#include <uhd/rfnoc/moving_average_block_control.hpp>
| virtual void | set_sum_len (const uint8_t sum_len)=0 |
| virtual uint8_t | get_sum_len () const =0 |
| virtual void | set_divisor (const uint32_t divisor)=0 |
| virtual uint32_t | get_divisor () const =0 |
| static const uint32_t | REG_SUM_LEN_ADDR |
| static const uint32_t | REG_DIVISOR_ADDR |
Moving Average Block Control Class
The Moving Average block is an RFNoC block that computes the running average of an input data stream. The output is the sum of the last SUM_LEN samples divided by DIVISOR which may or may not be equal to SUM_LEN. For example, if SUM_LEN is set to 10 and DIVISOR is set to 10, the block will return a sample that is the average of the last 10 samples. If SUM_LEN is set to 10 and DIVISOR is set to 1, the block will return a sample that is equal to the sum of the last 10 samples.
Return the current divisor
Return the current sum length
Set the divisor
| divisor | The amount to divide the sum by |
Set the Sum Length
Changing the sum length will clear the history and reset the accumulated sum to 0.
| sum_len | The number of samples to sum |
