7#ifndef INCLUDED_LIBUHD_CAL_GAIN_HPP
    8#define INCLUDED_LIBUHD_CAL_GAIN_HPP
   12#include <boost/optional.hpp>
   16namespace uhd {
namespace usrp {
namespace cal {
   23    static constexpr uint32_t NUM_AMP         = 1;
   24    static constexpr uint32_t NUM_DSA         = 2 + NUM_AMP;
   25    static constexpr uint32_t NUM_GAIN_STAGES = 61;
   27    using sptr          = std::shared_ptr<zbx_tx_dsa_cal>;
   38        const std::string& name,
   39        std::array<step_settings, NUM_GAIN_STAGES> dsa_steps) = 0;
   50        const double freq,
const size_t gain_index)
const = 0;
   69        const std::string& name,
const std::string& serial,
const uint64_t timestamp);
   80    static constexpr uint32_t NUM_DSA         = 4;
   81    static constexpr uint32_t NUM_GAIN_STAGES = 61;
   83    using sptr          = std::shared_ptr<zbx_rx_dsa_cal>;
   94        const std::string& name,
   95        std::array<step_settings, NUM_GAIN_STAGES> dsa_steps) = 0;
  107        const double freq,
const = 0;
  122        const std::string& name,
Definition: container.hpp:23
Definition: dsa_cal.hpp:78
static sptr make(const std::string &name, const std::string &serial, const uint64_t timestamp)
Factory for new cal data sets.
virtual const step_settings get_dsa_setting(const double freq, const size_t gain_index) const =0
static sptr make()
Default factory.
virtual void add_frequency_band(const double max_freq, const std::string &name, std::array< step_settings, NUM_GAIN_STAGES > dsa_steps)=0
virtual std::vector< uint32_t > get_band_settings(double freq, uint8_t dsa) const =0
virtual bool is_same_band(double freq1, double freq2) const =0
std::array< uint32_t, NUM_DSA > step_settings
Definition: dsa_cal.hpp:84
std::shared_ptr< zbx_rx_dsa_cal > sptr
Definition: dsa_cal.hpp:83
Definition: dsa_cal.hpp:21
Definition: dsa_cal.hpp:28
std::shared_ptr< zbx_tx_dsa_cal > sptr
Definition: dsa_cal.hpp:27
static sptr make()
Default factory.
Definition: config.h:70
Definition: build_info.hpp:12
