uhd::sensor_value_t Struct Reference
enum  data_type_t { BOOLEAN = 'b' , INTEGER = 'i' , REALNUM = 'r' , STRING = 's' }
 Enumeration of possible data types in a sensor. More...
typedef std::map< std::string, std::string > sensor_map_t
 sensor_value_t (const std::string &name, bool value, const std::string &utrue, const std::string &ufalse)
 sensor_value_t (const std::string &name, signed value, const std::string &unit, const std::string &formatter="%d")
 sensor_value_t (const std::string &name, double value, const std::string &unit, const std::string &formatter="%f")
 sensor_value_t (const std::string &name, const std::string &value, const std::string &unit)
 sensor_value_t (const std::map< std::string, std::string > &sensor_dict)
 sensor_value_t (const sensor_value_t &source)
bool to_bool (void) const
 convert the sensor value to a boolean More...
signed to_int (void) const
 convert the sensor value to an integer More...
double to_real (void) const
 convert the sensor value to real number More...
sensor_map_t to_map (void) const
 convert the sensor value to sensor_map_t More...
 Convert this sensor value into a printable string. More...
sensor_value_t & operator= (const sensor_value_t &value)
 Assignment operator for sensor value. More...
Public Attributes
std::string name
 The name of the sensor value. More...
std::string value
std::string unit
data_type_t type
 The data type of the value. More...
A sensor value stores a sensor reading as a string with unit and data type. The sensor value class can be used in the following way:
sensor_value_t ref_lock_sensor("Reference", my_lock, "unlocked", "locked"); std::cout << ref_lock_sensor.to_pp_string() << std::endl; //prints Reference: locked
sensor_value_t temp_sensor("Temperature", my_temp, "C"); std::cout << temp_sensor.to_pp_string() << std::endl; //prints Temperature: 38.5 C
◆ sensor_map_t
typedef std::map<std::string, std::string> uhd::sensor_value_t::sensor_map_t
◆ data_type_t
Enumerator
BOOLEAN
INTEGER
REALNUM
STRING
◆ sensor_value_t() [1/6]
uhd::sensor_value_t::sensor_value_t ( const std::string &  name,
bool  value,
const std::string &  utrue,
const std::string &  ufalse
Create a sensor value from a boolean.
namethe name of the sensor
valuethe value true or false
utruethe unit string when value is true
ufalsethe unit string when value is false
◆ sensor_value_t() [2/6]
signed  value,
const std::string &  unit,
const std::string &  formatter = "%d"
Create a sensor value from an integer.
valuethe signed integer value
unitthe associated unit type
formatterthe formatter string
◆ sensor_value_t() [3/6]
double  value,
const std::string &  formatter = "%f"
Create a sensor value from a real number.
valuethe real number value
◆ sensor_value_t() [4/6]
const std::string &  value,
Create a sensor value from a string.
◆ sensor_value_t() [5/6]
uhd::sensor_value_t::sensor_value_t ( const std::map< std::string, std::string > &  sensor_dict)
Create a sensor value from a map.
The map must have the following keys: name, type, value, and unit.
type must one of the following strings: BOOLEAN, INTEGER, REALNUM, or STRING (see data_type_t).
◆ sensor_value_t() [6/6]
uhd::sensor_value_t::sensor_value_t ( const sensor_value_t &  source)
Create a sensor value from another sensor value.
sourcethe source sensor value to copy
◆ operator=()
sensor_value_t & uhd::sensor_value_t::operator= ( const sensor_value_t &  value)
◆ to_bool()
bool uhd::sensor_value_t::to_bool ( void  ) const
◆ to_int()
signed uhd::sensor_value_t::to_int ( void  ) const
◆ to_map()
sensor_map_t uhd::sensor_value_t::to_map ( void  ) const
◆ to_pp_string()
std::string uhd::sensor_value_t::to_pp_string ( void  ) const
◆ to_real()
double uhd::sensor_value_t::to_real ( void  ) const
◆ name
std::string uhd::sensor_value_t::name
◆ type
data_type_t uhd::sensor_value_t::type
◆ unit
std::string uhd::sensor_value_t::unit
The sensor value's unit type. For boolean types, this will be the one of the two units depending upon the value of the boolean true or false.
◆ value
std::string uhd::sensor_value_t::value
The sensor value as a string. For integer and real number types, this will be the output of the formatter. For boolean types, the value will be the string literal "true" or "false".
