sensors.h
1//
2// Copyright 2015 Ettus Research LLC
3// Copyright 2018 Ettus Research, a National Instruments Company
4//
5// SPDX-License-Identifier: GPL-3.0-or-later
6//
7
8#pragma once
9
10#include <uhd/config.h>
11#include <uhd/error.h>
12
13#ifdef __cplusplus
14#include <uhd/types/sensors.hpp>
15#include <string>
16
17struct uhd_sensor_value_t {
18 // No default constructor, so we need a pointer
19 uhd::sensor_value_t* sensor_value_cpp;
20 std::string last_error;
21};
22extern "C" {
23#else
24struct uhd_sensor_value_t;
25#endif
26
28
33typedef struct uhd_sensor_value_t* uhd_sensor_value_handle;
34
36typedef enum {
42
44
55);
56
58
68 const char* name,
69 bool value,
70 const char* utrue,
71 const char* ufalse
72);
73
75
85 const char* name,
86 int value,
87 const char* unit,
88 const char* formatter
89);
90
92
102 const char* name,
103 double value,
104 const char* unit,
105 const char* formatter
106);
107
109
118 const char* name,
119 const char* value,
120 const char* unit
121);
122
124
130);
131
135 bool *value_out
136);
137
141 int *value_out
142);
143
147 double *value_out
148);
149
151
161 char* name_out,
162 size_t strbuffer_len
163);
164
166
176 char* value_out,
177 size_t strbuffer_len
178);
179
181
191 char* unit_out,
192 size_t strbuffer_len
193);
194
197 uhd_sensor_value_data_type_t *data_type_out
198);
199
201
211 char* pp_string_out,
212 size_t strbuffer_len
213);
214
216
226 char* error_out,
227 size_t strbuffer_len
228);
229
230#ifdef __cplusplus
231}
232#endif
Definition: config.h:70
uhd_error
UHD error codes.
Definition: error.h:20
UHD_API uhd_error uhd_sensor_value_data_type(uhd_sensor_value_handle h, uhd_sensor_value_data_type_t *data_type_out)
UHD_API uhd_error uhd_sensor_value_last_error(uhd_sensor_value_handle h, char *error_out, size_t strbuffer_len)
Get the last error logged by the sensor handle.
UHD_API uhd_error uhd_sensor_value_make_from_realnum(uhd_sensor_value_handle *h, const char *name, double value, const char *unit, const char *formatter)
Make a UHD sensor from a real number.
UHD_API uhd_error uhd_sensor_value_to_pp_string(uhd_sensor_value_handle h, char *pp_string_out, size_t strbuffer_len)
Get a pretty-print representation of the given sensor.
UHD_API uhd_error uhd_sensor_value_value(uhd_sensor_value_handle h, char *value_out, size_t strbuffer_len)
Get the sensor's value.
UHD_API uhd_error uhd_sensor_value_make_from_bool(uhd_sensor_value_handle *h, const char *name, bool value, const char *utrue, const char *ufalse)
Make a UHD sensor from a boolean.
UHD_API uhd_error uhd_sensor_value_make_from_int(uhd_sensor_value_handle *h, const char *name, int value, const char *unit, const char *formatter)
Make a UHD sensor from an integer.
UHD_API uhd_error uhd_sensor_value_make_from_string(uhd_sensor_value_handle *h, const char *name, const char *value, const char *unit)
Make a UHD sensor from a string.
UHD_API uhd_error uhd_sensor_value_to_int(uhd_sensor_value_handle h, int *value_out)
Get the sensor's value as an integer.
UHD_API uhd_error uhd_sensor_value_to_realnum(uhd_sensor_value_handle h, double *value_out)
Get the sensor's value as a real number.
Sensor value types.
Definition: sensors.h:36
@ UHD_SENSOR_VALUE_BOOLEAN
Definition: sensors.h:37
@ UHD_SENSOR_VALUE_STRING
Definition: sensors.h:40
@ UHD_SENSOR_VALUE_REALNUM
Definition: sensors.h:39
@ UHD_SENSOR_VALUE_INTEGER
Definition: sensors.h:38
UHD_API uhd_error uhd_sensor_value_free(uhd_sensor_value_handle *h)
Free the given sensor handle.
UHD_API uhd_error uhd_sensor_value_make(uhd_sensor_value_handle *h)
Make an empty UHD sensor value.
UHD_API uhd_error uhd_sensor_value_name(uhd_sensor_value_handle h, char *name_out, size_t strbuffer_len)
Get the sensor's name.
UHD_API uhd_error uhd_sensor_value_to_bool(uhd_sensor_value_handle h, bool *value_out)
Get the sensor's value as a boolean.
Definition: sensors.h:33
UHD_API uhd_error uhd_sensor_value_unit(uhd_sensor_value_handle h, char *unit_out, size_t strbuffer_len)
Get the sensor's unit.
Definition: sensors.hpp:29
