Public Types | |
| enum | error_code_t {  ERROR_CODE_NONE = 0x0 , ERROR_CODE_TIMEOUT = 0x1 , ERROR_CODE_LATE_COMMAND = 0x2 , ERROR_CODE_BROKEN_CHAIN = 0x4 , ERROR_CODE_OVERFLOW = 0x8 , ERROR_CODE_ALIGNMENT = 0xc , ERROR_CODE_BAD_PACKET = 0xf }  |
| rx_metadata_t () | |
| Default constructor.  More... | |
| void | reset () |
| Reset values.  More... | |
| std::string | to_pp_string (bool compact=true) const |
| std::string | strerror (void) const |
Public Attributes | |
| bool | has_time_spec |
| Has time specification?  More... | |
| time_spec_t | time_spec |
| Time of the first sample.  More... | |
| bool | more_fragments |
| size_t | fragment_offset |
| bool | start_of_burst |
| Start of burst will be true for the first packet in the chain.  More... | |
| bool | end_of_burst |
| End of burst will be true for the last packet in the chain.  More... | |
| size_t * | eov_positions |
| size_t | eov_positions_size |
| size_t | eov_positions_count |
| enum uhd::rx_metadata_t::error_code_t | error_code |
| bool | out_of_sequence |
  inline |
  inline |
Reset values.
| std::string uhd::rx_metadata_t::strerror | ( | void | ) | const |
Similar to C's strerror() function, creates a std::string describing the error code.
| std::string uhd::rx_metadata_t::to_pp_string | ( | bool | compact = true | ) | const |
Convert a rx_metadata_t into a pretty print string.
| compact | Set to false for a more verbose output. |
| bool uhd::rx_metadata_t::end_of_burst |
| size_t* uhd::rx_metadata_t::eov_positions |
If this pointer is not null, it specifies the address of an array of size_ts into which the sample offset relative to the beginning of a call to recv() of each vector (as denoted by packets with the eov header byte set) will be written.
The caller is responsible for allocating and deallocating the storage for the array and for indicating the maximum number of elements in the array via the eov_positions_size value below.
Upon return from recv(), eov_positions_count will be updated to indicate the number of valid entries written to the end_of_vector_positions array. It shall never exceed the value of eov_positions_size. However, if in the process of recv(), storage for new positions is exhausted, then recv() shall return.
| size_t uhd::rx_metadata_t::eov_positions_count |
Upon return from recv(), holds the number of end-of-vector indications in the eov_positions array.
| size_t uhd::rx_metadata_t::eov_positions_size |
| enum uhd::rx_metadata_t::error_code_t uhd::rx_metadata_t::error_code |
| size_t uhd::rx_metadata_t::fragment_offset |
| bool uhd::rx_metadata_t::has_time_spec |
| bool uhd::rx_metadata_t::more_fragments |
| bool uhd::rx_metadata_t::out_of_sequence |
Out of sequence. The transport has either dropped a packet or received data out of order.
| bool uhd::rx_metadata_t::start_of_burst |
| time_spec_t uhd::rx_metadata_t::time_spec |
