| mgmt_payload ()=default |
| mgmt_payload (const mgmt_payload &rhs)=default |
| mgmt_payload (mgmt_payload &&rhs)=default |
mgmt_payload & | operator= (const mgmt_payload &rhs)=default |
void | set_header (sep_id_t src_epid, uint16_t protover, chdr_w_t chdr_w) |
void | add_hop (const mgmt_hop_t &hop) |
| Add a management hop to this transaction. More...
size_t | get_num_hops () const |
| Get the number of management hops in this hop. More...
const mgmt_hop_t & | get_hop (size_t i) const |
| Get the n'th hop in the transaction. More...
mgmt_hop_t | pop_hop () |
| Pop the first hop of the transaction and return it. More...
size_t | get_size_bytes () const |
void | populate_header (chdr_header &header) const |
| Populate the header for this type of packet. More...
size_t | serialize (uint64_t *buff, size_t max_size_bytes, const std::function< uint64_t(uint64_t)> &conv_byte_order) const |
| Serialize the payload to a uint64_t buffer. More...
template<endianness_t endianness> |
size_t | serialize (uint64_t *buff, size_t max_size_bytes) const |
| Serialize the payload to a uint64_t buffer (no conversion function) More...
void | deserialize (const uint64_t *buff, size_t num_elems, const std::function< uint64_t(uint64_t)> &conv_byte_order) |
| Deserialize the payload from a uint64_t buffer. More...
void | deserialize (const uint64_t *buff, size_t num_elems) |
| Deserialize the payload from a uint64_t buffer (no conversion function) More...
size_t | get_length () const |
| Get the serialized size of this payload in 64 bit words. More...
const std::string | to_string () const |
| Return a string representation of this object. More...
const std::string | hops_to_string () const |
| Return a string representaiton of the hops contained by this object. More...
sep_id_t | get_src_epid () const |
| Return the source EPID for this transaction. More...
void | set_src_epid (sep_id_t src_epid) |
| Set the source EPID for this transaction. More...
bool | operator== (const mgmt_payload &rhs) const |
| Comparison operator (==) More...
chdr_w_t | get_chdr_w () const |
| Return the CHDR_W for this transaction. More...
void | set_chdr_w (chdr_w_t chdr_w) |
| Set the CHDR_W for this transaction. More...
uint16_t | get_proto_ver () const |
| Return the protocol version for this transaction. More...
void | set_proto_ver (uint16_t proto_ver) |
| Set the protocol version for this transaction. More...
