USRP Hardware Driver and USRP Manual Version: 4.1.0.1
usrp.h
1//
2// Copyright 2015-2016 Ettus Research LLC
3// Copyright 2018 Ettus Research, a National Instruments Company
4//
5// SPDX-License-Identifier: GPL-3.0-or-later
6//
7
8#pragma once
9
10#include <uhd/config.h>
11#include <uhd/error.h>
12#include <uhd/types/metadata.h>
13#include <uhd/types/ranges.h>
14#include <uhd/types/sensors.h>
18#include <uhd/types/usrp_info.h>
22/* version.hpp is safe to include in C: */
23#include <uhd/version.hpp> /* Provides UHD_VERSION */
25#include <stdbool.h>
26#include <stdlib.h>
27#include <stdint.h>
28#include <time.h>
29
31typedef struct {
32 size_t bitwidth;
36
37/*
38 * Streamers
39 */
40
42
45typedef struct {
51 char* args;
53 size_t* channel_list;
57
59
62typedef enum {
72
74
77typedef struct {
81 size_t num_samps;
89
90struct uhd_rx_streamer;
91struct uhd_tx_streamer;
92
94
97typedef struct uhd_rx_streamer* uhd_rx_streamer_handle;
98
100
103typedef struct uhd_tx_streamer* uhd_tx_streamer_handle;
104
105#ifdef __cplusplus
106extern "C" {
107#endif
108
109/*
110 * RX Streamer
111 */
112
114
120);
121
123
129);
130
134 size_t *num_channels_out
135);
136
140 size_t *max_num_samps_out
141);
142
144
157 void** buffs,
158 size_t samps_per_buff,
160 double timeout,
161 bool one_packet,
162 size_t *items_recvd
163);
164
166
171 const uhd_stream_cmd_t *stream_cmd
172);
173
175
185 char* error_out,
186 size_t strbuffer_len
187);
188
189/*
190 * TX Streamer
191 */
192
194
200);
201
203
209);
210
214 size_t *num_channels_out
215);
216
220 size_t *max_num_samps_out
221);
222
224
236 const void **buffs,
237 size_t samps_per_buff,
239 double timeout,
240 size_t *items_sent
241);
242
244
250 double timeout,
251 bool *valid
252);
253
255
265 char* error_out,
266 size_t strbuffer_len
267);
268
269#ifdef __cplusplus
270}
271#endif
272
273/****************************************************************************
274 * Public Datatypes for USRP / streamer handling.
275 ***************************************************************************/
276struct uhd_usrp;
277
279/*
280 * See uhd::usrp::multi_usrp for more details.
281 *
282 * NOTE: You must pass this handle into uhd_usrp_make before using it.
283 */
284typedef struct uhd_usrp* uhd_usrp_handle;
285
286/****************************************************************************
287 * USRP Make / Free API calls
288 ***************************************************************************/
289#ifdef __cplusplus
290extern "C" {
291#endif
292
294
298 const char* args,
299 uhd_string_vector_handle *strings_out
300);
301
303
309 const char *args
310);
311
313
319);
320
324 char* error_out,
325 size_t strbuffer_len
326);
327
331 uhd_stream_args_t *stream_args,
333);
334
338 uhd_stream_args_t *stream_args,
340);
341
342/****************************************************************************
343 * multi_usrp API calls
344 ***************************************************************************/
345
347
352 size_t chan,
353 uhd_usrp_rx_info_t *info_out
354);
355
357
362 size_t chan,
363 uhd_usrp_tx_info_t *info_out
364);
365
366/****************************************************************************
367 * Motherboard methods
368 ***************************************************************************/
369
371
376 double rate,
377 size_t mboard
378);
379
381
386 size_t mboard,
387 double *clock_rate_out
388);
389
391
396 char* pp_string_out,
397 size_t strbuffer_len
398);
399
401
406 size_t mboard,
407 char* mboard_name_out,
408 size_t strbuffer_len
409);
410
412
417 size_t mboard,
418 int64_t *full_secs_out,
419 double *frac_secs_out
420);
421
423
428 size_t mboard,
429 int64_t *full_secs_out,
430 double *frac_secs_out
431);
432
434
439 int64_t full_secs,
440 double frac_secs,
441 size_t mboard
442);
443
445
450 int64_t full_secs,
451 double frac_secs,
452 size_t mboard
453);
454
456
461 int64_t full_secs,
462 double frac_secs
463);
464
468 bool *result_out
469);
470
472
477 int64_t full_secs,
478 double frac_secs,
479 size_t mboard
480);
481
485 size_t mboard
486);
487
489
494 const char* time_source,
495 size_t mboard
496);
497
499
504 size_t mboard,
505 char* time_source_out,
506 size_t strbuffer_len
507);
508
512 size_t mboard,
513 uhd_string_vector_handle *time_sources_out
514);
515
517
522 const char* clock_source,
523 size_t mboard
524);
525
527
532 size_t mboard,
533 char* clock_source_out,
534 size_t strbuffer_len
535);
536
540 size_t mboard,
541 uhd_string_vector_handle *clock_sources_out
542);
543
545
550 bool enb,
551 size_t mboard
552);
553
555
560 bool enb,
561 size_t mboard
562);
563
567 size_t *num_mboards_out
568);
569
573 const char* name,
574 size_t mboard,
575 uhd_sensor_value_handle *sensor_value_out
576);
577
581 size_t mboard,
582 uhd_string_vector_handle *mboard_sensor_names_out
583);
584
586
591 uint8_t addr,
592 uint32_t data,
593 size_t mboard
594);
595
596/****************************************************************************
597 * EEPROM access methods
598 ***************************************************************************/
599
603 uhd_mboard_eeprom_handle mb_eeprom,
604 size_t mboard
605);
606
610 uhd_mboard_eeprom_handle mb_eeprom,
611 size_t mboard
612);
613
617 uhd_dboard_eeprom_handle db_eeprom,
618 const char* unit,
619 const char* slot,
620 size_t mboard
621);
622
626 uhd_dboard_eeprom_handle db_eeprom,
627 const char* unit,
628 const char* slot,
629 size_t mboard
630);
631
632/****************************************************************************
633 * RX methods
634 ***************************************************************************/
635
637
642 uhd_subdev_spec_handle subdev_spec,
643 size_t mboard
644);
645
649 size_t mboard,
650 uhd_subdev_spec_handle subdev_spec_out
651);
652
656 size_t *num_channels_out
657);
658
662 size_t chan,
663 char* rx_subdev_name_out,
664 size_t strbuffer_len
665);
666
670 double rate,
671 size_t chan
672);
673
677 size_t chan,
678 double *rate_out
679);
680
684 size_t chan,
685 uhd_meta_range_handle rates_out
686);
687
691 uhd_tune_request_t *tune_request,
692 size_t chan,
693 uhd_tune_result_t *tune_result
694);
695
699 size_t chan,
700 double *freq_out
701);
702
704
709 size_t chan,
710 uhd_meta_range_handle freq_range_out
711);
712
716 size_t chan,
717 uhd_meta_range_handle freq_range_out
718);
719
721UHD_UNUSED(static const char* UHD_USRP_ALL_LOS) = "all";
722
724/*
725 * See uhd::usrp::multi_usrp::get_rx_lo_names() for more details.
726 */
729 size_t chan,
730 uhd_string_vector_handle *rx_lo_names_out
731);
732
734/*
735 * See uhd::usrp::multi_usrp::set_rx_lo_source() for more details.
736 */
739 const char* src,
740 const char* name,
741 size_t chan
742);
743
747 const char* name,
748 size_t chan,
749 char* rx_lo_source_out,
750 size_t strbuffer_len
751);
752
756 const char* name,
757 size_t chan,
758 uhd_string_vector_handle *rx_lo_sources_out
759);
760
762/*
763 * See uhd::usrp::multi_usrp::set_rx_lo_enabled() for more details.
764 */
767 bool enabled,
768 const char* name,
769 size_t chan
770);
771
775 const char* name,
776 size_t chan,
777 bool* result_out
778);
779
783 double freq,
784 const char* name,
785 size_t chan,
786 double* coerced_freq_out
787);
788
792 const char* name,
793 size_t chan,
794 double* rx_lo_freq_out
795);
796
800 double gain,
801 size_t chan,
802 const char *gain_name
803);
804
806
811 double gain,
812 size_t chan
813);
814
816
821 bool enable,
822 size_t chan
823);
824
828 size_t chan,
829 const char *gain_name,
830 double *gain_out
831);
832
834
839 size_t chan,
840 double *gain_out
841);
842
846 const char* name,
847 size_t chan,
848 uhd_meta_range_handle gain_range_out
849);
850
854 size_t chan,
855 uhd_string_vector_handle *gain_names_out
856);
857
861 const char* ant,
862 size_t chan
863);
864
868 size_t chan,
869 char* ant_out,
870 size_t strbuffer_len
871);
872
876 size_t chan,
877 uhd_string_vector_handle *antennas_out
878);
879
883 size_t chan,
884 uhd_string_vector_handle *sensor_names_out
885);
886
890 double bandwidth,
891 size_t chan
892);
893
897 size_t chan,
898 double *bandwidth_out
899);
900
904 size_t chan,
905 uhd_meta_range_handle bandwidth_range_out
906);
907
911 const char* name,
912 size_t chan,
913 uhd_sensor_value_handle *sensor_value_out
914);
915
917
922 bool enb,
923 size_t chan
924);
925
929 bool enb,
930 size_t chan
931);
932
933/****************************************************************************
934 * TX methods
935 ***************************************************************************/
936
938
943 uhd_subdev_spec_handle subdev_spec,
944 size_t mboard
945);
946
950 size_t mboard,
951 uhd_subdev_spec_handle subdev_spec_out
952);
953
957 size_t *num_channels_out
958);
959
963 size_t chan,
964 char* tx_subdev_name_out,
965 size_t strbuffer_len
966);
967
971 double rate,
972 size_t chan
973);
974
978 size_t chan,
979 double *rate_out
980);
981
985 size_t chan,
986 uhd_meta_range_handle rates_out
987);
988
992 uhd_tune_request_t *tune_request,
993 size_t chan,
994 uhd_tune_result_t *tune_result
995);
996
1000 size_t chan,
1001 double *freq_out
1002);
1003
1005
1010 size_t chan,
1011 uhd_meta_range_handle freq_range_out
1012);
1013
1017 size_t chan,
1018 uhd_meta_range_handle freq_range_out
1019);
1020
1022/*
1023 * See uhd::usrp::multi_usrp::get_tx_lo_names() for more details.
1024 */
1027 size_t chan,
1028 uhd_string_vector_handle *tx_lo_names_out
1029);
1030
1032/*
1033 * See uhd::usrp::multi_usrp::set_tx_lo_source() for more details.
1034 */
1037 const char* src,
1038 const char* name,
1039 size_t chan
1040);
1041
1045 const char* name,
1046 size_t chan,
1047 char* tx_lo_source_out,
1048 size_t strbuffer_len
1049);
1050
1054 const char* name,
1055 size_t chan,
1056 uhd_string_vector_handle *tx_lo_sources_out
1057);
1058
1060/*
1061 * See uhd::usrp::multi_usrp::set_tx_lo_enabled() for more details.
1062 */
1065 bool enabled,
1066 const char* name,
1067 size_t chan
1068);
1069
1073 const char* name,
1074 size_t chan,
1075 bool* result_out
1076);
1077
1081 double freq,
1082 const char* name,
1083 size_t chan,
1084 double* coerced_freq_out
1085);
1086
1090 const char* name,
1091 size_t chan,
1092 double* tx_lo_freq_out
1093);
1094
1098 double gain,
1099 size_t chan,
1100 const char *gain_name
1101);
1102
1104
1109 double gain,
1110 size_t chan
1111);
1112
1116 const char* name,
1117 size_t chan,
1118 uhd_meta_range_handle gain_range_out
1119);
1120
1124 size_t chan,
1125 const char *gain_name,
1126 double *gain_out
1127);
1128
1130
1135 size_t chan,
1136 double *gain_out
1137);
1138
1142 size_t chan,
1143 uhd_string_vector_handle *gain_names_out
1144);
1145
1149 const char* ant,
1150 size_t chan
1151);
1152
1156 size_t chan,
1157 char* ant_out,
1158 size_t strbuffer_len
1159);
1160
1164 size_t chan,
1165 uhd_string_vector_handle *antennas_out
1166);
1167
1171 double bandwidth,
1172 size_t chan
1173);
1174
1178 size_t chan,
1179 double *bandwidth_out
1180);
1181
1185 size_t chan,
1186 uhd_meta_range_handle bandwidth_range_out
1187);
1188
1192 const char* name,
1193 size_t chan,
1194 uhd_sensor_value_handle *sensor_value_out
1195);
1196
1200 size_t chan,
1201 uhd_string_vector_handle *sensor_names_out
1202);
1203
1204/****************************************************************************
1205 * GPIO methods
1206 ***************************************************************************/
1207
1211 size_t mboard,
1212 uhd_string_vector_handle *gpio_banks_out
1213);
1214
1216
1221 const char* bank,
1222 const char* attr,
1223 uint32_t value,
1224 uint32_t mask,
1225 size_t mboard
1226);
1227
1229
1234 const char* bank,
1235 const char* attr,
1236 size_t mboard,
1237 uint32_t *attr_out
1238);
1239
1240#ifdef __cplusplus
1241}
1242#endif
Definition: config.h:70
struct uhd_dboard_eeprom_t * uhd_dboard_eeprom_handle
A C-level interface for interacting with a daughterboard EEPROM.
Definition: dboard_eeprom.h:34
uhd_error
UHD error codes.
Definition: error.h:20
struct uhd_mboard_eeprom_t * uhd_mboard_eeprom_handle
A C-level interface for interacting with a USRP motherboard's EEPROM.
Definition: mboard_eeprom.h:34
struct uhd_rx_metadata_t * uhd_rx_metadata_handle
RX metadata interface for describing sent IF data.
Definition: metadata.h:51
struct uhd_tx_metadata_t * uhd_tx_metadata_handle
TX metadata interface for describing received IF data.
Definition: metadata.h:60
struct uhd_async_metadata_t * uhd_async_metadata_handle
Interface for describing transmit-related events.
Definition: metadata.h:69
Definition: soft_register.hpp:87
Definition: ranges.h:44
Definition: sensors.h:33
uhd_string_vector_t * uhd_string_vector_handle
Definition: string_vector.h:32
A struct of parameters to construct a stream.
Definition: usrp.h:45
char * otw_format
Over-the-wire format.
Definition: usrp.h:49
char * cpu_format
Format of host memory.
Definition: usrp.h:47
int n_channels
Number of channels.
Definition: usrp.h:55
size_t * channel_list
Array that lists channels.
Definition: usrp.h:53
char * args
Other stream args.
Definition: usrp.h:51
Define how device streams to host.
Definition: usrp.h:77
bool stream_now
Stream now?
Definition: usrp.h:83
int64_t time_spec_full_secs
If not now, then full seconds into future to stream.
Definition: usrp.h:85
uhd_stream_mode_t stream_mode
How streaming is issued to the device.
Definition: usrp.h:79
double time_spec_frac_secs
If not now, then fractional seconds into future to stream.
Definition: usrp.h:87
size_t num_samps
Number of samples.
Definition: usrp.h:81
Instructs implementation how to tune the RF chain.
Definition: tune_request.h:28
Stores RF and DSP tuned frequencies.
Definition: tune_result.h:18
Register info.
Definition: usrp.h:31
bool writable
Definition: usrp.h:34
size_t bitwidth
Definition: usrp.h:32
bool readable
Definition: usrp.h:33
USRP RX info.
Definition: usrp_info.h:17
USRP TX info.
Definition: usrp_info.h:40
struct uhd_subdev_spec_t * uhd_subdev_spec_handle
A C-level interface for working with a list of subdevice specifications.
Definition: subdev_spec.h:44
UHD_API uhd_error uhd_usrp_free(uhd_usrp_handle *h)
Safely destroy the USRP object underlying the handle.
UHD_API uhd_error uhd_usrp_get_tx_lo_sources(uhd_usrp_handle h, const char *name, size_t chan, uhd_string_vector_handle *tx_lo_sources_out)
Get a list of possible LO sources.
UHD_API uhd_error uhd_usrp_set_time_next_pps(uhd_usrp_handle h, int64_t full_secs, double frac_secs, size_t mboard)
Set the USRP device's time to the given value upon the next PPS detection.
UHD_API uhd_error uhd_usrp_get_tx_info(uhd_usrp_handle h, size_t chan, uhd_usrp_tx_info_t *info_out)
Get TX info from the USRP device.
struct uhd_rx_streamer * uhd_rx_streamer_handle
C-level interface for working with an RX streamer.
Definition: usrp.h:97
UHD_API uhd_error uhd_usrp_get_time_source(uhd_usrp_handle h, size_t mboard, char *time_source_out, size_t strbuffer_len)
Get the time source for the given device.
UHD_API uhd_error uhd_usrp_get_tx_gain_range(uhd_usrp_handle h, const char *name, size_t chan, uhd_meta_range_handle gain_range_out)
Get all possible gain ranges for the given channel and name.
UHD_API uhd_error uhd_rx_streamer_max_num_samps(uhd_rx_streamer_handle h, size_t *max_num_samps_out)
Get the max number of samples per buffer per packet.
UHD_API uhd_error uhd_usrp_get_normalized_rx_gain(uhd_usrp_handle h, size_t chan, double *gain_out)
Get the given channel's normalized RX gain [0.0, 1.0].
UHD_API uhd_error uhd_usrp_set_tx_freq(uhd_usrp_handle h, uhd_tune_request_t *tune_request, size_t chan, uhd_tune_result_t *tune_result)
Set the given channel's center TX frequency.
UHD_API uhd_error uhd_usrp_get_mboard_sensor_names(uhd_usrp_handle h, size_t mboard, uhd_string_vector_handle *mboard_sensor_names_out)
Get a list of motherboard sensors for the given device.
UHD_API uhd_error uhd_usrp_set_rx_agc(uhd_usrp_handle h, bool enable, size_t chan)
Enable or disable the given channel's RX AGC module.
UHD_API uhd_error uhd_usrp_make(uhd_usrp_handle *h, const char *args)
Create a USRP handle.
UHD_API uhd_error uhd_tx_streamer_recv_async_msg(uhd_tx_streamer_handle h, uhd_async_metadata_handle *md, double timeout, bool *valid)
Receive an asynchronous message from this streamer.
UHD_API uhd_error uhd_usrp_set_command_time(uhd_usrp_handle h, int64_t full_secs, double frac_secs, size_t mboard)
Set the time at which timed commands will take place.
UHD_API uhd_error uhd_usrp_set_tx_subdev_spec(uhd_usrp_handle h, uhd_subdev_spec_handle subdev_spec, size_t mboard)
Map the given device's TX frontend to a channel.
UHD_API uhd_error uhd_usrp_get_tx_bandwidth(uhd_usrp_handle h, size_t chan, double *bandwidth_out)
Get the bandwidth for the given channel's TX frontend.
UHD_API uhd_error uhd_usrp_get_dboard_eeprom(uhd_usrp_handle h, uhd_dboard_eeprom_handle db_eeprom, const char *unit, const char *slot, size_t mboard)
Get a handle for the given device's daughterboard EEPROM.
UHD_API uhd_error uhd_usrp_set_tx_lo_export_enabled(uhd_usrp_handle h, bool enabled, const char *name, size_t chan)
Set whether the LO used by the USRP device is exported.
UHD_API uhd_error uhd_usrp_get_mboard_name(uhd_usrp_handle h, size_t mboard, char *mboard_name_out, size_t strbuffer_len)
Get the motherboard name for the given device.
UHD_API uhd_error uhd_rx_streamer_free(uhd_rx_streamer_handle *h)
Free an RX streamer handle.
UHD_API uhd_error uhd_usrp_get_rx_info(uhd_usrp_handle h, size_t chan, uhd_usrp_rx_info_t *info_out)
Get RX info from the USRP device.
UHD_API uhd_error uhd_usrp_set_rx_gain(uhd_usrp_handle h, double gain, size_t chan, const char *gain_name)
Set the RX gain for the given channel and name.
UHD_API uhd_error uhd_usrp_get_clock_source(uhd_usrp_handle h, size_t mboard, char *clock_source_out, size_t strbuffer_len)
Get the given device's clock source.
UHD_API uhd_error uhd_usrp_get_gpio_banks(uhd_usrp_handle h, size_t mboard, uhd_string_vector_handle *gpio_banks_out)
Get a list of GPIO banks associated with the given channels.
UHD_API uhd_error uhd_usrp_set_rx_rate(uhd_usrp_handle h, double rate, size_t chan)
Set the given RX channel's sample rate (in Sps)
UHD_API uhd_error uhd_usrp_set_gpio_attr(uhd_usrp_handle h, const char *bank, const char *attr, uint32_t value, uint32_t mask, size_t mboard)
Set a GPIO attribute for a given GPIO bank.
UHD_API uhd_error uhd_usrp_get_tx_subdev_name(uhd_usrp_handle h, size_t chan, char *tx_subdev_name_out, size_t strbuffer_len)
Get the name for the RX frontend.
UHD_API uhd_error uhd_usrp_get_rx_lo_names(uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *rx_lo_names_out)
Get a list of possible LO stage names.
struct uhd_tx_streamer * uhd_tx_streamer_handle
C-level interface for working with a TX streamer.
Definition: usrp.h:103
UHD_API uhd_error uhd_usrp_get_rx_lo_source(uhd_usrp_handle h, const char *name, size_t chan, char *rx_lo_source_out, size_t strbuffer_len)
Get the currently set LO source.
UHD_API uhd_error uhd_usrp_get_rx_gain(uhd_usrp_handle h, size_t chan, const char *gain_name, double *gain_out)
Get the given channel's RX gain.
UHD_API uhd_error uhd_usrp_get_tx_antennas(uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *antennas_out)
Get a list of tx antennas associated with the given channels.
UHD_API uhd_error uhd_rx_streamer_last_error(uhd_rx_streamer_handle h, char *error_out, size_t strbuffer_len)
Get the last error reported by the RX streamer.
UHD_API uhd_error uhd_rx_streamer_num_channels(uhd_rx_streamer_handle h, size_t *num_channels_out)
Get the number of channels associated with this streamer.
UHD_UNUSED(static const char *UHD_USRP_ALL_LOS)
A wildcard for all LO names.
UHD_API uhd_error uhd_usrp_clear_command_time(uhd_usrp_handle h, size_t mboard)
Clear the command time so that commands are sent ASAP.
UHD_API uhd_error uhd_usrp_set_rx_lo_export_enabled(uhd_usrp_handle h, bool enabled, const char *name, size_t chan)
UHD_API uhd_error uhd_usrp_get_tx_lo_names(uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *tx_lo_names_out)
UHD_API uhd_error uhd_usrp_get_rx_bandwidth(uhd_usrp_handle h, size_t chan, double *bandwidth_out)
Get the bandwidth for the given channel's RX frontend.
uhd_stream_mode_t
Definition: usrp.h:62
@ UHD_STREAM_MODE_NUM_SAMPS_AND_DONE
Stream some number of samples and finish.
Definition: usrp.h:68
@ UHD_STREAM_MODE_START_CONTINUOUS
Stream samples indefinitely.
Definition: usrp.h:64
@ UHD_STREAM_MODE_NUM_SAMPS_AND_MORE
Stream some number of samples but expect more.
Definition: usrp.h:70
@ UHD_STREAM_MODE_STOP_CONTINUOUS
End continuous streaming.
Definition: usrp.h:66
UHD_API uhd_error uhd_usrp_set_rx_bandwidth(uhd_usrp_handle h, double bandwidth, size_t chan)
Set the bandwidth for the given channel's RX frontend.
UHD_API uhd_error uhd_usrp_get_tx_gain_names(uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *gain_names_out)
Get a list of TX gain names for the given channel.
UHD_API uhd_error uhd_usrp_get_rx_freq_range(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle freq_range_out)
Get all possible center frequency ranges for the given channel.
UHD_API uhd_error uhd_usrp_get_rx_lo_sources(uhd_usrp_handle h, const char *name, size_t chan, uhd_string_vector_handle *rx_lo_sources_out)
UHD_API uhd_error uhd_usrp_set_rx_freq(uhd_usrp_handle h, uhd_tune_request_t *tune_request, size_t chan, uhd_tune_result_t *tune_result)
Set the given channel's center RX frequency.
UHD_API uhd_error uhd_usrp_get_rx_gain_range(uhd_usrp_handle h, const char *name, size_t chan, uhd_meta_range_handle gain_range_out)
UHD_API uhd_error uhd_usrp_set_master_clock_rate(uhd_usrp_handle h, double rate, size_t mboard)
Set the master clock rate.
UHD_API uhd_error uhd_usrp_get_rx_antennas(uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *antennas_out)
Get a list of RX antennas associated with the given channels.
UHD_API uhd_error uhd_usrp_get_tx_lo_export_enabled(uhd_usrp_handle h, const char *name, size_t chan, bool *result_out)
Returns true if the currently selected LO is being exported.
UHD_API uhd_error uhd_usrp_get_master_clock_rate(uhd_usrp_handle h, size_t mboard, double *clock_rate_out)
Get the master clock rate.
UHD_API uhd_error uhd_usrp_get_tx_freq(uhd_usrp_handle h, size_t chan, double *freq_out)
Get the given channel's center TX frequency.
UHD_API uhd_error uhd_usrp_get_tx_sensor(uhd_usrp_handle h, const char *name, size_t chan, uhd_sensor_value_handle *sensor_value_out)
Get the value for the given TX sensor.
UHD_API uhd_error uhd_rx_streamer_make(uhd_rx_streamer_handle *h)
Create an RX streamer handle.
UHD_API uhd_error uhd_tx_streamer_last_error(uhd_tx_streamer_handle h, char *error_out, size_t strbuffer_len)
Get the last error reported by the TX streamer.
UHD_API uhd_error uhd_usrp_get_tx_lo_freq(uhd_usrp_handle h, const char *name, size_t chan, double *tx_lo_freq_out)
Get the current Tx LO frequency.
UHD_API uhd_error uhd_tx_streamer_make(uhd_tx_streamer_handle *h)
Create an TX streamer handle.
UHD_API uhd_error uhd_usrp_get_tx_stream(uhd_usrp_handle h, uhd_stream_args_t *stream_args, uhd_tx_streamer_handle h_out)
Create TX streamer from a USRP handle and given stream args.
UHD_API uhd_error uhd_usrp_get_fe_tx_freq_range(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle freq_range_out)
Get all possible RF frequency ranges for the given channel's TX RF frontend.
UHD_API uhd_error uhd_usrp_get_tx_num_channels(uhd_usrp_handle h, size_t *num_channels_out)
Get the number of TX channels for the given handle.
UHD_API uhd_error uhd_usrp_get_rx_subdev_name(uhd_usrp_handle h, size_t chan, char *rx_subdev_name_out, size_t strbuffer_len)
UHD_API uhd_error uhd_usrp_get_rx_gain_names(uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *gain_names_out)
Get a list of RX gain names for the given channel.
UHD_API uhd_error uhd_usrp_set_tx_antenna(uhd_usrp_handle h, const char *ant, size_t chan)
Set the TX antenna for the given channel.
UHD_API uhd_error uhd_usrp_get_mboard_eeprom(uhd_usrp_handle h, uhd_mboard_eeprom_handle mb_eeprom, size_t mboard)
Get a handle for the given motherboard's EEPROM.
UHD_API uhd_error uhd_usrp_set_time_source_out(uhd_usrp_handle h, bool enb, size_t mboard)
Enable or disable sending the time source to an output connector.
UHD_API uhd_error uhd_usrp_get_tx_rate(uhd_usrp_handle h, size_t chan, double *rate_out)
Get the given RX channel's sample rate (in Sps)
UHD_API uhd_error uhd_usrp_get_rx_sensor(uhd_usrp_handle h, const char *name, size_t chan, uhd_sensor_value_handle *sensor_value_out)
Get the value for the given RX sensor.
UHD_API uhd_error uhd_usrp_set_rx_dc_offset_enabled(uhd_usrp_handle h, bool enb, size_t chan)
Enable or disable RX DC offset correction for the given channel.
UHD_API uhd_error uhd_usrp_last_error(uhd_usrp_handle h, char *error_out, size_t strbuffer_len)
Get the last error reported by the USRP handle.
UHD_API uhd_error uhd_usrp_get_tx_bandwidth_range(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle bandwidth_range_out)
Get all possible bandwidth ranges for the given channel's TX frontend.
UHD_API uhd_error uhd_usrp_set_clock_source_out(uhd_usrp_handle h, bool enb, size_t mboard)
Enable or disable sending the clock source to an output connector.
UHD_API uhd_error uhd_usrp_get_tx_lo_source(uhd_usrp_handle h, const char *name, size_t chan, char *tx_lo_source_out, size_t strbuffer_len)
UHD_API uhd_error uhd_rx_streamer_issue_stream_cmd(uhd_rx_streamer_handle h, const uhd_stream_cmd_t *stream_cmd)
Issue the given stream command.
UHD_API uhd_error uhd_tx_streamer_free(uhd_tx_streamer_handle *h)
Free an TX streamer handle.
struct uhd_usrp * uhd_usrp_handle
C-level interface for working with a USRP device.
Definition: usrp.h:284
UHD_API uhd_error uhd_usrp_get_normalized_tx_gain(uhd_usrp_handle h, size_t chan, double *gain_out)
Get the given channel's normalized TX gain [0.0, 1.0].
UHD_API uhd_error uhd_usrp_set_rx_iq_balance_enabled(uhd_usrp_handle h, bool enb, size_t chan)
Enable or disable RX IQ imbalance correction for the given channel.
UHD_API uhd_error uhd_usrp_get_tx_antenna(uhd_usrp_handle h, size_t chan, char *ant_out, size_t strbuffer_len)
Get the TX antenna for the given channel.
UHD_API uhd_error uhd_usrp_get_num_mboards(uhd_usrp_handle h, size_t *num_mboards_out)
Get the number of devices associated with the given USRP handle.
UHD_API uhd_error uhd_rx_streamer_recv(uhd_rx_streamer_handle h, void **buffs, size_t samps_per_buff, uhd_rx_metadata_handle *md, double timeout, bool one_packet, size_t *items_recvd)
Receive buffers containing samples into the given RX streamer.
UHD_API uhd_error uhd_usrp_get_rx_stream(uhd_usrp_handle h, uhd_stream_args_t *stream_args, uhd_rx_streamer_handle h_out)
Create RX streamer from a USRP handle and given stream args.
UHD_API uhd_error uhd_usrp_get_tx_freq_range(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle freq_range_out)
UHD_API uhd_error uhd_tx_streamer_max_num_samps(uhd_tx_streamer_handle h, size_t *max_num_samps_out)
UHD_API uhd_error uhd_usrp_get_rx_rate(uhd_usrp_handle h, size_t chan, double *rate_out)
UHD_API uhd_error uhd_usrp_get_rx_sensor_names(uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *sensor_names_out)
Get a list of RX sensors associated with the given channels.
UHD_API uhd_error uhd_usrp_set_time_now(uhd_usrp_handle h, int64_t full_secs, double frac_secs, size_t mboard)
Set the USRP device's time.
UHD_API uhd_error uhd_usrp_get_rx_rates(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle rates_out)
Get a range of possible RX rates for the given channel.
UHD_API uhd_error uhd_usrp_set_clock_source(uhd_usrp_handle h, const char *clock_source, size_t mboard)
Set the given device's clock source.
UHD_API uhd_error uhd_usrp_get_time_synchronized(uhd_usrp_handle h, bool *result_out)
Are all motherboard times synchronized?
UHD_API uhd_error uhd_usrp_get_time_last_pps(uhd_usrp_handle h, size_t mboard, int64_t *full_secs_out, double *frac_secs_out)
Get the time when this device's last PPS pulse occurred.
UHD_API uhd_error uhd_usrp_get_time_now(uhd_usrp_handle h, size_t mboard, int64_t *full_secs_out, double *frac_secs_out)
Get the USRP device's current internal time.
UHD_API uhd_error uhd_usrp_get_rx_antenna(uhd_usrp_handle h, size_t chan, char *ant_out, size_t strbuffer_len)
Get the RX antenna for the given channel.
UHD_API uhd_error uhd_usrp_get_rx_num_channels(uhd_usrp_handle h, size_t *num_channels_out)
Get the number of RX channels for the given handle.
UHD_API uhd_error uhd_usrp_get_pp_string(uhd_usrp_handle h, char *pp_string_out, size_t strbuffer_len)
Get a pretty-print representation of the USRP device.
UHD_API uhd_error uhd_usrp_set_user_register(uhd_usrp_handle h, uint8_t addr, uint32_t data, size_t mboard)
Perform a write on a user configuration register bus.
UHD_API uhd_error uhd_usrp_set_tx_gain(uhd_usrp_handle h, double gain, size_t chan, const char *gain_name)
Set the TX gain for the given channel and name.
UHD_API uhd_error uhd_tx_streamer_num_channels(uhd_tx_streamer_handle h, size_t *num_channels_out)
UHD_API uhd_error uhd_usrp_set_rx_antenna(uhd_usrp_handle h, const char *ant, size_t chan)
Set the RX antenna for the given channel.
UHD_API uhd_error uhd_usrp_get_rx_lo_export_enabled(uhd_usrp_handle h, const char *name, size_t chan, bool *result_out)
UHD_API uhd_error uhd_usrp_set_mboard_eeprom(uhd_usrp_handle h, uhd_mboard_eeprom_handle mb_eeprom, size_t mboard)
Set values in the given motherboard's EEPROM.
UHD_API uhd_error uhd_usrp_get_clock_sources(uhd_usrp_handle h, size_t mboard, uhd_string_vector_handle *clock_sources_out)
Get a list of clock sources for the given device.
UHD_API uhd_error uhd_usrp_set_normalized_rx_gain(uhd_usrp_handle h, double gain, size_t chan)
Set the normalized RX gain [0.0, 1.0] for the given channel.
UHD_API uhd_error uhd_usrp_find(const char *args, uhd_string_vector_handle *strings_out)
Find all connected USRP devices.
UHD_API uhd_error uhd_usrp_get_rx_subdev_spec(uhd_usrp_handle h, size_t mboard, uhd_subdev_spec_handle subdev_spec_out)
Get the RX frontend specification for the given device.
UHD_API uhd_error uhd_usrp_get_time_sources(uhd_usrp_handle h, size_t mboard, uhd_string_vector_handle *time_sources_out)
Get a list of time sources for the given device.
UHD_API uhd_error uhd_usrp_get_tx_rates(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle rates_out)
UHD_API uhd_error uhd_usrp_set_tx_lo_source(uhd_usrp_handle h, const char *src, const char *name, size_t chan)
Set the LO source for the USRP device.
UHD_API uhd_error uhd_usrp_set_rx_lo_source(uhd_usrp_handle h, const char *src, const char *name, size_t chan)
UHD_API uhd_error uhd_usrp_set_tx_bandwidth(uhd_usrp_handle h, double bandwidth, size_t chan)
Set the bandwidth for the given channel's TX frontend.
UHD_API uhd_error uhd_usrp_get_rx_bandwidth_range(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle bandwidth_range_out)
Get all possible bandwidth ranges for the given channel's RX frontend.
UHD_API uhd_error uhd_tx_streamer_send(uhd_tx_streamer_handle h, const void **buffs, size_t samps_per_buff, uhd_tx_metadata_handle *md, double timeout, size_t *items_sent)
Send buffers containing samples described by the metadata.
UHD_API uhd_error uhd_usrp_set_dboard_eeprom(uhd_usrp_handle h, uhd_dboard_eeprom_handle db_eeprom, const char *unit, const char *slot, size_t mboard)
Set values in the given daughterboard's EEPROM.
UHD_API uhd_error uhd_usrp_get_rx_freq(uhd_usrp_handle h, size_t chan, double *freq_out)
Get the given channel's center RX frequency.
UHD_API uhd_error uhd_usrp_get_gpio_attr(uhd_usrp_handle h, const char *bank, const char *attr, size_t mboard, uint32_t *attr_out)
Get a GPIO attribute on a particular GPIO bank.
UHD_API uhd_error uhd_usrp_set_tx_rate(uhd_usrp_handle h, double rate, size_t chan)
UHD_API uhd_error uhd_usrp_set_rx_subdev_spec(uhd_usrp_handle h, uhd_subdev_spec_handle subdev_spec, size_t mboard)
Map the given device's RX frontend to a channel.
UHD_API uhd_error uhd_usrp_get_tx_sensor_names(uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *sensor_names_out)
Get a list of TX sensors associated with the given channels.
UHD_API uhd_error uhd_usrp_get_fe_rx_freq_range(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle freq_range_out)
Get all possible RF frequency ranges for the given channel's RX RF frontend.
UHD_API uhd_error uhd_usrp_set_time_unknown_pps(uhd_usrp_handle h, int64_t full_secs, double frac_secs)
Synchronize the time across all motherboards.
UHD_API uhd_error uhd_usrp_get_tx_gain(uhd_usrp_handle h, size_t chan, const char *gain_name, double *gain_out)
UHD_API uhd_error uhd_usrp_get_tx_subdev_spec(uhd_usrp_handle h, size_t mboard, uhd_subdev_spec_handle subdev_spec_out)
Get the TX frontend specification for the given device.
UHD_API uhd_error uhd_usrp_set_normalized_tx_gain(uhd_usrp_handle h, double gain, size_t chan)
Set the normalized TX gain [0.0, 1.0] for the given channel.
UHD_API uhd_error uhd_usrp_get_rx_lo_freq(uhd_usrp_handle h, const char *name, size_t chan, double *rx_lo_freq_out)
Get the current RX LO frequency.
UHD_API uhd_error uhd_usrp_set_tx_lo_freq(uhd_usrp_handle h, double freq, const char *name, size_t chan, double *coerced_freq_out)
Set the Tx LO frequency.
UHD_API uhd_error uhd_usrp_get_mboard_sensor(uhd_usrp_handle h, const char *name, size_t mboard, uhd_sensor_value_handle *sensor_value_out)
Get the value associated with the given sensor name.
UHD_API uhd_error uhd_usrp_set_time_source(uhd_usrp_handle h, const char *time_source, size_t mboard)
Set the time source for the given device.
UHD_API uhd_error uhd_usrp_set_rx_lo_freq(uhd_usrp_handle h, double freq, const char *name, size_t chan, double *coerced_freq_out)
Set the RX LO frequency.
