USRP Hardware Driver and USRP Manual Version: 4.1.0.4
log.hpp File Reference
#include <uhd/config.hpp>
#include <boost/thread/thread.hpp>
#include <iomanip>
#include <iostream>
#include <ostream>
#include <sstream>
#include <string>
Classes
struct  uhd::log::logging_info
Namespaces
namespace  uhd
namespace  uhd::log
Macros
#define UHD_LOG_TRACE(component, message)    _UHD_LOG_INTERNAL(component, uhd::log::trace) << message;
#define UHD_LOG_DEBUG(component, message)    _UHD_LOG_INTERNAL(component, uhd::log::debug) << message;
#define UHD_LOG_INFO(component, message)    _UHD_LOG_INTERNAL(component, uhd::log::info) << message;
#define UHD_LOG_WARNING(component, message)    _UHD_LOG_INTERNAL(component, uhd::log::warning) << message;
#define UHD_LOG_ERROR(component, message)    _UHD_LOG_INTERNAL(component, uhd::log::error) << message;
#define UHD_LOG_FATAL(component, message)    _UHD_LOG_INTERNAL(component, uhd::log::fatal) << message;
#define RFNOC_LOG_TRACE(message)   UHD_LOG_TRACE(this->get_unique_id(), message)
#define RFNOC_LOG_DEBUG(message)   UHD_LOG_DEBUG(this->get_unique_id(), message)
#define RFNOC_LOG_INFO(message)   UHD_LOG_INFO(this->get_unique_id(), message)
#define RFNOC_LOG_WARNING(message)   UHD_LOG_WARNING(this->get_unique_id(), message)
#define RFNOC_LOG_ERROR(message)   UHD_LOG_ERROR(this->get_unique_id(), message)
#define RFNOC_LOG_FATAL(message)   UHD_LOG_FATAL(this->get_unique_id(), message)
#define UHD_LOG_FASTPATH(message)   uhd::_log::log_fastpath(message);
 Extra-fast logging macro for when speed matters. More...
#define UHD_LOGGER_TRACE(component)   _UHD_LOG_INTERNAL(component, uhd::log::trace)
#define UHD_LOGGER_DEBUG(component)   _UHD_LOG_INTERNAL(component, uhd::log::debug)
#define UHD_LOGGER_INFO(component)   _UHD_LOG_INTERNAL(component, uhd::log::info)
#define UHD_LOGGER_WARNING(component)   _UHD_LOG_INTERNAL(component, uhd::log::warning)
#define UHD_LOGGER_ERROR(component)   _UHD_LOG_INTERNAL(component, uhd::log::error)
#define UHD_LOGGER_FATAL(component)   _UHD_LOG_INTERNAL(component, uhd::log::fatal)
#define UHD_HERE()   UHD_LOGGER_DEBUG("DEBUG") << __FILE__ << ":" << __LINE__;
 Helpful debug tool to print site info. More...
#define UHD_VAR(var)   UHD_LOGGER_DEBUG("DEBUG") << #var << " = " << var;
 Helpful debug tool to print a variable. More...
#define UHD_HEX(var)
 Helpful debug tool to print a variable in hex. More...
Enumerations
enum  uhd::log::severity_level {
  uhd::log::trace = 0 , uhd::log::debug = 1 , uhd::log::info = 2 , uhd::log::warning = 3 ,
  uhd::log::error = 4 , uhd::log::fatal = 5 , uhd::log::off = 6
Functions
UHD_API void uhd::log::set_log_level (uhd::log::severity_level level)
UHD_API void uhd::log::set_console_level (uhd::log::severity_level level)
UHD_API void uhd::log::set_file_level (uhd::log::severity_level level)
UHD_API void uhd::log::set_logger_level (const std::string &logger, uhd::log::severity_level level)
The UHD logging facility
The logger enables UHD library code to easily log events into a file and display messages above a certain level in the terminal. Log entries are time-stamped and stored with file, line, and function. Each call to the UHD_LOG macros is thread-safe. Each thread will aquire the lock for the logger.
Note: More information on the logging subsystem can be found on UHD Logging.
To disable console logging completely at compile time specify -DUHD_LOG_CONSOLE_DISABLE during configuration with CMake.
By default no file logging will occur. Set a log file path:
  • at compile time by specifying -DUHD_LOG_FILE=$file_path
  • and/or override at runtime by setting the environment variable UHD_LOG_FILE
Log levels
See also Log levels.
All log messages with verbosity greater than or equal to the log level (in other words, as often or less often than the current log level) are recorded to std::clog and/or the log file. Log levels can be specified using string or numeric values of uhd::log::severity_level.
The minimum log level is defined by -DUHD_LOG_MIN_LEVEL at compile time, and this value can be increased at runtime by specifying the UHD_LOG_LEVEL environment variable. This minimum logging level applies to any form of runtime logging. Thus for example if this minimum is set to 3 (info), then during runtime no logging at levels below 3 can be provided.
The following set the minimum logging level to 3 (info):
  • Example pre-processor define: -DUHD_LOG_MIN_LEVEL=3
  • Example pre-processor define: -DUHD_LOG_MIN_LEVEL=info
  • Example environment variable: export UHD_LOG_LEVEL=3
  • Example environment variable: export UHD_LOG_LEVEL=info
The actual log level for console and file logging can be configured by setting UHD_LOG_CONSOLE_LEVEL or UHD_LOG_FILE_LEVEL, respectively. The default values for these variables can be defined using the cmake flags -DUHD_LOG_CONSOLE_LEVEL and -DUHD_LOG_FILE_LEVEL, respectively.
These variables can be the name of a verbosity enum or integer value:
  • Example pre-processor define: -DUHD_LOG_CONSOLE_LEVEL=3
  • Example pre-processor define: -DUHD_LOG_CONSOLE_LEVEL=info
  • Example environment variable: export UHD_LOG_CONSOLE_LEVEL=3
  • Example environment variable: export UHD_LOG_CONSOLE_LEVEL=info
The UHD_LOG_FILE_LEVEL variable can be used in the same way.
Log formatting
The log format for messages going into a log file is CSV. All log messages going into a logfile will contain following fields:
  • timestamp
  • thread-id
  • source-file + line information
  • severity level
  • component/channel information which logged the information
  • the actual log message
The log format of log messages displayed on the terminal is plain text with space separated tags prepended. For example:
  • [INFO] [X300] This is a informational log message
The log format for log output on the console by using these preprocessor defines in CMake:
  • -DUHD_LOG_CONSOLE_TIME adds a timestamp [2017-01-01 00:00:00.000000]
  • -DUHD_LOG_CONSOLE_THREAD adds a thread-id [0x001234]
  • -DUHD_LOG_CONSOLE_SRC adds a sourcefile and line tag [src_file:line]
◆ RFNOC_LOG_DEBUG
#define RFNOC_LOG_DEBUG (   message)    UHD_LOG_DEBUG(this->get_unique_id(), message)
◆ RFNOC_LOG_ERROR
#define RFNOC_LOG_ERROR (   message)    UHD_LOG_ERROR(this->get_unique_id(), message)
◆ RFNOC_LOG_FATAL
#define RFNOC_LOG_FATAL (   message)    UHD_LOG_FATAL(this->get_unique_id(), message)
◆ RFNOC_LOG_INFO
#define RFNOC_LOG_INFO (   message)    UHD_LOG_INFO(this->get_unique_id(), message)
◆ RFNOC_LOG_TRACE
#define RFNOC_LOG_TRACE (   message)    UHD_LOG_TRACE(this->get_unique_id(), message)
◆ RFNOC_LOG_WARNING
#define RFNOC_LOG_WARNING (   message)    UHD_LOG_WARNING(this->get_unique_id(), message)
◆ UHD_HERE
#define UHD_HERE ( )    UHD_LOGGER_DEBUG("DEBUG") << __FILE__ << ":" << __LINE__;
◆ UHD_HEX
#define UHD_HEX (   var)
Value:
UHD_LOGGER_DEBUG("DEBUG") << #var << " = 0x" << std::hex << std::setfill('0') \
<< std::setw(8) << var << std::dec;
Definition: log.hpp:255
◆ UHD_LOG_DEBUG
#define UHD_LOG_DEBUG (   component,
  message
◆ UHD_LOG_ERROR
#define UHD_LOG_ERROR (   component,
  message
◆ UHD_LOG_FASTPATH
#define UHD_LOG_FASTPATH (   message)    uhd::_log::log_fastpath(message);
◆ UHD_LOG_FATAL
#define UHD_LOG_FATAL (   component,
  message
◆ UHD_LOG_INFO
#define UHD_LOG_INFO (   component,
  message
◆ UHD_LOG_TRACE
#define UHD_LOG_TRACE (   component,
  message
◆ UHD_LOG_WARNING
#define UHD_LOG_WARNING (   component,
  message
◆ UHD_LOGGER_DEBUG
#define UHD_LOGGER_DEBUG (   component)    _UHD_LOG_INTERNAL(component, uhd::log::debug)
◆ UHD_LOGGER_ERROR
#define UHD_LOGGER_ERROR (   component)    _UHD_LOG_INTERNAL(component, uhd::log::error)
◆ UHD_LOGGER_FATAL
#define UHD_LOGGER_FATAL (   component)    _UHD_LOG_INTERNAL(component, uhd::log::fatal)
◆ UHD_LOGGER_INFO
#define UHD_LOGGER_INFO (   component)    _UHD_LOG_INTERNAL(component, uhd::log::info)
◆ UHD_LOGGER_TRACE
#define UHD_LOGGER_TRACE (   component)    _UHD_LOG_INTERNAL(component, uhd::log::trace)
◆ UHD_LOGGER_WARNING
#define UHD_LOGGER_WARNING (   component)    _UHD_LOG_INTERNAL(component, uhd::log::warning)
◆ UHD_VAR
#define UHD_VAR (   var)    UHD_LOGGER_DEBUG("DEBUG") << #var << " = " << var;
