Namespaces | |
| namespace | uhd |
| namespace | uhd::build_info |
Functions | |
| UHD_API const std::string | uhd::build_info::boost_version () |
| Return the version of Boost this build was built with.  More... | |
| UHD_API const std::string | uhd::build_info::build_date () |
| Return the date and time (GMT) this UHD build was built.  More... | |
| UHD_API const std::string | uhd::build_info::c_compiler () |
| Return the C compiler used for this build.  More... | |
| UHD_API const std::string | uhd::build_info::cxx_compiler () |
| Return the C++ compiler used for this build.  More... | |
| UHD_API const std::string | uhd::build_info::c_flags () |
| Return the C flags passed into this build.  More... | |
| UHD_API const std::string | uhd::build_info::cxx_flags () |
| Return the C++ flags passed into this build.  More... | |
| UHD_API const std::string | uhd::build_info::enabled_components () |
| Return the UHD components enabled for this build, comma-delimited.  More... | |
| UHD_API const std::string | uhd::build_info::install_prefix () |
| Return the default CMake install prefix for this build.  More... | |
| UHD_API const std::string | uhd::build_info::libusb_version () |
| Return the version of libusb this build was built with.  More... | |
