uhd::transport::udp_zero_copy Class Referenceabstract
#include <uhd/transport/udp_zero_copy.hpp>
Inheritance diagram for uhd::transport::udp_zero_copy:
uhd::transport::zero_copy_if
Classes
struct  buff_params
typedef std::shared_ptr< udp_zero_copy > sptr
- Public Types inherited from uhd::transport::zero_copy_if
typedef std::shared_ptr< zero_copy_if > sptr
virtual uint16_t get_local_port (void) const =0
virtual std::string get_local_addr (void) const =0
- Public Member Functions inherited from uhd::transport::zero_copy_if
virtual ~zero_copy_if ()
static sptr make (const std::string &addr, const std::string &port, const zero_copy_xport_params &default_buff_args, udp_zero_copy::buff_params &buff_params_out, const device_addr_t &hints=device_addr_t())
A zero copy udp transport provides an efficient way to handle data. by avoiding the extra copy when recv() or send() is called on the socket. Rather, the zero copy transport gives the caller memory references. The caller informs the transport when it is finished with the reference.
On Linux systems, the zero copy transport can use a kernel packet ring. If no platform specific solution is available, make returns a boost asio implementation that wraps the functionality around a standard send/recv calls.
◆ get_local_addr()
virtual std::string uhd::transport::udp_zero_copy::get_local_addr ( void  ) const
Return the local IP address of the UDP connection as a dotted string.
IP address as a string or empty string if the IP address could not be identified.
◆ get_local_port()
virtual uint16_t uhd::transport::udp_zero_copy::get_local_port ( void  ) const
Return the local port of the UDP connection
Port is in host byte order. No funny business here.
Port number or 0 if port number couldn't be identified.
◆ make()
static sptr uhd::transport::udp_zero_copy::make ( const std::string &  addr,
const std::string &  port,
const zero_copy_xport_params &  default_buff_args,
udp_zero_copy::buff_params &  buff_params_out,
const device_addr_t &  hints = device_addr_t()
Make a new zero copy udp transport: This transport is for sending and receiving between this host and a single endpoint. The primary usage for this transport will be data transactions. The underlying implementation is fast and platform specific.
default_buff_argsDefault values for frame sizes and num frames
[out]buff_params_outReturns the actual buffer sizes
hintsoptional parameters to pass to the underlying transport
