For Windows users, copy the CMake file to Program Files, e.g. C:\Program Files\cmake-3.13.4-win32-x86. The CMake path, e.g. C:\Program Files\cmake-3.13.4-win32-x86\bin needs to be added to the environment variables.
The Boost binary installer must be selected to match the architecture of Windows being run.
The directory to which you extract libusb must not contain spaces. This is to say that C:\local\lib usb-1.0.22 will cause compile issues moving forward.
Windows x86-64 MSI Installer -> python-version.amd64.msi needs to be used.Install fundamental packages for Python: On Windows Terminal, navigate to Python scripts folder, e.g. C:\local\Python37\Scripts, and execute the following commands to install requests and numpy packages, respectively:
pip3 install requests pip3 install numpy pip3 install ruamel.yaml pip3 install setuptools
For curses package installation:
curses-2.2-cp37-cp37m-win_amd64.whl.pip3 install wheel
python3 -m pip3 install curses-2.2-cp37-cp37m-win_amd64.whl
Alternative method: You can use pip3 or easy_install to install Mako from PyPi. To install it using 'pip3' on Windows, navigate to Python scripts folder, e.g. C:\local\Python37\Scripts, and run the following command:
pip3 install mako
On Windows, install Cygwin from https://www.cygwin.com/ with Git support to checkout the repository or install msysGit from http://code.google.com/p/msysgit/downloads/list.
sudo apt-get install libboost-all-dev libusb-1.0-0-dev doxygen python3-docutils python3-mako python3-numpy python3-requests python3-ruamel.yaml python3-setuptools cmake build-essential
sudo yum -y install boost-devel libusb1-devel doxygen python3-docutils python3-mako python3-numpy python3-requests python3-ruamel-yaml python3-setuptools cmake make gcc gcc-c++
or
sudo dnf -y install boost-devel libusb1-devel doxygen python3-docutils python3-mako python3-numpy python3-requests python3-ruamel-yaml python3-setuptools cmake make gcc gcc-c++
The UHD source is stored in a git repository. To download it, follow these instructions:
Our source code repository contains of the following branches:
$ pybombs install uhd
cd <uhd-repo-path>/host mkdir build cd build cmake ../
-DCMAKE_INSTALL_PREFIX=<install-path>cmake -DLIB_SUFFIX=64Example usage:
Ubuntu 20.04 note: When building for Ubuntu 20.04, you may run into errors such as this during CMake's generation stage:
CMake Error in python/CMakeLists.txt: Imported target "Boost::chrono" includes non-existent path "/include" in its INTERFACE_INCLUDE_DIRECTORIES. Possible reasons include: The path was deleted, renamed, or moved to another location. An install or uninstall procedure did not complete successfully. The installation package was faulty and references files it does not provide.
These errors occur when CMake finds filesystem items by following the /bin symlink to /usr/bin and thus incorrectly calculating the root path for various directories needed by the build.
If you encounter this issue, ensure that /usr/bin appears before /bin in the PATH environment variable of the process executing CMake. Alternatively, you can pass the CMAKE_FIND_ROOT_PATH configuration variable to CMake with a value of /usr to point it to the right starting directory for filesystem item searches.
Example usage:
cmake -DCMAKE_FIND_ROOT_PATH=/usr ../
make make test # This step is optional sudo make install
sudo ldconfig
When compiling for ARM platforms, the assumption is made that NEON extensions are available if the arm_neon.h header is found. However, this might not be true, e.g., when cross-compiling for an arm7l target (e.g., the Odroid XU4) using a standard SDK. In this case, it's necessary to tell CMake to disable NEON extensions:
cmake -DNEON_SIMD_ENABLE=OFF [...]
<uhd-repo-path>/host.<uhd-repo-path>\host\build.Boost_INCLUDE_DIR should point to the PATH where the Boost .hpp files are, e.g. C:\local\boost_version\Boost_LIBRARY_DIR should point to the pre-built libraries, e.g. C:\local\boost_version\lib64-msvc-14.0)CMAKECMAKE_BUILD_TYPE: Release and change it to CMAKE_BUILD_TYPE: Debug.<uhd-repo-path>\host\build\ALL_BUILD.vcxproj in visual studio, generate the project. Watch the output console for errors.CMAKE_INSTALL_PREFIX where your user has write privileges, you must close Visual Studio, run it again with Administrator Privileges, and open ALL_BUILD.vcxproj.On Windows, CMake does not have the advantage of pkg-config, so we must manually tell CMake how to locate the LibUSB header and lib.
LIBUSB_INCLUDE_DIRS to the directory for libusb.h, e.g. C:\local\libusb-1.0.22\include\libusb-1.0.LIBUSB_LIBRARIES to the full path for libusb-1.0.lib, e.g. C:\local\libusb-1.0.22\MS64\dll\libusb-1.0.lib.libusb-1.0.lib to simplify runtime dependencies.Note: On Windows, LibUSB v1.0.19 is required to use most USB3 controllers.
C:\cygwin64\home\admin\uhd\host\build\UHD.sln.Note: You may not have permission to build the install target. You need to be an administrator or to run MSVC as administrator.
cd <uhd-repo-path>\host\build DevEnv uhd.sln /build Release /project ALL_BUILD DevEnv uhd.sln /build Release /project INSTALL
Add the UHD bin path to PATH% (usually C:\Program Files\UHD\bin)
xcode-select --install
sudo port install uhd sudo port uninstall uhd
NOTE: Other package managers (e.g., Fink, HomeBrew) will require different commands than the above to install all dependencies and then remove the UHD install. Please consult the specific package manager in use for how to do these commands properly; they will not be covered here.
$ mkdir build $ cd build $ CC=/usr/bin/llvm-gcc CXX=/usr/bin/llvm-g++ cmake -DCMAKE_INSTALL_PREFIX=/opt/local -DPYTHON_EXECUTABLE=/opt/local/bin/python2.7 -DPYTHON_INCLUDE_DIR=/opt/local/Library/Frameworks/Python.framework/Versions/2.7/Headers -DPYTHON_LIBRARY=/opt/local/Library/Frameworks/Python.framework/Versions/2.7/Python ../host $ make
$ make test
To install the build, issue
$ sudo make install
uhd_images_downloader on the command line, or one of these executables (the actual path may differ based on your installation):If your application uses CMake as a build system, the following command will setup up your build environment to link against UHD:
