USRP Hardware Driver and USRP Manual Version: 4.1.0.1
uhd::usrp_clock::octoclock_eeprom_t Class Reference
#include <uhd/usrp_clock/octoclock_eeprom.hpp>
Inheritance diagram for uhd::usrp_clock::octoclock_eeprom_t:
 octoclock_eeprom_t (void)
 Make a new empty OctoClock EEPROM handler. More...
 octoclock_eeprom_t (transport::udp_simple::sptr transport, uint32_t proto_ver)
void commit () const
 dict (void)
std::size_t size (void) const
bool operator== (const dict< std::string, std::string > &other) const
bool operator!= (const dict< std::string, std::string > &other) const
void update (const dict< std::string, std::string > &new_dict, bool fail_on_conflict=true)
 operator std::map< std::string, std::string > () const
The OctoClock EEPROM object: Knows how to read and write the OctoClock EEPROM. The class inherits from a string, string dictionary. Use the dictionary interface to get and set values. Commit to the EEPROM to save changed settings.
◆ octoclock_eeprom_t() [1/2]
uhd::usrp_clock::octoclock_eeprom_t::octoclock_eeprom_t ( void  )
◆ octoclock_eeprom_t() [2/2]
uhd::usrp_clock::octoclock_eeprom_t::octoclock_eeprom_t ( transport::udp_simple::sptr  transport,
uint32_t  proto_ver
Make a new OctoClock EEPROM handler.
transportthe UDP transport to the OctoClock
proto_verfirmware protocol version
◆ commit()
void uhd::usrp_clock::octoclock_eeprom_t::commit ( ) const
Write the contents of this object to the EEPROM.
