Namespaces | |
| namespace | vrt |
Classes | |
| class | bounded_buffer |
| class | bounded_buffer_detail |
| class | buffer_pool |
| class | frame_buff |
| struct | if_addrs_t |
| class | managed_buffer |
| Simple managed buffer with release interface.  More... | |
| class | managed_recv_buffer |
| class | managed_send_buffer |
| class | muxed_zero_copy_if |
| struct | tcp_zero_copy |
| class | udp_simple |
| class | udp_zero_copy |
| class | usb_control |
| class | usb_device_handle |
| class | usb_zero_copy |
| class | zero_copy_flow_ctrl |
| class | zero_copy_if |
| struct | zero_copy_xport_params |
Typedefs | |
| using | adapter_id_t = size_t |
| Host transport adapter ID.  More... | |
| typedef std::function< bool(managed_buffer::sptr buff)> | flow_ctrl_func |
Functions | |
| UHD_API std::vector< if_addrs_t > | get_if_addrs (void) |
| UHD_INLINE void | intrusive_ptr_add_ref (managed_buffer *p) |
| UHD_INLINE void | intrusive_ptr_release (managed_buffer *p) |
| using uhd::transport::adapter_id_t = typedef size_t |
| typedef std::function<bool(managed_buffer::sptr buff)> uhd::transport::flow_ctrl_func |
Flow control function.
| buff | buffer to be sent or receive buffer being released |
| UHD_API std::vector< if_addrs_t > uhd::transport::get_if_addrs | ( | void | ) |
Get a list of network interface addresses. The internal implementation is system-dependent.
| UHD_INLINE void uhd::transport::intrusive_ptr_add_ref | ( | managed_buffer * | p | ) |
| UHD_INLINE void uhd::transport::intrusive_ptr_release | ( | managed_buffer * | p | ) |
