uhd::rfnoc::tx_event_action_info Struct Reference
#include <uhd/rfnoc/actions.hpp>
Inheritance diagram for uhd::rfnoc::tx_event_action_info:
uhd::rfnoc::action_info
using sptr = std::shared_ptr< tx_event_action_info >
- Public Types inherited from uhd::rfnoc::action_info
using sptr = std::shared_ptr< action_info >
static sptr make (uhd::async_metadata_t::event_code_t event_code, const boost::optional< uint64_t > &tsf)
 Factory function. More...
- Static Public Member Functions inherited from uhd::rfnoc::action_info
static sptr make (const std::string &key="", const uhd::device_addr_t &args=uhd::device_addr_t(""))
Public Attributes
 The event code that describes the event. More...
bool has_tsf
 Has time specification? More...
uint64_t tsf
 When the async event occurred. More...
- Public Attributes inherited from uhd::rfnoc::action_info
const size_t id
 A unique counter for this action. More...
std::string key
 A string identifier for this action. More...
std::vector< uint8_t > payload
 An arbitrary payload. It is up to consumers and producers to. More...
uhd::device_addr_t args
 A dictionary of key-value pairs. May be used as desired. More...
 tx_event_action_info (uhd::async_metadata_t::event_code_t event_code, const boost::optional< uint64_t > &tsf)
- Protected Member Functions inherited from uhd::rfnoc::action_info
 action_info (const std::string &key, const uhd::device_addr_t &args=uhd::device_addr_t(""))
- Public Member Functions inherited from uhd::rfnoc::action_info
virtual ~action_info ()
◆ tx_event_action_info()
uhd::rfnoc::tx_event_action_info::tx_event_action_info ( uhd::async_metadata_t::event_code_t  event_code,
const boost::optional< uint64_t > &  tsf
◆ make()
static sptr uhd::rfnoc::tx_event_action_info::make ( uhd::async_metadata_t::event_code_t  event_code,
Factory function.
◆ event_code
uhd::async_metadata_t::event_code_t uhd::rfnoc::tx_event_action_info::event_code
◆ has_tsf
bool uhd::rfnoc::tx_event_action_info::has_tsf
◆ tsf
uint64_t uhd::rfnoc::tx_event_action_info::tsf
