uhd::rfnoc::graph_edge_t Struct Reference
#include <uhd/rfnoc/graph_edge.hpp>
enum  edge_t { STATIC , DYNAMIC , RX_STREAM , TX_STREAM }
 graph_edge_t ()=default
 graph_edge_t (const size_t src_port_, const size_t dst_port_, const edge_t edge_, const bool ppa)
bool operator== (const graph_edge_t &rhs) const
std::string to_string () const
 Return a string representation of the connection. More...
Public Attributes
std::string src_blockid
 The ID of the source block for this edge. More...
size_t src_port = 0
 The port number of the source block for this edge. More...
std::string dst_blockid
 The ID of the destination block for this edge. More...
size_t dst_port = 0
 The port number of the destination block for this edge. More...
edge_t edge = DYNAMIC
 The type of edge. More...
bool property_propagation_active = true
 When true, the framework will use this edge for property propagation. More...
A container that holds information about a graph edge
Note: The source and destination IDs are strings, not block IDs (uhd::rfnoc::block_id_t). This is because the graph can contain edges that are not between RFNoC blocks (e.g., to a streamer), and we need to be able to generically express node IDs.
◆ edge_t
Enumerator
STATIC
A static connection between two blocks in the FPGA.
DYNAMIC
A user (dynamic) connection between two blocks in the FPGA.
RX_STREAM
A connection from an FPGA block to a software RX streamer.
TX_STREAM
A connection from a software TX streamer and an FPGA block.
◆ graph_edge_t() [1/2]
uhd::rfnoc::graph_edge_t::graph_edge_t ( )
default
◆ graph_edge_t() [2/2]
uhd::rfnoc::graph_edge_t::graph_edge_t ( const size_t  src_port_,
const edge_t  edge_,
const bool  ppa
◆ operator==()
bool uhd::rfnoc::graph_edge_t::operator== ( const graph_edge_t &  rhs) const
◆ to_string()
std::string uhd::rfnoc::graph_edge_t::to_string ( void  ) const
◆ dst_blockid
std::string uhd::rfnoc::graph_edge_t::dst_blockid
◆ dst_port
size_t uhd::rfnoc::graph_edge_t::dst_port = 0
◆ edge
edge_t uhd::rfnoc::graph_edge_t::edge = DYNAMIC
The type of edge.
◆ property_propagation_active
bool uhd::rfnoc::graph_edge_t::property_propagation_active = true
◆ src_blockid
std::string uhd::rfnoc::graph_edge_t::src_blockid
◆ src_port
size_t uhd::rfnoc::graph_edge_t::src_port = 0
