time_spec_t::get_tick_count ( double  tick_rate) const
Convert the fractional seconds to clock ticks. Translation into clock-domain specific units.
◆ operator+=() [1/2]
time_spec_t & uhd::time_spec_t::operator+= ( const time_spec_t &  )
◆ operator+=() [2/2]
time_spec_t & uhd::time_spec_t::operator+= ( double &  )
◆ operator-=() [1/2]
time_spec_t & uhd::time_spec_t::operator-= ( const time_spec_t &  )
◆ operator-=() [2/2]
time_spec_t & uhd::time_spec_t::operator-= ( double &  )
◆ to_ticks()
long long uhd::time_spec_t::to_ticks ( const double  tick_rate) const
Convert the time spec into a 64-bit tick count. Translation into clock-domain specific units.
an integer number of ticks
◆ ASAP
constexpr double uhd::time_spec_t::ASAP = 0.0
staticconstexpr
