Typedefs | |
| typedef struct uhd_sensor_value_t * | uhd_sensor_value_handle |
| C-level interface for a UHD sensor.  More... | |
Enumerations | |
| enum | uhd_sensor_value_data_type_t { UHD_SENSOR_VALUE_BOOLEAN = 98 , UHD_SENSOR_VALUE_INTEGER = 105 , UHD_SENSOR_VALUE_REALNUM = 114 , UHD_SENSOR_VALUE_STRING = 115 } |
| Sensor value types.  More... | |
Functions | |
| UHD_API uhd_error | uhd_sensor_value_make (uhd_sensor_value_handle *h) |
| Make an empty UHD sensor value.  More... | |
| UHD_API uhd_error | uhd_sensor_value_make_from_bool (uhd_sensor_value_handle *h, const char *name, bool value, const char *utrue, const char *ufalse) |
| Make a UHD sensor from a boolean.  More... | |
| UHD_API uhd_error | uhd_sensor_value_make_from_int (uhd_sensor_value_handle *h, const char *name, int value, const char *unit, const char *formatter) |
| Make a UHD sensor from an integer.  More... | |
| UHD_API uhd_error | uhd_sensor_value_make_from_realnum (uhd_sensor_value_handle *h, const char *name, double value, const char *unit, const char *formatter) |
| Make a UHD sensor from a real number.  More... | |
| UHD_API uhd_error | uhd_sensor_value_make_from_string (uhd_sensor_value_handle *h, const char *name, const char *value, const char *unit) |
| Make a UHD sensor from a string.  More... | |
| UHD_API uhd_error | uhd_sensor_value_free (uhd_sensor_value_handle *h) |
| Free the given sensor handle.  More... | |
| UHD_API uhd_error | uhd_sensor_value_to_bool (uhd_sensor_value_handle h, bool *value_out) |
| Get the sensor's value as a boolean.  More... | |
| UHD_API uhd_error | uhd_sensor_value_to_int (uhd_sensor_value_handle h, int *value_out) |
| Get the sensor's value as an integer.  More... | |
| UHD_API uhd_error | uhd_sensor_value_to_realnum (uhd_sensor_value_handle h, double *value_out) |
| Get the sensor's value as a real number.  More... | |
| UHD_API uhd_error | uhd_sensor_value_name (uhd_sensor_value_handle h, char *name_out, size_t strbuffer_len) |
| Get the sensor's name.  More... | |
| UHD_API uhd_error | uhd_sensor_value_value (uhd_sensor_value_handle h, char *value_out, size_t strbuffer_len) |
| Get the sensor's value.  More... | |
| UHD_API uhd_error | uhd_sensor_value_unit (uhd_sensor_value_handle h, char *unit_out, size_t strbuffer_len) |
| Get the sensor's unit.  More... | |
| UHD_API uhd_error | uhd_sensor_value_data_type (uhd_sensor_value_handle h, uhd_sensor_value_data_type_t *data_type_out) |
| UHD_API uhd_error | uhd_sensor_value_to_pp_string (uhd_sensor_value_handle h, char *pp_string_out, size_t strbuffer_len) |
| Get a pretty-print representation of the given sensor.  More... | |
| UHD_API uhd_error | uhd_sensor_value_last_error (uhd_sensor_value_handle h, char *error_out, size_t strbuffer_len) |
| Get the last error logged by the sensor handle.  More... | |
| typedef struct uhd_sensor_value_t* uhd_sensor_value_handle |
See uhd::sensor_value_t for more details.
NOTE: Using a handle before calling a make function will result in undefined behavior.
| UHD_API uhd_error uhd_sensor_value_data_type | ( | uhd_sensor_value_handle | h, |
| uhd_sensor_value_data_type_t * | data_type_out | ||
| UHD_API uhd_error uhd_sensor_value_free | ( | uhd_sensor_value_handle * | h | ) |
Attempting to use the handle after calling this handle will result in a segmentation fault.
| UHD_API uhd_error uhd_sensor_value_last_error | ( | uhd_sensor_value_handle | h, |
| char * | error_out, | ||
| size_t | strbuffer_len | ||
| h | sensor handle |
| error_out | string buffer in which to place error |
| strbuffer_len | buffer length |
| UHD_API uhd_error uhd_sensor_value_make | ( | uhd_sensor_value_handle * | h | ) |
The purpose of this call is to populate the handle with a valid sensor value object. Querying this object will always yield 'false'. Typically, this sensor value object will never be used, but it will allow the handle object to be used with sensor functions later on.
| h | the sensor handle in which to place sensor |
| UHD_API uhd_error uhd_sensor_value_make_from_bool | ( | uhd_sensor_value_handle * | h, |
| const char * | name, | ||
| bool | value, | ||
| const char * | utrue, | ||
| const char * | ufalse | ||
| name | sensor name |
| value | sensor value |
| utrue | string representing "true" |
| ufalse | string representing "false" |
| UHD_API uhd_error uhd_sensor_value_make_from_int | ( | uhd_sensor_value_handle * | h, |
| int | value, | ||
| const char * | unit, | ||
| const char * | formatter | ||
| h | the sensor value in which to place sensor |
| unit | sensor unit |
| formatter | printf-style format string for value string |
| UHD_API uhd_error uhd_sensor_value_make_from_realnum | ( | uhd_sensor_value_handle * | h, |
| double | value, | ||
| UHD_API uhd_error uhd_sensor_value_make_from_string | ( | uhd_sensor_value_handle * | h, |
| const char * | value, | ||
| const char * | unit | ||
| UHD_API uhd_error uhd_sensor_value_name | ( | uhd_sensor_value_handle | h, |
| char * | name_out, | ||
NOTE: This function will overwrite any string in the given buffer before inserting the sensor name.
| h | sensor handle |
| name_out | string buffer in which to place name |
| UHD_API uhd_error uhd_sensor_value_to_bool | ( | uhd_sensor_value_handle | h, |
| bool * | value_out | ||
| UHD_API uhd_error uhd_sensor_value_to_int | ( | uhd_sensor_value_handle | h, |
| int * | value_out | ||
| UHD_API uhd_error uhd_sensor_value_to_pp_string | ( | uhd_sensor_value_handle | h, |
| char * | pp_string_out, | ||
NOTE: This function will overwrite any string in the given buffer before inserting the string.
| h | sensor handle |
| pp_string_out | string buffer in which to place pp_string |
| UHD_API uhd_error uhd_sensor_value_to_realnum | ( | uhd_sensor_value_handle | h, |
| double * | value_out | ||
| UHD_API uhd_error uhd_sensor_value_unit | ( | uhd_sensor_value_handle | h, |
| char * | unit_out, | ||
NOTE: This function will overwrite any string in the given buffer before inserting the sensor unit.
| h | sensor handle |
| unit_out | string buffer in which to place unit |
| UHD_API uhd_error uhd_sensor_value_value | ( | uhd_sensor_value_handle | h, |
| char * | value_out, | ||
NOTE: This function will overwrite any string in the given buffer before inserting the sensor value.
| h | sensor handle |
| value_out | string buffer in which to place value |
