| multichan_register_iface (register_iface_holder ®_iface_holder, const uint32_t block_base_addr, const size_t block_size) |
| ~multichan_register_iface ()=default |
void | poke32 (uint32_t addr, uint32_t data, const size_t instance=0, uhd::time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false) |
void | poke64 (uint32_t addr, uint64_t data, const size_t instance=0, time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false) |
void | multi_poke32 (const std::vector< uint32_t > addrs, const std::vector< uint32_t > data, const size_t instance=0, uhd::time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false) |
void | block_poke32 (uint32_t first_addr, const std::vector< uint32_t > data, const size_t instance=0, uhd::time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false) |
uint32_t | peek32 (uint32_t addr, const size_t instance=0, time_spec_t time=uhd::time_spec_t::ASAP) |
uint64_t | peek64 (uint32_t addr, const size_t instance=0, time_spec_t time=uhd::time_spec_t::ASAP) |
std::vector< uint32_t > | block_peek32 (uint32_t first_addr, size_t length, const size_t instance=0, time_spec_t time=uhd::time_spec_t::ASAP) |
void | poll32 (uint32_t addr, uint32_t data, uint32_t mask, time_spec_t timeout, const size_t instance=0, time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false) |
A software interface to access low-level registers in a NoC block, which automatically handles address translation between multiple consecutive instances of the block. (For instance, accessing registers from multiple channels in hardware).
This interface supports the following:
- Writing and reading registers
- Hardware timed delays (for time sequencing operations)
std::vector< uint32_t > uhd::rfnoc::multichan_register_iface::block_peek32 |
uint32_t |
first_addr, |
size_t |
length, |
const size_t |
instance = 0 , |
time_spec_t |
time = uhd::time_spec_t::ASAP |
inline |
Read multiple 32-bit consecutive registers implemented in the NoC block.
- Parameters
first_addr | The byte address of the first register to read from (truncated to 20 bits). |
length | The number of 32-bit values to read |
instance | The index of the block of registers to which the reads apply. |
time | The time at which the transaction should be executed. |
- Returns
- data New value of this register.
Example: If first_addr
is set to 0, and length is 8, then this function will return a vector of length 8, with the content of registers at addresses 0, 4, 8, 12, 16, 20, 24, and 28 respectively.
Note: There is no guarantee that under the hood, the implementation won't separate the reads.
- Exceptions
void uhd::rfnoc::multichan_register_iface::block_poke32 |
uint32_t |
first_addr, |
const std::vector< uint32_t > |
data, |
const size_t |
instance = 0 , |
uhd::time_spec_t |
time = uhd::time_spec_t::ASAP , |
bool |
ack = false |
inline |
Write multiple consecutive 32-bit registers implemented in the NoC block.
This function will only allow writes to adjacent registers, in increasing order. If addr is set to 0, and the length of data is 8, then this method triggers eight writes, in order, to addresses 0, 4, 8, 12, 16, 20, 24, 28. For arbitrary addresses, cf. multi_poke32().
Note: There is no guarantee that under the hood, the implementation won't separate the writes.
- Parameters
first_addr | The byte addresses of the first register to write |
data | New values of these registers |
instance | The index of the block of registers to which the writes apply. |
time | The time at which the first transaction should be executed. |
ack | Should transaction completion be acknowledged? |
- Exceptions
op_failed | if an ACK is requested and the transaction fails |
op_timeout | if an ACK is requested and no response is received |
op_seqerr | if an ACK is requested and a sequence error occurs |
op_timeerr | if an ACK is requested and a time error occurs (late command) |
Poll a 32-bit register until its value for all bits in mask match data&mask
This will insert a command into the command queue to wait until a register is of a certain value. This can be used, e.g., to poll for a lock pin before executing the next command. It is related to sleep(), except it has a condition to wait on, rather than an unconditional stall duration. The timeout is hardware-timed. If the register does not attain the requested value within the requested duration, ${something bad happens}.
Example: Assume readback register 16 is a status register, and bit 0 indicates a lock is in place (i.e., we want it to be 1) and bit 1 is an error flag (i.e., we want it to be 0). The previous command can modify the state of the block, so we give it 1ms to settle. In that case, the call would be thus:
iface->poll32(16, 0x1, 0x3, 1e-3);
- Parameters
addr | The byte address of the register to read from (truncated to 20 bits). |
data | The values that the register must have |
mask | The bitmask that is applied before checking the readback value |
timeout | The max duration that the register is allowed to take before reaching its new state. |
instance | The index of the block of registers to which the poll applies. |
time | When the poll should be executed |
ack | Should transaction completion be acknowledged? This is typically only necessary if the software needs a condition to be fulfilled before continueing, or during debugging. |
- Exceptions
