#include <uhd/rfnoc/noc_block_base.hpp>
Classes | |
struct | make_args_t |
Public Types | |
using | sptr = std::shared_ptr< noc_block_base > |
using | make_args_ptr = std::unique_ptr< make_args_t > |
Opaque pointer to the constructor arguments. More... | |
enum class | forwarding_policy_t { ONE_TO_ONE , ONE_TO_FAN , ONE_TO_ALL_IN , ONE_TO_ALL_OUT , ONE_TO_ALL , DROP , USE_MAP } |
Types of property/action forwarding for those not defined by the block itself. More... | |
using | resolver_fn_t = std::function< void(void)> |
using | resolve_callback_t = std::function< void(void)> |
using | action_handler_t = std::function< void(const res_source_info &, action_info::sptr)> |
using | forwarding_map_t = std::unordered_map< res_source_info, std::vector< res_source_info > > |
~noc_block_base () override | |
std::string | get_unique_id () const override |
Unique ID for an RFNoC block is its block ID. More... | |
size_t | get_num_input_ports () const override |
Number of input ports. Note: This gets passed into this block from the. More... | |
size_t | get_num_output_ports () const override |
Number of output ports. Note: This gets passed outto this block from the. More... | |
noc_id_t | get_noc_id () const |
const block_id_t & | get_block_id () const |
double | get_tick_rate () const |
size_t | get_mtu (const res_source_info &edge) |
uhd::device_addr_t | get_block_args () const |
uhd::property_tree::sptr & | get_tree () const |
Return a reference to this block's subtree. More... | |
uhd::property_tree::sptr & | get_tree () |
Return a reference to this block's subtree (non-const version) More... | |
node_t () | |
virtual | ~node_t () |
virtual std::string | get_unique_id () const |
Return a unique identifier string for this node. In every RFNoC graph,. More... | |
virtual size_t | get_num_input_ports () const =0 |
virtual size_t | get_num_output_ports () const =0 |
std::vector< std::string > | get_property_ids () const |
template<typename prop_data_t > | |
void | set_property (const std::string &id, const prop_data_t &val, const size_t instance=0) |
void | set_properties (const uhd::device_addr_t &props, const size_t instance=0) |
const prop_data_t & | get_property (const std::string &id, const size_t instance=0) |
virtual void | set_command_time (uhd::time_spec_t time, const size_t instance) |
virtual uhd::time_spec_t | get_command_time (const size_t instance) const |
virtual void | clear_command_time (const size_t instance) |
register_iface_holder (register_iface::sptr reg) | |
virtual | ~register_iface_holder ()=default |
register_iface & | regs () |
Protected Member Functions | |
noc_block_base (make_args_ptr make_args) | |
void | set_num_input_ports (const size_t num_ports) |
Update number of input ports. More... | |
void | set_num_output_ports (const size_t num_ports) |
Update number of output ports. More... | |
void | set_tick_rate (const double tick_rate) |
void | set_mtu_forwarding_policy (const forwarding_policy_t policy) |
void | set_mtu (const res_source_info &edge, const size_t new_mtu) |
property_base_t * | get_mtu_prop_ref (const res_source_info &edge) |
std::shared_ptr< mb_controller > | get_mb_controller () |
virtual void | deinit () |
void | register_property (property_base_t *prop, resolve_callback_t &&clean_callback=nullptr) |
void | add_property_resolver (prop_ptrs_t &&inputs, prop_ptrs_t &&outputs, resolver_fn_t &&resolver_fn) |
void | set_prop_forwarding_policy (forwarding_policy_t policy, const std::string &prop_id="") |
void | set_prop_forwarding_map (const forwarding_map_t &map) |
void | set_property (const std::string &id, const prop_data_t &val, const res_source_info &src_info) |
const prop_data_t & | get_property (const std::string &id, const res_source_info &src_info) |
void | register_action_handler (const std::string &id, action_handler_t &&handler) |
void | set_action_forwarding_policy (forwarding_policy_t policy, const std::string &action_key="") |
void | set_action_forwarding_map (const forwarding_map_t &map) |
void | post_action (const res_source_info &edge_info, action_info::sptr action) |
virtual bool | check_topology (const std::vector< size_t > &connected_inputs, const std::vector< size_t > &connected_outputs) |
virtual void | shutdown () |
void | update_reg_iface (register_iface::sptr new_iface=nullptr) |
static const size_t | ANY_PORT = size_t(~0) |
using | prop_ptrs_t = std::unordered_set< property_base_t * > |
static dirtifier_t | ALWAYS_DIRTY |
A dirtifyer object, useful for properties that always need updating. More... | |
The primary interface to a NoC block in the FPGA
The block supports three types of data access:
The main difference between this class and its parent is the direct access to registers, and the NoC&block IDs.
using uhd::rfnoc::noc_block_base::make_args_ptr = std::unique_ptr<make_args_t> |
using uhd::rfnoc::noc_block_base::sptr = std::shared_ptr<noc_block_base> |
A shared pointer to allow easy access to this class and for automatic memory management.
override |
protected |
protectedvirtual |
Safely de-initialize the block
This function is called by the framework when the RFNoC session is about to finish to allow blocks to safely perform actions to shut down a block. For example, if your block is producing samples, like a radio or signal generator, this is a good place to issue a "stop" command.
After this function is called, register access is no more possible. So make sure not to interact with regs() after this was called. Future access to regs() won't throw, but will print error messages and do nothing.
The rationale for having this separate from the destructor is because rfnoc_graph allows exporting references to blocks, and this function ensures that blocks are safely shut down when the rest of the device control goes away.
inline |
Return the arguments that were passed into this block from the framework
inline |
Returns the unique block ID for this block.
protected |
Get access to the motherboard controller for this block's motherboard
This will return a nullptr if this block doesn't have access to the motherboard. In order to gain access to the motherboard, the block needs to have requested access to the motherboard during the registration procedure. See also registry.hpp.
Even if this block requested access to the motherboard controller, there is no guarantee that UHD will honour that request. It is therefore important to verify that the returned pointer is valid.
size_t uhd::rfnoc::noc_block_base::get_mtu | ( | const res_source_info & | edge | ) |
Return the current MTU on a given edge
The MTU is determined by the block itself (i.e., how big of a packet can this block handle on this edge), but also the neighboring block, and possibly the transport medium between the blocks. This value can thus be lower than what the block defines as MTU, but never higher.
edge | The edge on which the MTU is queried. edge.type must be INPUT_EDGE or OUTPUT_EDGE! |
uhd::value_error | if edge is not referring to a valid edge |
protected |
Return a reference to an MTU property
This can be used to make the MTU an input to a property resolver. For example, blocks that have an spp property, such as the radio, can now trigger a property resolver based on the MTU.
inline |
Return the NoC ID for this block.
inlineoverridevirtual |
Implements uhd::rfnoc::node_t.
double uhd::rfnoc::noc_block_base::get_tick_rate | ( | ) | const |
Returns the tick rate of the current time base
Note there is only ever one time base (or tick rate) per block.
inline |
inline |
Reimplemented from uhd::rfnoc::node_t.
protected |
Update the MTU
This is another data point in the MTU discovery process. This means that the MTU cannot be increased using the method, only decreased.
protected |
Change the way MTUs are forwarded
The policy will have the following effect:
The default policy is DROP.
Note: The MTU forwarding policy can only be set ONCE per instance of a noc_block_base. If an RFNoC block subclassing noc_block_base wants to modify the MTU forwarding policy, it would typically call this function in its constructor. Once set, however, the MTU forwarding policy cannot be changed. This represents a change in behaviour from UHD 4.0. Violations of this restriction will result in a uhd::runtime_error being thrown.
protected |
protected |
protected |
Update tick rate for this node and all the connected nodes
Careful: Calling this function will trigger a property propagation to any block this block is connected to.
