◆ strc_payload() [1/3]
          | uhd::rfnoc::chdr::strc_payload::strc_payload  |
default   |
◆ strc_payload() [2/3]
          const strc_payload &  |
          rhs | ) |
default   |
◆ strc_payload() [3/3]
          strc_payload &&  |
          rhs | ) |
default   |
◆ deserialize() [1/2]
          | void uhd::rfnoc::chdr::strc_payload::deserialize  |
          const uint64_t *  |
          buff,  |
          size_t  |
          num_elems  |
inline   |
Deserialize the payload from a uint64_t buffer (no conversion function)
◆ deserialize() [2/2]
          const uint64_t *  |
          buff,  |
          size_t  |
          num_elems,  |
          const std::function< uint64_t(uint64_t)> &  |
          conv_byte_order  |
Deserialize the payload from a uint64_t buffer.
◆ get_length()
          | size_t uhd::rfnoc::chdr::strc_payload::get_length  |
           const |
Get the serialized size of this payload in 64 bit words.
◆ operator!=()
          | bool uhd::rfnoc::chdr::strc_payload::operator!=  |
          rhs | ) |
           const |
inline   |
◆ operator=()
◆ operator==()
          | bool uhd::rfnoc::chdr::strc_payload::operator==  |
          rhs | ) |
           const |
◆ populate_header()
          | void uhd::rfnoc::chdr::strc_payload::populate_header  |
          chdr_header &  |
          header | ) |
           const |
Populate the header for this type of packet.
◆ serialize() [1/2]
          | size_t uhd::rfnoc::chdr::strc_payload::serialize  |
          uint64_t *  |
          buff,  |
          size_t  |
          max_size_bytes  |
           |  const |
inline   |
Serialize the payload to a uint64_t buffer (no conversion function)
◆ serialize() [2/2]
          uint64_t *  |
          buff,  |
          size_t  |
          max_size_bytes,  |
          conv_byte_order  |
           |  const |
Serialize the payload to a uint64_t buffer.
◆ to_string()
          | const std::string uhd::rfnoc::chdr::strc_payload::to_string  |
           const |
Return a string representation of this object.
◆ MAX_PACKET_SIZE
          | constexpr size_t uhd::rfnoc::chdr::strc_payload::MAX_PACKET_SIZE = 128 |
staticconstexpr   |
Worst-case size of a strc packet (including header)
◆ num_bytes
          | uint64_t uhd::rfnoc::chdr::strc_payload::num_bytes = 0 |
Number of bytes to use for operation (64 bits)
◆ num_pkts
          | uint64_t uhd::rfnoc::chdr::strc_payload::num_pkts = 0 |
Number of packets to use for operation (40 bits)
◆ op_code
Operation code for the command (4 bits)
◆ op_data
          | uint8_t uhd::rfnoc::chdr::strc_payload::op_data = 0 |
Data associated with the operation (4 bits)
◆ src_epid
          | uint16_t uhd::rfnoc::chdr::strc_payload::src_epid = 0 |
The source EPID for the stream (16 bits)
