USRP Hardware Driver and USRP Manual Version: 4.1.0.1
uhd::rfnoc::fft_block_control Member List
This is the complete list of members for uhd::rfnoc::fft_block_control, including all inherited members.
get_direction() const =0uhd::rfnoc::fft_block_controlpure virtual
get_length() const =0uhd::rfnoc::fft_block_controlpure virtual
get_magnitude() const =0uhd::rfnoc::fft_block_controlpure virtual
get_mb_controller()uhd::rfnoc::noc_block_baseprotected
get_scaling() const =0uhd::rfnoc::fft_block_controlpure virtual
get_shift_config() const =0uhd::rfnoc::fft_block_controlpure virtual
node_t()uhd::rfnoc::node_t
REG_DIRECTION_ADDRuhd::rfnoc::fft_block_controlstatic
REG_LENGTH_LOG2_ADDRuhd::rfnoc::fft_block_controlstatic
REG_MAGNITUDE_OUT_ADDRuhd::rfnoc::fft_block_controlstatic
REG_RESET_ADDRuhd::rfnoc::fft_block_controlstatic
REG_SCALING_ADDRuhd::rfnoc::fft_block_controlstatic
REG_SHIFT_CONFIG_ADDRuhd::rfnoc::fft_block_controlstatic
set_direction(const fft_direction direction)=0uhd::rfnoc::fft_block_controlpure virtual
set_length(const size_t length)=0uhd::rfnoc::fft_block_controlpure virtual
set_magnitude(const fft_magnitude magnitude)=0uhd::rfnoc::fft_block_controlpure virtual
set_scaling(const uint16_t scaling)=0uhd::rfnoc::fft_block_controlpure virtual
set_shift_config(const fft_shift shift)=0uhd::rfnoc::fft_block_controlpure virtual
