#include <uhd/cal/dsa_cal.hpp>
Public Types | |
| using | sptr = std::shared_ptr< zbx_rx_dsa_cal > |
| using | step_settings = std::array< uint32_t, NUM_DSA > |
| virtual void | add_frequency_band (const double max_freq, const std::string &name, std::array< step_settings, NUM_GAIN_STAGES > dsa_steps)=0 |
| virtual bool | is_same_band (double freq1, double freq2) const =0 |
| virtual const step_settings | get_dsa_setting (const double freq, const size_t gain_index) const =0 |
| virtual std::vector< uint32_t > | get_band_settings (double freq, uint8_t dsa) const =0 |
| virtual void | clear ()=0 |
  Public Member Functions inherited from uhd::usrp::cal::container | |
| virtual | ~container ()=default |
| virtual std::string | get_name () const =0 |
| Return the name of this calibration table.  More... | |
| virtual std::string | get_serial () const =0 |
| Return the device serial of this calibration table.  More... | |
| virtual uint64_t | get_timestamp () const =0 |
| Timestamp of acquisition time.  More... | |
| virtual std::vector< uint8_t > | serialize ()=0 |
| Return a serialized version of this container.  More... | |
| virtual void | deserialize (const std::vector< uint8_t > &data)=0 |
| Populate this class from the serialized data.  More... | |
| static sptr | make (const std::string &name, const std::string &serial, const uint64_t timestamp) |
| Factory for new cal data sets.  More... | |
| static sptr | make () |
| Default factory.  More... | |
  Static Public Member Functions inherited from uhd::usrp::cal::container | |
| template<typename container_type > | |
| static std::shared_ptr< container_type > | make (const std::vector< uint8_t > &data) |
| Generic factory for cal data from serialized data.  More... | |
| static constexpr uint32_t | NUM_DSA = 4 |
| static constexpr uint32_t | NUM_GAIN_STAGES = 61 |
Class that stores DSA indices for all ZBX TX bands.
| using uhd::usrp::cal::zbx_rx_dsa_cal::sptr = std::shared_ptr<zbx_rx_dsa_cal> |
| using uhd::usrp::cal::zbx_rx_dsa_cal::step_settings = std::array<uint32_t, NUM_DSA> |
Add a new band description.
max_freq is the (inclusive) upper limit for the band (lower limit derives from the other bands). Name is an text representation (human readable) for the band. dsa_steps is an array of DSA settings for all gains in the band.
Clear all stored values
Retrieves DSA settings as flat list. The values are flattend by frequency band, gain and values in that order. Use NUM_DSA and NUM_GAIN_STAGES to find values in the list.
Retrieves DSA settings for frequency and gain_index.
The settings are retrieved from the band with the biggest max_freq that is smaller or equal to freq. DSA settings are the settings at gain_index in that band. Value errors are thrown if freq is larger that the largest freq_max of all bands or gain_index is not within range.
Default factory.
  staticconstexpr |
  staticconstexpr |
