USRP Hardware Driver and USRP Manual Version: 4.1.0.1
uhd::rfnoc::register_iface Class Referenceabstract
#include <uhd/rfnoc/register_iface.hpp>
Inheritance diagram for uhd::rfnoc::register_iface:
uhd::rfnoc::mock_reg_iface_t
using sptr = std::shared_ptr< register_iface >
using async_msg_validator_t = std::function< bool(uint32_t addr, const std::vector< uint32_t > &data)>
using async_msg_callback_t = std::function< void(uint32_t addr, const std::vector< uint32_t > &data, boost::optional< uint64_t >)>
virtual ~register_iface ()=default
virtual void poke32 (uint32_t addr, uint32_t data, uhd::time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)=0
void poke64 (uint32_t addr, uint64_t data, time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)
virtual void multi_poke32 (const std::vector< uint32_t > addrs, const std::vector< uint32_t > data, uhd::time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)=0
virtual void block_poke32 (uint32_t first_addr, const std::vector< uint32_t > data, uhd::time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)=0
virtual uint32_t peek32 (uint32_t addr, time_spec_t time=uhd::time_spec_t::ASAP)=0
uint64_t peek64 (uint32_t addr, time_spec_t time=uhd::time_spec_t::ASAP)
virtual std::vector< uint32_t > block_peek32 (uint32_t first_addr, size_t length, time_spec_t time=uhd::time_spec_t::ASAP)=0
virtual void poll32 (uint32_t addr, uint32_t data, uint32_t mask, time_spec_t timeout, time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)=0
virtual void sleep (time_spec_t duration, bool ack=false)=0
virtual void register_async_msg_validator (async_msg_validator_t callback_f)=0
virtual void register_async_msg_handler (async_msg_callback_t callback_f)=0
virtual void set_policy (const std::string &name, const uhd::device_addr_t &args)=0
virtual uint16_t get_src_epid () const =0
virtual uint16_t get_port_num () const =0
A software interface to access low-level registers in a NoC block.
This interface supports the following:
  • Writing and reading registers
  • Hardware timed delays (for time sequencing operations)
  • Asynchronous messages (where a block requests a "register write" in software)
This class has no public factory function or constructor.
◆ async_msg_callback_t
using uhd::rfnoc::register_iface::async_msg_callback_t = std::function<void( uint32_t addr, const std::vector<uint32_t>& data, boost::optional<uint64_t>)>
Callback function for acting upon an asynchronous message.
When a block in the FPGA sends an asynchronous message to the software, and it has been validated, the async message callback function is called. An async message can be modelled as a simple register write (key-value pair with addr/data) that is initiated by the FPGA.
When this message is called, the async message was previously verified by calling the async message validator callback.
◆ async_msg_validator_t
using uhd::rfnoc::register_iface::async_msg_validator_t = std::function<bool(uint32_t addr, const std::vector<uint32_t>& data)>
Callback function for validating an asynchronous message.
When a block in the FPGA sends an asynchronous message to the software, the async message validator function is called. An async message can be modelled as a simple register write (key-value pair with addr/data) that is initiated by the FPGA. If this message returns true, the message is considered valid.
◆ ~register_iface()
virtual uhd::rfnoc::register_iface::~register_iface ( )
virtualdefault
◆ block_peek32()
virtual std::vector< uint32_t > uhd::rfnoc::register_iface::block_peek32 ( uint32_t  first_addr,
size_t  length,
time_spec_t  time = uhd::time_spec_t::ASAP
Read multiple 32-bit consecutive registers implemented in the NoC block.
first_addrThe byte address of the first register to read from (truncated to 20 bits).
lengthThe number of 32-bit values to read
timeThe time at which the transaction should be executed.
data New value of this register.
Example: If first_addr is set to 0, and length is 8, then this function will return a vector of length 8, with the content of registers at addresses 0, 4, 8, 12, 16, 20, 24, and 28 respectively.
Note: There is no guarantee that under the hood, the implementation won't separate the reads.
Exceptions
op_failedif the transaction fails
op_timeoutif no response is received
op_seqerrif a sequence error occurs
Implemented in uhd::rfnoc::mock_reg_iface_t.
◆ block_poke32()
virtual void uhd::rfnoc::register_iface::block_poke32 ( uint32_t  first_addr,
uhd::time_spec_t  time = uhd::time_spec_t::ASAP,
bool  ack = false
Write multiple consecutive 32-bit registers implemented in the NoC block.
This function will only allow writes to adjacent registers, in increasing order. If addr is set to 0, and the length of data is 8, then this method triggers eight writes, in order, to addresses 0, 4, 8, 12, 16, 20, 24, 28. For arbitrary addresses, cf. multi_poke32().
Note: There is no guarantee that under the hood, the implementation won't separate the writes.
first_addrThe byte addresses of the first register to write
dataNew values of these registers
timeThe time at which the first transaction should be executed.
ackShould transaction completion be acknowledged?
Exceptions
op_failedif an ACK is requested and the transaction fails
op_timeoutif an ACK is requested and no response is received
op_seqerrif an ACK is requested and a sequence error occurs
op_timeerrif an ACK is requested and a time error occurs (late command)
◆ get_port_num()
virtual uint16_t uhd::rfnoc::register_iface::get_port_num ( ) const
Get the port number of the software counterpart of this register interface. This information is useful to send async messages to the host.
The 10-bit port number
◆ get_src_epid()
virtual uint16_t uhd::rfnoc::register_iface::get_src_epid ( ) const
Get the endpoint ID of the software counterpart of this register interface. This information is useful to send async messages to the host.
The 16-bit endpoint ID
◆ multi_poke32()
virtual void uhd::rfnoc::register_iface::multi_poke32 ( const std::vector< uint32_t >  addrs,
bool  ack = false
Write multiple 32-bit registers implemented in the NoC block.
This method should be called when multiple writes need to happen that are at non-consecutive addresses. For consecutive writes, cf. block_poke32().
addrsThe byte addresses of the registers to write to (each truncated to 20 bits).
dataNew values of these registers. The lengths of data and addr must match.
Exceptions
uhd::value_errorif lengths of data and addr don't match
◆ peek32()
virtual uint32_t uhd::rfnoc::register_iface::peek32 ( uint32_t  addr,
Read a 32-bit register implemented in the NoC block.
addrThe byte address of the register to read from (truncated to 20 bits).
Exceptions
◆ peek64()
uint64_t uhd::rfnoc::register_iface::peek64 ( uint32_t  addr,
Read two consecutive 32-bit registers implemented in the NoC block and return them as one 64-bit value.
Note: This is a convenience call, because all register peeks are 32-bits. This will concatenate two peeks in a block peek, and then return the combined result of the two peeks.
addrThe byte address of the lower 32-bit register to read from (truncated to 20 bits).
Exceptions
◆ poke32()
virtual void uhd::rfnoc::register_iface::poke32 ( uint32_t  addr,
uint32_t  data,
bool  ack = false
Write a 32-bit register implemented in the NoC block.
addrThe byte address of the register to write to (truncated to 20 bits).
dataNew value of this register.
Exceptions
◆ poke64()
void uhd::rfnoc::register_iface::poke64 ( uint32_t  addr,
uint64_t  data,
bool  ack = false
Write two consecutive 32-bit registers implemented in the NoC block from one 64-bit value.
Note: This is a convenience call, because all register pokes are 32-bits. This will concatenate two pokes in a block poke, and then return the combined result of the two pokes.
dataNew value of the register(s).
Exceptions
◆ poll32()
virtual void uhd::rfnoc::register_iface::poll32 ( uint32_t  addr,
uint32_t  data,
uint32_t  mask,
bool  ack = false
Poll a 32-bit register until its value for all bits in mask match data&mask
This will insert a command into the command queue to wait until a register is of a certain value. This can be used, e.g., to poll for a lock pin before executing the next command. It is related to sleep(), except it has a condition to wait on, rather than an unconditional stall duration. The timeout is hardware-timed. If the register does not attain the requested value within the requested duration, ${something bad happens}.
Example: Assume readback register 16 is a status register, and bit 0 indicates a lock is in place (i.e., we want it to be 1) and bit 1 is an error flag (i.e., we want it to be 0). The previous command can modify the state of the block, so we give it 1ms to settle. In that case, the call would be thus:
// iface is a register_iface::sptr:
iface->poll32(16, 0x1, 0x3, 1e-3);
dataThe values that the register must have
maskThe bitmask that is applied before checking the readback value
timeoutThe max duration that the register is allowed to take before reaching its new state.
timeWhen the poll should be executed
ackShould transaction completion be acknowledged? This is typically only necessary if the software needs a condition to be fulfilled before continueing, or during debugging.
Exceptions
◆ register_async_msg_handler()
virtual void uhd::rfnoc::register_iface::register_async_msg_handler ( async_msg_callback_t  callback_f)
Register a callback function for when an async message is received
Only one callback function can be registered. When calling this multiple times, only the last callback will be accepted.
callback_fThe function to call when an asynchronous message is received.
◆ register_async_msg_validator()
virtual void uhd::rfnoc::register_iface::register_async_msg_validator ( async_msg_validator_t  callback_f)
Register a callback function to validate a received async message
The purpose of this callback is to provide a method to the framework to make sure a received async message is valid. If this callback is provided, the framework will first pass the message to the validator for validation. If the validator returns true, the async message is ACK'd with a ctrl_status_t::CMD_OKAY response, and then the async message is executed. If the validator returns false, then the async message is ACK'd with a ctrl_status_t::CMD_CMDERR, and the async message handler is not excecuted.
This callback may not communicate with the device, it can only look at the data and make a valid/not valid decision.
◆ set_policy()
virtual void uhd::rfnoc::register_iface::set_policy ( const std::string &  name,
const uhd::device_addr_t args
Set a policy that governs the operational parameters of this register bus. Policies can be used to make tradeoffs between performance, resilience, latency, etc.
nameThe name of the policy to apply
argsAdditional arguments to pass to the policy governor
◆ sleep()
virtual void uhd::rfnoc::register_iface::sleep ( time_spec_t  duration,
bool  ack = false
Send a command to halt (block) the control bus for a specified time. This is a hardware-timed sleep.
durationThe amount of time to sleep.
Exceptions
