Public Types | |
| enum | unit_t { UNIT_RX = int('r') , UNIT_TX = int('t') , UNIT_BOTH = int('b') } |
| tells the host which unit to use  More... | |
| enum | aux_dac_t { AUX_DAC_A = int('a') , AUX_DAC_B = int('b') , AUX_DAC_C = int('c') , AUX_DAC_D = int('d') } |
| aux dac selection enums (per unit)  More... | |
| enum | aux_adc_t { AUX_ADC_A = int('a') , AUX_ADC_B = int('b') } |
| aux adc selection enums (per unit)  More... | |
| typedef std::shared_ptr< dboard_iface > | sptr |
| typedef dboard_iface_special_props_t | special_props_t |
| typedef uhd::usrp::gpio_atr::gpio_atr_reg_t | atr_reg_t |
  Public Types inherited from uhd::i2c_iface | |
| typedef std::shared_ptr< i2c_iface > | sptr |
| ~dboard_iface (void) override | |
| virtual special_props_t | get_special_props (void)=0 |
| virtual void | write_aux_dac (unit_t unit, aux_dac_t which_dac, double value)=0 |
| virtual double | read_aux_adc (unit_t unit, aux_adc_t which_adc)=0 |
| virtual void | set_pin_ctrl (unit_t unit, uint32_t value, uint32_t mask=0xffff)=0 |
| virtual uint32_t | get_pin_ctrl (unit_t unit)=0 |
| virtual void | set_atr_reg (unit_t unit, atr_reg_t reg, uint32_t value, uint32_t mask=0xffff)=0 |
| virtual uint32_t | get_atr_reg (unit_t unit, atr_reg_t reg)=0 |
| virtual void | set_gpio_ddr (unit_t unit, uint32_t value, uint32_t mask=0xffff)=0 |
| virtual uint32_t | get_gpio_ddr (unit_t unit)=0 |
| virtual void | set_gpio_out (unit_t unit, uint32_t value, uint32_t mask=0xffff)=0 |
| virtual uint32_t | get_gpio_out (unit_t unit)=0 |
| virtual uint32_t | read_gpio (unit_t unit)=0 |
| virtual void | write_spi (unit_t unit, const spi_config_t &config, uint32_t data, size_t num_bits)=0 |
| virtual uint32_t | read_write_spi (unit_t unit, const spi_config_t &config, uint32_t data, size_t num_bits)=0 |
| virtual void | set_clock_rate (unit_t unit, double rate)=0 |
| virtual double | get_clock_rate (unit_t unit)=0 |
| virtual std::vector< double > | get_clock_rates (unit_t unit)=0 |
| virtual void | set_clock_enabled (unit_t unit, bool enb)=0 |
| virtual double | get_codec_rate (unit_t unit)=0 |
| virtual void | set_fe_connection (unit_t unit, const std::string &fe_name, const uhd::usrp::fe_connection_t &fe_conn)=0 |
| virtual bool | has_set_fe_connection (const unit_t) |
| virtual uhd::time_spec_t | get_command_time (void)=0 |
| virtual void | set_command_time (const uhd::time_spec_t &t)=0 |
| virtual void | sleep (const boost::chrono::nanoseconds &time) |
  Public Member Functions inherited from uhd::i2c_iface | |
| virtual | ~i2c_iface (void) |
| i2c_iface::sptr | eeprom16 (void) |
| Create an i2c_iface than can talk to 16 bit addressable EEPROMS.  More... | |
| virtual void | write_i2c (uint16_t addr, const byte_vector_t &buf)=0 |
| virtual byte_vector_t | read_i2c (uint16_t addr, size_t num_bytes)=0 |
| virtual void | write_eeprom (uint16_t addr, uint16_t offset, const byte_vector_t &buf) |
| virtual byte_vector_t | read_eeprom (uint16_t addr, uint16_t offset, size_t num_bytes) |
| typedef std::shared_ptr<dboard_iface> uhd::usrp::dboard_iface::sptr |
  inlineoverride |
| unit | which unit rx or tx |
| reg | which ATR register |
Get the command time.
  inlinevirtual |
Returns the true if set_fe_connection() is implemented on this dboard_iface
Read from an aux adc.
| which_adc | the adc index 0, 1, 2, 3... |
| unit | which unit, rx or tx |
| config | configuration settings |
| data | the bits to write MSB first |
| num_bits | the number of bits in data |
| value | 16-bits, 0=ATR output low, 1=ATR output high |
| mask | 16-bits, 0=do not change, 1=change value |
| enb | true for enabled |
| rate | the clock rate in Hz |
Set the command time.
| t | the time |
Configure the front-end connection parameters.
| fe_name | name of the front-end to update |
| fe_conn | connection parameters class |
| value | 16-bits, 0=GPIO input, 1=GPIO output |
| value | 16-bits, 0=GPIO output low, 1=GPIO output high |
| value | 16-bits, 0=GPIO controlled, 1=ATR controlled |
  virtual |
Sleep for a set time
| time | time to sleep in nanoseconds |
Write to an aux dac.
| which_dac | the dac index 0, 1, 2, 3... |
| value | the value in volts |
