USRP Hardware Driver and USRP Manual Version: 4.1.0.1
ddc_block_control.hpp
1//
2// Copyright 2019 Ettus Research, a National Instruments Brand
3//
4// SPDX-License-Identifier: GPL-3.0-or-later
5//
6
7#pragma once
8
9#include <uhd/config.hpp>
11#include <uhd/types/ranges.hpp>
12#include <boost/optional.hpp>
13
14namespace uhd { namespace rfnoc {
15
30{
31public:
33
34 static const uint16_t MAJOR_COMPAT;
35 static const uint16_t MINOR_COMPAT;
36 // Readback addresses
37 static const uint32_t RB_COMPAT_NUM;
38 static const uint32_t RB_NUM_HB;
39 static const uint32_t RB_CIC_MAX_DECIM;
40 // Write addresses
41 static const uint32_t SR_N_ADDR;
42 static const uint32_t SR_M_ADDR;
43 static const uint32_t SR_CONFIG_ADDR;
44 static const uint32_t SR_FREQ_ADDR;
45 static const uint32_t SR_SCALE_IQ_ADDR;
46 static const uint32_t SR_DECIM_ADDR;
47 static const uint32_t SR_MUX_ADDR;
48 static const uint32_t SR_COEFFS_ADDR;
49 static const uint32_t SR_TIME_INCR_ADDR;
50
70 virtual double set_freq(const double freq,
71 const size_t chan,
72 const boost::optional<uhd::time_spec_t> time = boost::none) = 0;
73
78 virtual double get_freq(const size_t chan) const = 0;
79
84 virtual uhd::freq_range_t get_frequency_range(const size_t chan) const = 0;
85
91 virtual double get_input_rate(const size_t chan) const = 0;
92
98 virtual void set_input_rate(const double rate, const size_t chan) = 0;
99
107 virtual double get_output_rate(const size_t chan) const = 0;
108
114 virtual uhd::meta_range_t get_output_rates(const size_t chan) const = 0;
115
126 virtual double set_output_rate(const double rate, const size_t chan) = 0;
127
128 /**************************************************************************
129 * Streaming-Related API Calls
130 *************************************************************************/
136 virtual void issue_stream_cmd(
137 const uhd::stream_cmd_t& stream_cmd, const size_t port) = 0;
138};
139
140}} // namespace uhd::rfnoc
Definition: ddc_block_control.hpp:30
Definition: noc_block_base.hpp:42
Definition: time_spec.hpp:31
Definition: config.h:70
Definition: build_info.hpp:12
#define RFNOC_DECLARE_BLOCK(CLASS_NAME)
Definition: noc_block_base.hpp:21
Definition: ranges.hpp:65
Definition: stream_cmd.hpp:40
