#include <uhd/rfnoc/vector_iir_block_control.hpp>
| virtual void | set_alpha (const double alpha, const size_t chan)=0 |
| virtual double | get_alpha (const size_t chan) const =0 |
| virtual void | set_beta (const double beta, const size_t chan)=0 |
| virtual double | get_beta (const size_t chan) const =0 |
| virtual void | set_delay (const uint16_t delay, const size_t chan)=0 |
| virtual uint16_t | get_delay (const size_t chan) const =0 |
| virtual uint16_t | get_max_delay (const size_t chan) const =0 |
| static const uint32_t | REG_BLOCK_SIZE |
| static const uint32_t | REG_DELAY_OFFSET |
| static const uint32_t | REG_ALPHA_OFFSET |
| static const uint32_t | REG_BETA_OFFSET |
Vector IIR Block Control Class
The Vector IIR Block is an RFNoC block that implements an infinite impulse filter with a variable length delay line. The transfer function is defined as follows:
beta
H(z) = ---------------------— 1 - alpha * z ^ -delay
where
Return the feedback tap value
Returns the feedback tap value for channel chan of the IIR filter.
| chan | The channel to retrieve the feedback tap value from |
Return the feedforward tap value
Returns the feedforward tap value for channel chan of the IIR filter.
| chan | The channel to retrieve the feedforward tap value from |
Return the feedback tap delay
Returns the feedback tap delay value in samples for channel chan of the IIR filter.
| chan | The channel to retrieve the feedback tap delay value from |
Return the maximum filter delay
Returns the maximum allowable filter delay value, in samples, for channel chan.
| chan | The channel to retrieve the maximum delay from |
Set the feedback tap value
Sets the feedback tap value for channel chan of the IIR filter.
| alpha | The feedback tap value for the filter |
| chan | The channel to apply the feedback tap value to |
Set the feedforward tap value
Sets the feedforward tap value for channel chan of the IIR filter.
| beta | The feedforward tap value for the filter |
| chan | The channel to apply the feedforward tap value to |
Set the feedback tap delay
Sets the feedback tap delay in samples for channel chan of the IIR filter. The delay value for the filter must be less than or equal to the maximum delay length supported by the filter.
| delay | The feedback tap delay of the filter in samples |
| chan | The channel to apply the feedback tap delay to |
