USRP Hardware Driver and USRP Manual Version: 4.1.0.1
usrp.h File Reference
#include <uhd/config.h>
#include <uhd/error.h>
#include <uhd/types/metadata.h>
#include <uhd/types/ranges.h>
#include <uhd/types/sensors.h>
#include <uhd/types/string_vector.h>
#include <uhd/types/tune_request.h>
#include <uhd/types/tune_result.h>
#include <uhd/types/usrp_info.h>
#include <uhd/usrp/mboard_eeprom.h>
#include <uhd/usrp/dboard_eeprom.h>
#include <uhd/usrp/subdev_spec.h>
#include <uhd/version.hpp>
#include <stdbool.h>
#include <stdlib.h>
#include <stdint.h>
#include <time.h>
Classes
struct  uhd_usrp_register_info_t
 Register info. More...
struct  uhd_stream_args_t
 A struct of parameters to construct a stream. More...
struct  uhd_stream_cmd_t
 Define how device streams to host. More...
Typedefs
typedef struct uhd_rx_streamer * uhd_rx_streamer_handle
 C-level interface for working with an RX streamer. More...
typedef struct uhd_tx_streamer * uhd_tx_streamer_handle
 C-level interface for working with a TX streamer. More...
typedef struct uhd_usrp * uhd_usrp_handle
 C-level interface for working with a USRP device. More...
Enumerations
enum  uhd_stream_mode_t { UHD_STREAM_MODE_START_CONTINUOUS = 97 , UHD_STREAM_MODE_STOP_CONTINUOUS = 111 , UHD_STREAM_MODE_NUM_SAMPS_AND_DONE = 100 , UHD_STREAM_MODE_NUM_SAMPS_AND_MORE = 109 }
 How streaming is issued to the device. More...
Functions
UHD_API uhd_error uhd_rx_streamer_make (uhd_rx_streamer_handle *h)
 Create an RX streamer handle. More...
UHD_API uhd_error uhd_rx_streamer_free (uhd_rx_streamer_handle *h)
 Free an RX streamer handle. More...
UHD_API uhd_error uhd_rx_streamer_num_channels (uhd_rx_streamer_handle h, size_t *num_channels_out)
UHD_API uhd_error uhd_rx_streamer_max_num_samps (uhd_rx_streamer_handle h, size_t *max_num_samps_out)
UHD_API uhd_error uhd_rx_streamer_recv (uhd_rx_streamer_handle h, void **buffs, size_t samps_per_buff, uhd_rx_metadata_handle *md, double timeout, bool one_packet, size_t *items_recvd)
 Receive buffers containing samples into the given RX streamer. More...
UHD_API uhd_error uhd_rx_streamer_issue_stream_cmd (uhd_rx_streamer_handle h, const uhd_stream_cmd_t *stream_cmd)
 Issue the given stream command. More...
UHD_API uhd_error uhd_rx_streamer_last_error (uhd_rx_streamer_handle h, char *error_out, size_t strbuffer_len)
 Get the last error reported by the RX streamer. More...
UHD_API uhd_error uhd_tx_streamer_make (uhd_tx_streamer_handle *h)
 Create an TX streamer handle. More...
UHD_API uhd_error uhd_tx_streamer_free (uhd_tx_streamer_handle *h)
 Free an TX streamer handle. More...
UHD_API uhd_error uhd_tx_streamer_num_channels (uhd_tx_streamer_handle h, size_t *num_channels_out)
UHD_API uhd_error uhd_tx_streamer_max_num_samps (uhd_tx_streamer_handle h, size_t *max_num_samps_out)
UHD_API uhd_error uhd_tx_streamer_send (uhd_tx_streamer_handle h, const void **buffs, size_t samps_per_buff, uhd_tx_metadata_handle *md, double timeout, size_t *items_sent)
 Send buffers containing samples described by the metadata. More...
UHD_API uhd_error uhd_tx_streamer_recv_async_msg (uhd_tx_streamer_handle h, uhd_async_metadata_handle *md, double timeout, bool *valid)
 Receive an asynchronous message from this streamer. More...
UHD_API uhd_error uhd_tx_streamer_last_error (uhd_tx_streamer_handle h, char *error_out, size_t strbuffer_len)
 Get the last error reported by the TX streamer. More...
UHD_API uhd_error uhd_usrp_find (const char *args, uhd_string_vector_handle *strings_out)
 Find all connected USRP devices. More...
UHD_API uhd_error uhd_usrp_make (uhd_usrp_handle *h, const char *args)
 Create a USRP handle. More...
UHD_API uhd_error uhd_usrp_free (uhd_usrp_handle *h)
 Safely destroy the USRP object underlying the handle. More...
UHD_API uhd_error uhd_usrp_last_error (uhd_usrp_handle h, char *error_out, size_t strbuffer_len)
 Get the last error reported by the USRP handle. More...
UHD_API uhd_error uhd_usrp_get_rx_stream (uhd_usrp_handle h, uhd_stream_args_t *stream_args, uhd_rx_streamer_handle h_out)
 Create RX streamer from a USRP handle and given stream args. More...
UHD_API uhd_error uhd_usrp_get_tx_stream (uhd_usrp_handle h, uhd_stream_args_t *stream_args, uhd_tx_streamer_handle h_out)
 Create TX streamer from a USRP handle and given stream args. More...
UHD_API uhd_error uhd_usrp_get_rx_info (uhd_usrp_handle h, size_t chan, uhd_usrp_rx_info_t *info_out)
 Get RX info from the USRP device. More...
UHD_API uhd_error uhd_usrp_get_tx_info (uhd_usrp_handle h, size_t chan, uhd_usrp_tx_info_t *info_out)
 Get TX info from the USRP device. More...
UHD_API uhd_error uhd_usrp_set_master_clock_rate (uhd_usrp_handle h, double rate, size_t mboard)
 Set the master clock rate. More...
UHD_API uhd_error uhd_usrp_get_master_clock_rate (uhd_usrp_handle h, size_t mboard, double *clock_rate_out)
 Get the master clock rate. More...
UHD_API uhd_error uhd_usrp_get_pp_string (uhd_usrp_handle h, char *pp_string_out, size_t strbuffer_len)
 Get a pretty-print representation of the USRP device. More...
UHD_API uhd_error uhd_usrp_get_mboard_name (uhd_usrp_handle h, size_t mboard, char *mboard_name_out, size_t strbuffer_len)
 Get the motherboard name for the given device. More...
UHD_API uhd_error uhd_usrp_get_time_now (uhd_usrp_handle h, size_t mboard, int64_t *full_secs_out, double *frac_secs_out)
 Get the USRP device's current internal time. More...
UHD_API uhd_error uhd_usrp_get_time_last_pps (uhd_usrp_handle h, size_t mboard, int64_t *full_secs_out, double *frac_secs_out)
 Get the time when this device's last PPS pulse occurred. More...
UHD_API uhd_error uhd_usrp_set_time_now (uhd_usrp_handle h, int64_t full_secs, double frac_secs, size_t mboard)
 Set the USRP device's time. More...
UHD_API uhd_error uhd_usrp_set_time_next_pps (uhd_usrp_handle h, int64_t full_secs, double frac_secs, size_t mboard)
 Set the USRP device's time to the given value upon the next PPS detection. More...
UHD_API uhd_error uhd_usrp_set_time_unknown_pps (uhd_usrp_handle h, int64_t full_secs, double frac_secs)
 Synchronize the time across all motherboards. More...
UHD_API uhd_error uhd_usrp_get_time_synchronized (uhd_usrp_handle h, bool *result_out)
 Are all motherboard times synchronized? More...
UHD_API uhd_error uhd_usrp_set_command_time (uhd_usrp_handle h, int64_t full_secs, double frac_secs, size_t mboard)
 Set the time at which timed commands will take place. More...
UHD_API uhd_error uhd_usrp_clear_command_time (uhd_usrp_handle h, size_t mboard)
 Clear the command time so that commands are sent ASAP. More...
UHD_API uhd_error uhd_usrp_set_time_source (uhd_usrp_handle h, const char *time_source, size_t mboard)
 Set the time source for the given device. More...
UHD_API uhd_error uhd_usrp_get_time_source (uhd_usrp_handle h, size_t mboard, char *time_source_out, size_t strbuffer_len)
 Get the time source for the given device. More...
UHD_API uhd_error uhd_usrp_get_time_sources (uhd_usrp_handle h, size_t mboard, uhd_string_vector_handle *time_sources_out)
 Get a list of time sources for the given device. More...
UHD_API uhd_error uhd_usrp_set_clock_source (uhd_usrp_handle h, const char *clock_source, size_t mboard)
 Set the given device's clock source. More...
UHD_API uhd_error uhd_usrp_get_clock_source (uhd_usrp_handle h, size_t mboard, char *clock_source_out, size_t strbuffer_len)
 Get the given device's clock source. More...
UHD_API uhd_error uhd_usrp_get_clock_sources (uhd_usrp_handle h, size_t mboard, uhd_string_vector_handle *clock_sources_out)
 Get a list of clock sources for the given device. More...
UHD_API uhd_error uhd_usrp_set_clock_source_out (uhd_usrp_handle h, bool enb, size_t mboard)
 Enable or disable sending the clock source to an output connector. More...
UHD_API uhd_error uhd_usrp_set_time_source_out (uhd_usrp_handle h, bool enb, size_t mboard)
 Enable or disable sending the time source to an output connector. More...
UHD_API uhd_error uhd_usrp_get_num_mboards (uhd_usrp_handle h, size_t *num_mboards_out)
 Get the number of devices associated with the given USRP handle. More...
UHD_API uhd_error uhd_usrp_get_mboard_sensor (uhd_usrp_handle h, const char *name, size_t mboard, uhd_sensor_value_handle *sensor_value_out)
 Get the value associated with the given sensor name. More...
UHD_API uhd_error uhd_usrp_get_mboard_sensor_names (uhd_usrp_handle h, size_t mboard, uhd_string_vector_handle *mboard_sensor_names_out)
 Get a list of motherboard sensors for the given device. More...
UHD_API uhd_error uhd_usrp_set_user_register (uhd_usrp_handle h, uint8_t addr, uint32_t data, size_t mboard)
 Perform a write on a user configuration register bus. More...
UHD_API uhd_error uhd_usrp_get_mboard_eeprom (uhd_usrp_handle h, uhd_mboard_eeprom_handle mb_eeprom, size_t mboard)
 Get a handle for the given motherboard's EEPROM. More...
UHD_API uhd_error uhd_usrp_set_mboard_eeprom (uhd_usrp_handle h, uhd_mboard_eeprom_handle mb_eeprom, size_t mboard)
 Set values in the given motherboard's EEPROM. More...
UHD_API uhd_error uhd_usrp_get_dboard_eeprom (uhd_usrp_handle h, uhd_dboard_eeprom_handle db_eeprom, const char *unit, const char *slot, size_t mboard)
 Get a handle for the given device's daughterboard EEPROM. More...
UHD_API uhd_error uhd_usrp_set_dboard_eeprom (uhd_usrp_handle h, uhd_dboard_eeprom_handle db_eeprom, const char *unit, const char *slot, size_t mboard)
 Set values in the given daughterboard's EEPROM. More...
UHD_API uhd_error uhd_usrp_set_rx_subdev_spec (uhd_usrp_handle h, uhd_subdev_spec_handle subdev_spec, size_t mboard)
 Map the given device's RX frontend to a channel. More...
UHD_API uhd_error uhd_usrp_get_rx_subdev_spec (uhd_usrp_handle h, size_t mboard, uhd_subdev_spec_handle subdev_spec_out)
 Get the RX frontend specification for the given device. More...
UHD_API uhd_error uhd_usrp_get_rx_num_channels (uhd_usrp_handle h, size_t *num_channels_out)
 Get the number of RX channels for the given handle. More...
UHD_API uhd_error uhd_usrp_get_rx_subdev_name (uhd_usrp_handle h, size_t chan, char *rx_subdev_name_out, size_t strbuffer_len)
 Get the name for the RX frontend. More...
UHD_API uhd_error uhd_usrp_set_rx_rate (uhd_usrp_handle h, double rate, size_t chan)
 Set the given RX channel's sample rate (in Sps) More...
UHD_API uhd_error uhd_usrp_get_rx_rate (uhd_usrp_handle h, size_t chan, double *rate_out)
 Get the given RX channel's sample rate (in Sps) More...
UHD_API uhd_error uhd_usrp_get_rx_rates (uhd_usrp_handle h, size_t chan, uhd_meta_range_handle rates_out)
 Get a range of possible RX rates for the given channel. More...
UHD_API uhd_error uhd_usrp_set_rx_freq (uhd_usrp_handle h, uhd_tune_request_t *tune_request, size_t chan, uhd_tune_result_t *tune_result)
 Set the given channel's center RX frequency. More...
UHD_API uhd_error uhd_usrp_get_rx_freq (uhd_usrp_handle h, size_t chan, double *freq_out)
 Get the given channel's center RX frequency. More...
UHD_API uhd_error uhd_usrp_get_rx_freq_range (uhd_usrp_handle h, size_t chan, uhd_meta_range_handle freq_range_out)
 Get all possible center frequency ranges for the given channel. More...
UHD_API uhd_error uhd_usrp_get_fe_rx_freq_range (uhd_usrp_handle h, size_t chan, uhd_meta_range_handle freq_range_out)
 Get all possible RF frequency ranges for the given channel's RX RF frontend. More...
 UHD_UNUSED (static const char *UHD_USRP_ALL_LOS)
 A wildcard for all LO names. More...
UHD_API uhd_error uhd_usrp_get_rx_lo_names (uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *rx_lo_names_out)
 Get a list of possible LO stage names. More...
UHD_API uhd_error uhd_usrp_set_rx_lo_source (uhd_usrp_handle h, const char *src, const char *name, size_t chan)
 Set the LO source for the USRP device. More...
UHD_API uhd_error uhd_usrp_get_rx_lo_source (uhd_usrp_handle h, const char *name, size_t chan, char *rx_lo_source_out, size_t strbuffer_len)
 Get the currently set LO source. More...
UHD_API uhd_error uhd_usrp_get_rx_lo_sources (uhd_usrp_handle h, const char *name, size_t chan, uhd_string_vector_handle *rx_lo_sources_out)
 Get a list of possible LO sources. More...
UHD_API uhd_error uhd_usrp_set_rx_lo_export_enabled (uhd_usrp_handle h, bool enabled, const char *name, size_t chan)
 Set whether the LO used by the USRP device is exported. More...
UHD_API uhd_error uhd_usrp_get_rx_lo_export_enabled (uhd_usrp_handle h, const char *name, size_t chan, bool *result_out)
 Returns true if the currently selected LO is being exported. More...
UHD_API uhd_error uhd_usrp_set_rx_lo_freq (uhd_usrp_handle h, double freq, const char *name, size_t chan, double *coerced_freq_out)
 Set the RX LO frequency. More...
UHD_API uhd_error uhd_usrp_get_rx_lo_freq (uhd_usrp_handle h, const char *name, size_t chan, double *rx_lo_freq_out)
 Get the current RX LO frequency. More...
UHD_API uhd_error uhd_usrp_set_rx_gain (uhd_usrp_handle h, double gain, size_t chan, const char *gain_name)
 Set the RX gain for the given channel and name. More...
UHD_API uhd_error uhd_usrp_set_normalized_rx_gain (uhd_usrp_handle h, double gain, size_t chan)
 Set the normalized RX gain [0.0, 1.0] for the given channel. More...
UHD_API uhd_error uhd_usrp_set_rx_agc (uhd_usrp_handle h, bool enable, size_t chan)
 Enable or disable the given channel's RX AGC module. More...
UHD_API uhd_error uhd_usrp_get_rx_gain (uhd_usrp_handle h, size_t chan, const char *gain_name, double *gain_out)
 Get the given channel's RX gain. More...
UHD_API uhd_error uhd_usrp_get_normalized_rx_gain (uhd_usrp_handle h, size_t chan, double *gain_out)
 Get the given channel's normalized RX gain [0.0, 1.0]. More...
UHD_API uhd_error uhd_usrp_get_rx_gain_range (uhd_usrp_handle h, const char *name, size_t chan, uhd_meta_range_handle gain_range_out)
 Get all possible gain ranges for the given channel and name. More...
UHD_API uhd_error uhd_usrp_get_rx_gain_names (uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *gain_names_out)
 Get a list of RX gain names for the given channel. More...
UHD_API uhd_error uhd_usrp_set_rx_antenna (uhd_usrp_handle h, const char *ant, size_t chan)
 Set the RX antenna for the given channel. More...
UHD_API uhd_error uhd_usrp_get_rx_antenna (uhd_usrp_handle h, size_t chan, char *ant_out, size_t strbuffer_len)
 Get the RX antenna for the given channel. More...
UHD_API uhd_error uhd_usrp_get_rx_antennas (uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *antennas_out)
 Get a list of RX antennas associated with the given channels. More...
UHD_API uhd_error uhd_usrp_get_rx_sensor_names (uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *sensor_names_out)
 Get a list of RX sensors associated with the given channels. More...
UHD_API uhd_error uhd_usrp_set_rx_bandwidth (uhd_usrp_handle h, double bandwidth, size_t chan)
 Set the bandwidth for the given channel's RX frontend. More...
UHD_API uhd_error uhd_usrp_get_rx_bandwidth (uhd_usrp_handle h, size_t chan, double *bandwidth_out)
 Get the bandwidth for the given channel's RX frontend. More...
UHD_API uhd_error uhd_usrp_get_rx_bandwidth_range (uhd_usrp_handle h, size_t chan, uhd_meta_range_handle bandwidth_range_out)
 Get all possible bandwidth ranges for the given channel's RX frontend. More...
UHD_API uhd_error uhd_usrp_get_rx_sensor (uhd_usrp_handle h, const char *name, size_t chan, uhd_sensor_value_handle *sensor_value_out)
 Get the value for the given RX sensor. More...
UHD_API uhd_error uhd_usrp_set_rx_dc_offset_enabled (uhd_usrp_handle h, bool enb, size_t chan)
 Enable or disable RX DC offset correction for the given channel. More...
UHD_API uhd_error uhd_usrp_set_rx_iq_balance_enabled (uhd_usrp_handle h, bool enb, size_t chan)
 Enable or disable RX IQ imbalance correction for the given channel. More...
UHD_API uhd_error uhd_usrp_set_tx_subdev_spec (uhd_usrp_handle h, uhd_subdev_spec_handle subdev_spec, size_t mboard)
 Map the given device's TX frontend to a channel. More...
UHD_API uhd_error uhd_usrp_get_tx_subdev_spec (uhd_usrp_handle h, size_t mboard, uhd_subdev_spec_handle subdev_spec_out)
 Get the TX frontend specification for the given device. More...
UHD_API uhd_error uhd_usrp_get_tx_num_channels (uhd_usrp_handle h, size_t *num_channels_out)
 Get the number of TX channels for the given handle. More...
UHD_API uhd_error uhd_usrp_get_tx_subdev_name (uhd_usrp_handle h, size_t chan, char *tx_subdev_name_out, size_t strbuffer_len)
UHD_API uhd_error uhd_usrp_set_tx_rate (uhd_usrp_handle h, double rate, size_t chan)
UHD_API uhd_error uhd_usrp_get_tx_rate (uhd_usrp_handle h, size_t chan, double *rate_out)
UHD_API uhd_error uhd_usrp_get_tx_rates (uhd_usrp_handle h, size_t chan, uhd_meta_range_handle rates_out)
UHD_API uhd_error uhd_usrp_set_tx_freq (uhd_usrp_handle h, uhd_tune_request_t *tune_request, size_t chan, uhd_tune_result_t *tune_result)
 Set the given channel's center TX frequency. More...
UHD_API uhd_error uhd_usrp_get_tx_freq (uhd_usrp_handle h, size_t chan, double *freq_out)
 Get the given channel's center TX frequency. More...
UHD_API uhd_error uhd_usrp_get_tx_freq_range (uhd_usrp_handle h, size_t chan, uhd_meta_range_handle freq_range_out)
UHD_API uhd_error uhd_usrp_get_fe_tx_freq_range (uhd_usrp_handle h, size_t chan, uhd_meta_range_handle freq_range_out)
 Get all possible RF frequency ranges for the given channel's TX RF frontend. More...
UHD_API uhd_error uhd_usrp_get_tx_lo_names (uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *tx_lo_names_out)
UHD_API uhd_error uhd_usrp_set_tx_lo_source (uhd_usrp_handle h, const char *src, const char *name, size_t chan)
UHD_API uhd_error uhd_usrp_get_tx_lo_source (uhd_usrp_handle h, const char *name, size_t chan, char *tx_lo_source_out, size_t strbuffer_len)
UHD_API uhd_error uhd_usrp_get_tx_lo_sources (uhd_usrp_handle h, const char *name, size_t chan, uhd_string_vector_handle *tx_lo_sources_out)
UHD_API uhd_error uhd_usrp_set_tx_lo_export_enabled (uhd_usrp_handle h, bool enabled, const char *name, size_t chan)
UHD_API uhd_error uhd_usrp_get_tx_lo_export_enabled (uhd_usrp_handle h, const char *name, size_t chan, bool *result_out)
UHD_API uhd_error uhd_usrp_set_tx_lo_freq (uhd_usrp_handle h, double freq, const char *name, size_t chan, double *coerced_freq_out)
 Set the Tx LO frequency. More...
UHD_API uhd_error uhd_usrp_get_tx_lo_freq (uhd_usrp_handle h, const char *name, size_t chan, double *tx_lo_freq_out)
 Get the current Tx LO frequency. More...
UHD_API uhd_error uhd_usrp_set_tx_gain (uhd_usrp_handle h, double gain, size_t chan, const char *gain_name)
 Set the TX gain for the given channel and name. More...
UHD_API uhd_error uhd_usrp_set_normalized_tx_gain (uhd_usrp_handle h, double gain, size_t chan)
 Set the normalized TX gain [0.0, 1.0] for the given channel. More...
UHD_API uhd_error uhd_usrp_get_tx_gain_range (uhd_usrp_handle h, const char *name, size_t chan, uhd_meta_range_handle gain_range_out)
UHD_API uhd_error uhd_usrp_get_tx_gain (uhd_usrp_handle h, size_t chan, const char *gain_name, double *gain_out)
UHD_API uhd_error uhd_usrp_get_normalized_tx_gain (uhd_usrp_handle h, size_t chan, double *gain_out)
 Get the given channel's normalized TX gain [0.0, 1.0]. More...
UHD_API uhd_error uhd_usrp_get_tx_gain_names (uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *gain_names_out)
 Get a list of TX gain names for the given channel. More...
UHD_API uhd_error uhd_usrp_set_tx_antenna (uhd_usrp_handle h, const char *ant, size_t chan)
 Set the TX antenna for the given channel. More...
UHD_API uhd_error uhd_usrp_get_tx_antenna (uhd_usrp_handle h, size_t chan, char *ant_out, size_t strbuffer_len)
 Get the TX antenna for the given channel. More...
UHD_API uhd_error uhd_usrp_get_tx_antennas (uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *antennas_out)
 Get a list of tx antennas associated with the given channels. More...
UHD_API uhd_error uhd_usrp_set_tx_bandwidth (uhd_usrp_handle h, double bandwidth, size_t chan)
 Set the bandwidth for the given channel's TX frontend. More...
UHD_API uhd_error uhd_usrp_get_tx_bandwidth (uhd_usrp_handle h, size_t chan, double *bandwidth_out)
 Get the bandwidth for the given channel's TX frontend. More...
UHD_API uhd_error uhd_usrp_get_tx_bandwidth_range (uhd_usrp_handle h, size_t chan, uhd_meta_range_handle bandwidth_range_out)
 Get all possible bandwidth ranges for the given channel's TX frontend. More...
UHD_API uhd_error uhd_usrp_get_tx_sensor (uhd_usrp_handle h, const char *name, size_t chan, uhd_sensor_value_handle *sensor_value_out)
 Get the value for the given TX sensor. More...
UHD_API uhd_error uhd_usrp_get_tx_sensor_names (uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *sensor_names_out)
 Get a list of TX sensors associated with the given channels. More...
UHD_API uhd_error uhd_usrp_get_gpio_banks (uhd_usrp_handle h, size_t mboard, uhd_string_vector_handle *gpio_banks_out)
 Get a list of GPIO banks associated with the given channels. More...
UHD_API uhd_error uhd_usrp_set_gpio_attr (uhd_usrp_handle h, const char *bank, const char *attr, uint32_t value, uint32_t mask, size_t mboard)
 Set a GPIO attribute for a given GPIO bank. More...
UHD_API uhd_error uhd_usrp_get_gpio_attr (uhd_usrp_handle h, const char *bank, const char *attr, size_t mboard, uint32_t *attr_out)
 Get a GPIO attribute on a particular GPIO bank. More...
Typedef Documentation
◆ uhd_rx_streamer_handle
typedef struct uhd_rx_streamer* uhd_rx_streamer_handle
See uhd::rx_streamer for more details.
◆ uhd_tx_streamer_handle
typedef struct uhd_tx_streamer* uhd_tx_streamer_handle
See uhd::tx_streamer for more details.
◆ uhd_usrp_handle
typedef struct uhd_usrp* uhd_usrp_handle
◆ uhd_stream_mode_t
See uhd::stream_cmd_t for more details.
Enumerator
Stream samples indefinitely.
End continuous streaming.
Stream some number of samples and finish.
Stream some number of samples but expect more.
Function Documentation
◆ uhd_rx_streamer_free()
UHD_API uhd_error uhd_rx_streamer_free ( uhd_rx_streamer_handle h)
NOTE: Using a streamer after passing it into this function will result in a segmentation fault.
◆ uhd_rx_streamer_issue_stream_cmd()
UHD_API uhd_error uhd_rx_streamer_issue_stream_cmd ( uhd_rx_streamer_handle  h,
const uhd_stream_cmd_t stream_cmd
See uhd::rx_streamer::issue_stream_cmd() for more details.
◆ uhd_rx_streamer_last_error()
UHD_API uhd_error uhd_rx_streamer_last_error ( uhd_rx_streamer_handle  h,
char *  error_out,
NOTE: This will overwrite the string currently in error_out before using it to return its error.
hRX streamer handle
error_outstring buffer in which to place error
strbuffer_lenbuffer size
◆ uhd_rx_streamer_make()
UHD_API uhd_error uhd_rx_streamer_make ( uhd_rx_streamer_handle h)
NOTE: Using this streamer before passing it into uhd_usrp_get_rx_stream() will result in undefined behavior.
◆ uhd_rx_streamer_max_num_samps()
UHD_API uhd_error uhd_rx_streamer_max_num_samps ( uhd_rx_streamer_handle  h,
size_t *  max_num_samps_out
◆ uhd_rx_streamer_num_channels()
UHD_API uhd_error uhd_rx_streamer_num_channels ( uhd_rx_streamer_handle  h,
size_t *  num_channels_out
◆ uhd_rx_streamer_recv()
UHD_API uhd_error uhd_rx_streamer_recv ( uhd_rx_streamer_handle  h,
void **  buffs,
uhd_rx_metadata_handle md,
double  timeout,
bool  one_packet,
size_t *  items_recvd
See uhd::rx_streamer::recv() for more details.
hRX streamer handle
buffspointer to buffers in which to receive samples
samps_per_buffmax number of samples per buffer
mdhandle to RX metadata in which to receive results
timeouttimeout in seconds to wait for a packet
one_packetsend a single packet
items_recvdpointer to output variable for number of samples received
◆ uhd_tx_streamer_free()
UHD_API uhd_error uhd_tx_streamer_free ( uhd_tx_streamer_handle h)
◆ uhd_tx_streamer_last_error()
UHD_API uhd_error uhd_tx_streamer_last_error ( uhd_tx_streamer_handle  h,
char *  error_out,
hTX streamer handle
◆ uhd_tx_streamer_make()
UHD_API uhd_error uhd_tx_streamer_make ( uhd_tx_streamer_handle h)
NOTE: Using this streamer before passing it into uhd_usrp_get_tx_stream() will result in undefined behavior.
◆ uhd_tx_streamer_max_num_samps()
UHD_API uhd_error uhd_tx_streamer_max_num_samps ( uhd_tx_streamer_handle  h,
◆ uhd_tx_streamer_num_channels()
UHD_API uhd_error uhd_tx_streamer_num_channels ( uhd_tx_streamer_handle  h,
◆ uhd_tx_streamer_recv_async_msg()
UHD_API uhd_error uhd_tx_streamer_recv_async_msg ( uhd_tx_streamer_handle  h,
uhd_async_metadata_handle md,
double  timeout,
bool *  valid
See uhd::tx_streamer::recv_async_msg() for more details.
◆ uhd_tx_streamer_send()
UHD_API uhd_error uhd_tx_streamer_send ( uhd_tx_streamer_handle  h,
const void **  buffs,
uhd_tx_metadata_handle md,
double  timeout,
size_t *  items_sent
See uhd::tx_streamer::send() for more details.
hTX streamer handle
buffspointer to buffers containing samples to send
mdhandle to TX metadata
items_sentpointer to output variable for number of samples send
◆ UHD_UNUSED()
UHD_UNUSED ( static const char *  UHD_USRP_ALL_LOS)
◆ uhd_usrp_clear_command_time()
UHD_API uhd_error uhd_usrp_clear_command_time ( uhd_usrp_handle  h,
size_t  mboard
◆ uhd_usrp_find()
UHD_API uhd_error uhd_usrp_find ( const char *  args,
uhd_string_vector_handle strings_out
See uhd::device::find() for more details.
◆ uhd_usrp_free()
UHD_API uhd_error uhd_usrp_free ( uhd_usrp_handle h)
NOTE: Attempting to use a USRP handle after passing it into this function will result in a segmentation fault.
◆ uhd_usrp_get_clock_source()
UHD_API uhd_error uhd_usrp_get_clock_source ( uhd_usrp_handle  h,
size_t  mboard,
char *  clock_source_out,
See uhd::usrp::multi_usrp::get_clock_source() for more details.
◆ uhd_usrp_get_clock_sources()
UHD_API uhd_error uhd_usrp_get_clock_sources ( uhd_usrp_handle  h,
size_t  mboard,
uhd_string_vector_handle clock_sources_out
◆ uhd_usrp_get_dboard_eeprom()
UHD_API uhd_error uhd_usrp_get_dboard_eeprom ( uhd_usrp_handle  h,
const char *  unit,
const char *  slot,
size_t  mboard
◆ uhd_usrp_get_fe_rx_freq_range()
UHD_API uhd_error uhd_usrp_get_fe_rx_freq_range ( uhd_usrp_handle  h,
size_t  chan,
◆ uhd_usrp_get_fe_tx_freq_range()
UHD_API uhd_error uhd_usrp_get_fe_tx_freq_range ( uhd_usrp_handle  h,
size_t  chan,
◆ uhd_usrp_get_gpio_attr()
UHD_API uhd_error uhd_usrp_get_gpio_attr ( uhd_usrp_handle  h,
const char *  bank,
const char *  attr,
size_t  mboard,
uint32_t *  attr_out
See uhd::usrp::multi_usrp::get_gpio_attr() for more details.
◆ uhd_usrp_get_gpio_banks()
UHD_API uhd_error uhd_usrp_get_gpio_banks ( uhd_usrp_handle  h,
size_t  mboard,
uhd_string_vector_handle gpio_banks_out
◆ uhd_usrp_get_master_clock_rate()
UHD_API uhd_error uhd_usrp_get_master_clock_rate ( uhd_usrp_handle  h,
size_t  mboard,
double *  clock_rate_out
See uhd::usrp::multi_usrp::get_master_clock_rate() for more details.
◆ uhd_usrp_get_mboard_eeprom()
UHD_API uhd_error uhd_usrp_get_mboard_eeprom ( uhd_usrp_handle  h,
size_t  mboard
◆ uhd_usrp_get_mboard_name()
UHD_API uhd_error uhd_usrp_get_mboard_name ( uhd_usrp_handle  h,
size_t  mboard,
char *  mboard_name_out,
See uhd::usrp::multi_usrp::get_mboard_name() for more details.
◆ uhd_usrp_get_mboard_sensor()
UHD_API uhd_error uhd_usrp_get_mboard_sensor ( uhd_usrp_handle  h,
const char *  name,
size_t  mboard,
uhd_sensor_value_handle sensor_value_out
◆ uhd_usrp_get_mboard_sensor_names()
UHD_API uhd_error uhd_usrp_get_mboard_sensor_names ( uhd_usrp_handle  h,
size_t  mboard,
uhd_string_vector_handle mboard_sensor_names_out
◆ uhd_usrp_get_normalized_rx_gain()
UHD_API uhd_error uhd_usrp_get_normalized_rx_gain ( uhd_usrp_handle  h,
size_t  chan,
double *  gain_out
See uhd::usrp::multi_usrp::get_normalized_rx_gain() for more details.
◆ uhd_usrp_get_normalized_tx_gain()
UHD_API uhd_error uhd_usrp_get_normalized_tx_gain ( uhd_usrp_handle  h,
size_t  chan,
double *  gain_out
See uhd::usrp::multi_usrp::get_normalized_tx_gain() for more details.
◆ uhd_usrp_get_num_mboards()
UHD_API uhd_error uhd_usrp_get_num_mboards ( uhd_usrp_handle  h,
size_t *  num_mboards_out
◆ uhd_usrp_get_pp_string()
UHD_API uhd_error uhd_usrp_get_pp_string ( uhd_usrp_handle  h,
char *  pp_string_out,
See uhd::usrp::multi_usrp::get_pp_string() for more details.
◆ uhd_usrp_get_rx_antenna()
UHD_API uhd_error uhd_usrp_get_rx_antenna ( uhd_usrp_handle  h,
size_t  chan,
char *  ant_out,
◆ uhd_usrp_get_rx_antennas()
UHD_API uhd_error uhd_usrp_get_rx_antennas ( uhd_usrp_handle  h,
size_t  chan,
uhd_string_vector_handle antennas_out
◆ uhd_usrp_get_rx_bandwidth()
UHD_API uhd_error uhd_usrp_get_rx_bandwidth ( uhd_usrp_handle  h,
size_t  chan,
double *  bandwidth_out
◆ uhd_usrp_get_rx_bandwidth_range()
UHD_API uhd_error uhd_usrp_get_rx_bandwidth_range ( uhd_usrp_handle  h,
size_t  chan,
◆ uhd_usrp_get_rx_freq()
UHD_API uhd_error uhd_usrp_get_rx_freq ( uhd_usrp_handle  h,
size_t  chan,
double *  freq_out
◆ uhd_usrp_get_rx_freq_range()
UHD_API uhd_error uhd_usrp_get_rx_freq_range ( uhd_usrp_handle  h,
size_t  chan,
See uhd::usrp::multi_usrp::get_rx_freq_range() for more details.
◆ uhd_usrp_get_rx_gain()
UHD_API uhd_error uhd_usrp_get_rx_gain ( uhd_usrp_handle  h,
size_t  chan,
const char *  gain_name,
double *  gain_out
◆ uhd_usrp_get_rx_gain_names()
UHD_API uhd_error uhd_usrp_get_rx_gain_names ( uhd_usrp_handle  h,
size_t  chan,
uhd_string_vector_handle gain_names_out
◆ uhd_usrp_get_rx_gain_range()
UHD_API uhd_error uhd_usrp_get_rx_gain_range ( uhd_usrp_handle  h,
const char *  name,
size_t  chan,
◆ uhd_usrp_get_rx_info()
UHD_API uhd_error uhd_usrp_get_rx_info ( uhd_usrp_handle  h,
size_t  chan,
uhd_usrp_rx_info_t info_out
NOTE: After calling this function, uhd_usrp_rx_info_free() must be called on info_out.
◆ uhd_usrp_get_rx_lo_export_enabled()
UHD_API uhd_error uhd_usrp_get_rx_lo_export_enabled ( uhd_usrp_handle  h,
const char *  name,
size_t  chan,
bool *  result_out
◆ uhd_usrp_get_rx_lo_freq()
UHD_API uhd_error uhd_usrp_get_rx_lo_freq ( uhd_usrp_handle  h,
const char *  name,
size_t  chan,
double *  rx_lo_freq_out
◆ uhd_usrp_get_rx_lo_names()
UHD_API uhd_error uhd_usrp_get_rx_lo_names ( uhd_usrp_handle  h,
size_t  chan,
uhd_string_vector_handle rx_lo_names_out
◆ uhd_usrp_get_rx_lo_source()
UHD_API uhd_error uhd_usrp_get_rx_lo_source ( uhd_usrp_handle  h,
const char *  name,
size_t  chan,
char *  rx_lo_source_out,
◆ uhd_usrp_get_rx_lo_sources()
UHD_API uhd_error uhd_usrp_get_rx_lo_sources ( uhd_usrp_handle  h,
const char *  name,
size_t  chan,
uhd_string_vector_handle rx_lo_sources_out
◆ uhd_usrp_get_rx_num_channels()
UHD_API uhd_error uhd_usrp_get_rx_num_channels ( uhd_usrp_handle  h,
◆ uhd_usrp_get_rx_rate()
UHD_API uhd_error uhd_usrp_get_rx_rate ( uhd_usrp_handle  h,
size_t  chan,
double *  rate_out
◆ uhd_usrp_get_rx_rates()
UHD_API uhd_error uhd_usrp_get_rx_rates ( uhd_usrp_handle  h,
size_t  chan,
◆ uhd_usrp_get_rx_sensor()
UHD_API uhd_error uhd_usrp_get_rx_sensor ( uhd_usrp_handle  h,
const char *  name,
size_t  chan,
◆ uhd_usrp_get_rx_sensor_names()
UHD_API uhd_error uhd_usrp_get_rx_sensor_names ( uhd_usrp_handle  h,
size_t  chan,
uhd_string_vector_handle sensor_names_out
◆ uhd_usrp_get_rx_stream()
UHD_API uhd_error uhd_usrp_get_rx_stream ( uhd_usrp_handle  h,
uhd_stream_args_t stream_args,
◆ uhd_usrp_get_rx_subdev_name()
UHD_API uhd_error uhd_usrp_get_rx_subdev_name ( uhd_usrp_handle  h,
size_t  chan,
char *  rx_subdev_name_out,
◆ uhd_usrp_get_rx_subdev_spec()
UHD_API uhd_error uhd_usrp_get_rx_subdev_spec ( uhd_usrp_handle  h,
size_t  mboard,
◆ uhd_usrp_get_time_last_pps()
UHD_API uhd_error uhd_usrp_get_time_last_pps ( uhd_usrp_handle  h,
size_t  mboard,
int64_t *  full_secs_out,
double *  frac_secs_out
See uhd::usrp::multi_usrp::get_time_last_pps() for more details.
◆ uhd_usrp_get_time_now()
UHD_API uhd_error uhd_usrp_get_time_now ( uhd_usrp_handle  h,
size_t  mboard,
See uhd::usrp::multi_usrp::get_time_now() for more details.
◆ uhd_usrp_get_time_source()
UHD_API uhd_error uhd_usrp_get_time_source ( uhd_usrp_handle  h,
size_t  mboard,
char *  time_source_out,
See uhd::usrp::multi_usrp::get_time_source() for more details.
◆ uhd_usrp_get_time_sources()
UHD_API uhd_error uhd_usrp_get_time_sources ( uhd_usrp_handle  h,
size_t  mboard,
uhd_string_vector_handle time_sources_out
◆ uhd_usrp_get_time_synchronized()
UHD_API uhd_error uhd_usrp_get_time_synchronized ( uhd_usrp_handle  h,
bool *  result_out
◆ uhd_usrp_get_tx_antenna()
UHD_API uhd_error uhd_usrp_get_tx_antenna ( uhd_usrp_handle  h,
size_t  chan,
char *  ant_out,
◆ uhd_usrp_get_tx_antennas()
UHD_API uhd_error uhd_usrp_get_tx_antennas ( uhd_usrp_handle  h,
size_t  chan,
◆ uhd_usrp_get_tx_bandwidth()
UHD_API uhd_error uhd_usrp_get_tx_bandwidth ( uhd_usrp_handle  h,
size_t  chan,
◆ uhd_usrp_get_tx_bandwidth_range()
UHD_API uhd_error uhd_usrp_get_tx_bandwidth_range ( uhd_usrp_handle  h,
size_t  chan,
◆ uhd_usrp_get_tx_freq()
UHD_API uhd_error uhd_usrp_get_tx_freq ( uhd_usrp_handle  h,
size_t  chan,
double *  freq_out
◆ uhd_usrp_get_tx_freq_range()
UHD_API uhd_error uhd_usrp_get_tx_freq_range ( uhd_usrp_handle  h,
size_t  chan,
◆ uhd_usrp_get_tx_gain()
UHD_API uhd_error uhd_usrp_get_tx_gain ( uhd_usrp_handle  h,
size_t  chan,
double *  gain_out
◆ uhd_usrp_get_tx_gain_names()
UHD_API uhd_error uhd_usrp_get_tx_gain_names ( uhd_usrp_handle  h,
size_t  chan,
◆ uhd_usrp_get_tx_gain_range()
UHD_API uhd_error uhd_usrp_get_tx_gain_range ( uhd_usrp_handle  h,
const char *  name,
size_t  chan,
◆ uhd_usrp_get_tx_info()
UHD_API uhd_error uhd_usrp_get_tx_info ( uhd_usrp_handle  h,
size_t  chan,
uhd_usrp_tx_info_t info_out
NOTE: After calling this function, uhd_usrp_tx_info_free() must be called on info_out.
◆ uhd_usrp_get_tx_lo_export_enabled()
UHD_API uhd_error uhd_usrp_get_tx_lo_export_enabled ( uhd_usrp_handle  h,
const char *  name,
size_t  chan,
bool *  result_out
◆ uhd_usrp_get_tx_lo_freq()
UHD_API uhd_error uhd_usrp_get_tx_lo_freq ( uhd_usrp_handle  h,
const char *  name,
size_t  chan,
double *  tx_lo_freq_out
◆ uhd_usrp_get_tx_lo_names()
UHD_API uhd_error uhd_usrp_get_tx_lo_names ( uhd_usrp_handle  h,
size_t  chan,
uhd_string_vector_handle tx_lo_names_out
◆ uhd_usrp_get_tx_lo_source()
UHD_API uhd_error uhd_usrp_get_tx_lo_source ( uhd_usrp_handle  h,
const char *  name,
size_t  chan,
char *  tx_lo_source_out,
◆ uhd_usrp_get_tx_lo_sources()
UHD_API uhd_error uhd_usrp_get_tx_lo_sources ( uhd_usrp_handle  h,
const char *  name,
size_t  chan,
uhd_string_vector_handle tx_lo_sources_out
◆ uhd_usrp_get_tx_num_channels()
UHD_API uhd_error uhd_usrp_get_tx_num_channels ( uhd_usrp_handle  h,
◆ uhd_usrp_get_tx_rate()
UHD_API uhd_error uhd_usrp_get_tx_rate ( uhd_usrp_handle  h,
size_t  chan,
double *  rate_out
◆ uhd_usrp_get_tx_rates()
UHD_API uhd_error uhd_usrp_get_tx_rates ( uhd_usrp_handle  h,
size_t  chan,
◆ uhd_usrp_get_tx_sensor()
UHD_API uhd_error uhd_usrp_get_tx_sensor ( uhd_usrp_handle  h,
const char *  name,
size_t  chan,
◆ uhd_usrp_get_tx_sensor_names()
UHD_API uhd_error uhd_usrp_get_tx_sensor_names ( uhd_usrp_handle  h,
size_t  chan,
◆ uhd_usrp_get_tx_stream()
UHD_API uhd_error uhd_usrp_get_tx_stream ( uhd_usrp_handle  h,
◆ uhd_usrp_get_tx_subdev_name()
UHD_API uhd_error uhd_usrp_get_tx_subdev_name ( uhd_usrp_handle  h,
size_t  chan,
char *  tx_subdev_name_out,
◆ uhd_usrp_get_tx_subdev_spec()
UHD_API uhd_error uhd_usrp_get_tx_subdev_spec ( uhd_usrp_handle  h,
size_t  mboard,
◆ uhd_usrp_last_error()
UHD_API uhd_error uhd_usrp_last_error ( uhd_usrp_handle  h,
char *  error_out,
◆ uhd_usrp_make()
UHD_API uhd_error uhd_usrp_make ( uhd_usrp_handle h,
const char *  args
hthe handle
argsdevice args (e.g. "type=x300")
◆ uhd_usrp_set_clock_source()
UHD_API uhd_error uhd_usrp_set_clock_source ( uhd_usrp_handle  h,
const char *  clock_source,
size_t  mboard
See uhd::usrp::multi_usrp::set_clock_source() for more details.
◆ uhd_usrp_set_clock_source_out()
UHD_API uhd_error uhd_usrp_set_clock_source_out ( uhd_usrp_handle  h,
bool  enb,
size_t  mboard
See uhd::usrp::set_clock_source_out() for more details.
◆ uhd_usrp_set_command_time()
UHD_API uhd_error uhd_usrp_set_command_time ( uhd_usrp_handle  h,
int64_t  full_secs,
double  frac_secs,
size_t  mboard
See uhd::usrp::multi_usrp::set_command_time() for more details.
◆ uhd_usrp_set_dboard_eeprom()
UHD_API uhd_error uhd_usrp_set_dboard_eeprom ( uhd_usrp_handle  h,
const char *  unit,
const char *  slot,
size_t  mboard
◆ uhd_usrp_set_gpio_attr()
UHD_API uhd_error uhd_usrp_set_gpio_attr ( uhd_usrp_handle  h,
const char *  bank,
const char *  attr,
uint32_t  value,
uint32_t  mask,
size_t  mboard
See uhd::usrp::multi_usrp::set_gpio_attr() for more details.
◆ uhd_usrp_set_master_clock_rate()
UHD_API uhd_error uhd_usrp_set_master_clock_rate ( uhd_usrp_handle  h,
double  rate,
size_t  mboard
See uhd::usrp::multi_usrp::set_master_clock_rate() for more details.
◆ uhd_usrp_set_mboard_eeprom()
UHD_API uhd_error uhd_usrp_set_mboard_eeprom ( uhd_usrp_handle  h,
size_t  mboard
◆ uhd_usrp_set_normalized_rx_gain()
UHD_API uhd_error uhd_usrp_set_normalized_rx_gain ( uhd_usrp_handle  h,
double  gain,
size_t  chan
See uhd::usrp::multi_usrp::set_normalized_rx_gain() for more details.
◆ uhd_usrp_set_normalized_tx_gain()
UHD_API uhd_error uhd_usrp_set_normalized_tx_gain ( uhd_usrp_handle  h,
double  gain,
size_t  chan
See uhd::usrp::multi_usrp::set_normalized_tx_gain() for more details.
◆ uhd_usrp_set_rx_agc()
UHD_API uhd_error uhd_usrp_set_rx_agc ( uhd_usrp_handle  h,
bool  enable,
size_t  chan
See uhd::usrp::multi_usrp::set_rx_agc() for more details.
◆ uhd_usrp_set_rx_antenna()
UHD_API uhd_error uhd_usrp_set_rx_antenna ( uhd_usrp_handle  h,
const char *  ant,
size_t  chan
◆ uhd_usrp_set_rx_bandwidth()
UHD_API uhd_error uhd_usrp_set_rx_bandwidth ( uhd_usrp_handle  h,
double  bandwidth,
size_t  chan
◆ uhd_usrp_set_rx_dc_offset_enabled()
UHD_API uhd_error uhd_usrp_set_rx_dc_offset_enabled ( uhd_usrp_handle  h,
bool  enb,
size_t  chan
See uhd::usrp::multi_usrp::set_rx_dc_offset() for more details.
◆ uhd_usrp_set_rx_freq()
UHD_API uhd_error uhd_usrp_set_rx_freq ( uhd_usrp_handle  h,
uhd_tune_request_t tune_request,
size_t  chan,
uhd_tune_result_t tune_result
◆ uhd_usrp_set_rx_gain()
UHD_API uhd_error uhd_usrp_set_rx_gain ( uhd_usrp_handle  h,
double  gain,
size_t  chan,
◆ uhd_usrp_set_rx_iq_balance_enabled()
UHD_API uhd_error uhd_usrp_set_rx_iq_balance_enabled ( uhd_usrp_handle  h,
bool  enb,
size_t  chan
◆ uhd_usrp_set_rx_lo_export_enabled()
UHD_API uhd_error uhd_usrp_set_rx_lo_export_enabled ( uhd_usrp_handle  h,
bool  enabled,
const char *  name,
size_t  chan
◆ uhd_usrp_set_rx_lo_freq()
UHD_API uhd_error uhd_usrp_set_rx_lo_freq ( uhd_usrp_handle  h,
double  freq,
const char *  name,
size_t  chan,
double *  coerced_freq_out
◆ uhd_usrp_set_rx_lo_source()
UHD_API uhd_error uhd_usrp_set_rx_lo_source ( uhd_usrp_handle  h,
const char *  src,
const char *  name,
size_t  chan
◆ uhd_usrp_set_rx_rate()
UHD_API uhd_error uhd_usrp_set_rx_rate ( uhd_usrp_handle  h,
double  rate,
size_t  chan
◆ uhd_usrp_set_rx_subdev_spec()
UHD_API uhd_error uhd_usrp_set_rx_subdev_spec ( uhd_usrp_handle  h,
size_t  mboard
See uhd::usrp::multi_usrp::set_rx_subdev_spec() for more details.
◆ uhd_usrp_set_time_next_pps()
UHD_API uhd_error uhd_usrp_set_time_next_pps ( uhd_usrp_handle  h,
int64_t  full_secs,
double  frac_secs,
size_t  mboard
See uhd::usrp::multi_usrp::set_time_next_pps() for more details.
◆ uhd_usrp_set_time_now()
UHD_API uhd_error uhd_usrp_set_time_now ( uhd_usrp_handle  h,
int64_t  full_secs,
double  frac_secs,
size_t  mboard
See uhd::usrp::multi_usrp::set_time_now() for more details.
◆ uhd_usrp_set_time_source()
UHD_API uhd_error uhd_usrp_set_time_source ( uhd_usrp_handle  h,
const char *  time_source,
size_t  mboard
See uhd::usrp::multi_usrp::set_time_source() for more details.
◆ uhd_usrp_set_time_source_out()
UHD_API uhd_error uhd_usrp_set_time_source_out ( uhd_usrp_handle  h,
bool  enb,
size_t  mboard
See uhd::usrp::set_time_source_out() for more details.
◆ uhd_usrp_set_time_unknown_pps()
UHD_API uhd_error uhd_usrp_set_time_unknown_pps ( uhd_usrp_handle  h,
int64_t  full_secs,
double  frac_secs
See uhd::usrp::multi_usrp::set_time_unknown_pps() for more details.
◆ uhd_usrp_set_tx_antenna()
UHD_API uhd_error uhd_usrp_set_tx_antenna ( uhd_usrp_handle  h,
const char *  ant,
size_t  chan
◆ uhd_usrp_set_tx_bandwidth()
UHD_API uhd_error uhd_usrp_set_tx_bandwidth ( uhd_usrp_handle  h,
double  bandwidth,
size_t  chan
◆ uhd_usrp_set_tx_freq()
UHD_API uhd_error uhd_usrp_set_tx_freq ( uhd_usrp_handle  h,
size_t  chan,
◆ uhd_usrp_set_tx_gain()
UHD_API uhd_error uhd_usrp_set_tx_gain ( uhd_usrp_handle  h,
double  gain,
size_t  chan,
◆ uhd_usrp_set_tx_lo_export_enabled()
UHD_API uhd_error uhd_usrp_set_tx_lo_export_enabled ( uhd_usrp_handle  h,
bool  enabled,
const char *  name,
size_t  chan
◆ uhd_usrp_set_tx_lo_freq()
UHD_API uhd_error uhd_usrp_set_tx_lo_freq ( uhd_usrp_handle  h,
double  freq,
const char *  name,
size_t  chan,
◆ uhd_usrp_set_tx_lo_source()
UHD_API uhd_error uhd_usrp_set_tx_lo_source ( uhd_usrp_handle  h,
const char *  src,
const char *  name,
size_t  chan
◆ uhd_usrp_set_tx_rate()
UHD_API uhd_error uhd_usrp_set_tx_rate ( uhd_usrp_handle  h,
double  rate,
size_t  chan
◆ uhd_usrp_set_tx_subdev_spec()
UHD_API uhd_error uhd_usrp_set_tx_subdev_spec ( uhd_usrp_handle  h,
size_t  mboard
See uhd::usrp::multi_usrp::set_tx_subdev_spec() for more details.
◆ uhd_usrp_set_user_register()
UHD_API uhd_error uhd_usrp_set_user_register ( uhd_usrp_handle  h,
uint8_t  addr,
uint32_t  data,
size_t  mboard
See uhd::usrp::multi_usrp::set_user_register() for more details.
