#include <uhd/rfnoc/graph_edge.hpp>
Public Types | |
| enum | edge_t { STATIC , DYNAMIC , RX_STREAM , TX_STREAM } |
| graph_edge_t ()=default | |
| graph_edge_t (const size_t src_port_, const size_t dst_port_, const edge_t edge_, const bool ppa) | |
| bool | operator== (const graph_edge_t &rhs) const |
| std::string | to_string () const |
| Return a string representation of the connection.  More... | |
Public Attributes | |
| std::string | src_blockid |
| The ID of the source block for this edge.  More... | |
| size_t | src_port = 0 |
| The port number of the source block for this edge.  More... | |
| std::string | dst_blockid |
| The ID of the destination block for this edge.  More... | |
| size_t | dst_port = 0 |
| The port number of the destination block for this edge.  More... | |
| edge_t | edge = DYNAMIC |
| The type of edge.  More... | |
| bool | property_propagation_active = true |
| When true, the framework will use this edge for property propagation.  More... | |
A container that holds information about a graph edge
Note: The source and destination IDs are strings, not block IDs (uhd::rfnoc::block_id_t). This is because the graph can contain edges that are not between RFNoC blocks (e.g., to a streamer), and we need to be able to generically express node IDs.
  default |
  inline |
  inline |
  inline |
| std::string uhd::rfnoc::graph_edge_t::dst_blockid |
| size_t uhd::rfnoc::graph_edge_t::dst_port = 0 |
| bool uhd::rfnoc::graph_edge_t::property_propagation_active = true |
| std::string uhd::rfnoc::graph_edge_t::src_blockid |
| size_t uhd::rfnoc::graph_edge_t::src_port = 0 |
