USRP Hardware Driver and USRP Manual Version: 4.1.0.1
log.h File Reference
#include <uhd/config.h>
Macros
#define UHD_LOG_TRACE(component, ...)    _uhd_log(UHD_LOG_LEVEL_TRACE, __FILE__, __LINE__, component, __VA_ARGS__);
#define UHD_LOG_DEBUG(component, ...)    _uhd_log(UHD_LOG_LEVEL_DEBUG, __FILE__, __LINE__, component, __VA_ARGS__);
#define UHD_LOG_INFO(component, ...)    _uhd_log(UHD_LOG_LEVEL_INFO, __FILE__, __LINE__, component, __VA_ARGS__);
#define UHD_LOG_WARNING(component, ...)    _uhd_log(UHD_LOG_LEVEL_WARNING, __FILE__, __LINE__, component, __VA_ARGS__);
#define UHD_LOG_ERROR(component, ...)    _uhd_log(UHD_LOG_LEVEL_ERROR, __FILE__, __LINE__, component, __VA_ARGS__);
#define UHD_LOG_FATAL(component, ...)    _uhd_log(UHD_LOG_LEVEL_FATAL, __FILE__, __LINE__, component, __VA_ARGS__);
Enumerations
enum  uhd_log_severity_level_t {
  UHD_LOG_LEVEL_TRACE , UHD_LOG_LEVEL_DEBUG , UHD_LOG_LEVEL_INFO , UHD_LOG_LEVEL_WARNING ,
  UHD_LOG_LEVEL_ERROR , UHD_LOG_LEVEL_FATAL
Functions
void UHD_API _uhd_log (const uhd_log_severity_level_t log_level, const char *filename, const int lineno, const char *comp, const char *format,...)
◆ UHD_LOG_DEBUG
#define UHD_LOG_DEBUG (   component,
◆ UHD_LOG_ERROR
#define UHD_LOG_ERROR (   component,
◆ UHD_LOG_FATAL
#define UHD_LOG_FATAL (   component,
◆ UHD_LOG_INFO
#define UHD_LOG_INFO (   component,
◆ UHD_LOG_TRACE
#define UHD_LOG_TRACE (   component,
◆ UHD_LOG_WARNING
#define UHD_LOG_WARNING (   component,
◆ uhd_log_severity_level_t
Enumerator
UHD_LOG_LEVEL_TRACE
UHD_LOG_LEVEL_DEBUG
UHD_LOG_LEVEL_INFO
UHD_LOG_LEVEL_ERROR
UHD_LOG_LEVEL_FATAL
Function Documentation
◆ _uhd_log()
void UHD_API _uhd_log ( const uhd_log_severity_level_t  log_level,
const char *  filename,
const int  lineno,
const char *  comp,
const char *  format,
