uhd::rfnoc::chdr::mgmt_payload Class Reference
A class that represents a complete multi-hop management transaction. More...
 mgmt_payload ()=default
 mgmt_payload (const mgmt_payload &rhs)=default
 mgmt_payload (mgmt_payload &&rhs)=default
mgmt_payloadoperator= (const mgmt_payload &rhs)=default
void set_header (sep_id_t src_epid, uint16_t protover, chdr_w_t chdr_w)
void add_hop (const mgmt_hop_t &hop)
 Add a management hop to this transaction. More...
size_t get_num_hops () const
 Get the number of management hops in this hop. More...
const mgmt_hop_tget_hop (size_t i) const
 Get the n'th hop in the transaction. More...
mgmt_hop_t pop_hop ()
 Pop the first hop of the transaction and return it. More...
size_t get_size_bytes () const
void populate_header (chdr_header &header) const
 Populate the header for this type of packet. More...
size_t serialize (uint64_t *buff, size_t max_size_bytes, const std::function< uint64_t(uint64_t)> &conv_byte_order) const
 Serialize the payload to a uint64_t buffer. More...
size_t serialize (uint64_t *buff, size_t max_size_bytes) const
 Serialize the payload to a uint64_t buffer (no conversion function) More...
void deserialize (const uint64_t *buff, size_t num_elems, const std::function< uint64_t(uint64_t)> &conv_byte_order)
 Deserialize the payload from a uint64_t buffer. More...
void deserialize (const uint64_t *buff, size_t num_elems)
 Deserialize the payload from a uint64_t buffer (no conversion function) More...
size_t get_length () const
 Get the serialized size of this payload in 64 bit words. More...
const std::string to_string () const
 Return a string representation of this object. More...
const std::string hops_to_string () const
 Return a string representaiton of the hops contained by this object. More...
sep_id_t get_src_epid () const
 Return the source EPID for this transaction. More...
void set_src_epid (sep_id_t src_epid)
 Set the source EPID for this transaction. More...
bool operator== (const mgmt_payload &rhs) const
 Comparison operator (==) More...
chdr_w_t get_chdr_w () const
 Return the CHDR_W for this transaction. More...
void set_chdr_w (chdr_w_t chdr_w)
 Set the CHDR_W for this transaction. More...
uint16_t get_proto_ver () const
 Return the protocol version for this transaction. More...
void set_proto_ver (uint16_t proto_ver)
 Set the protocol version for this transaction. More...
◆ mgmt_payload() [1/3]
uhd::rfnoc::chdr::mgmt_payload::mgmt_payload ( )
default
◆ mgmt_payload() [2/3]
uhd::rfnoc::chdr::mgmt_payload::mgmt_payload ( const mgmt_payload rhs)
default
◆ mgmt_payload() [3/3]
uhd::rfnoc::chdr::mgmt_payload::mgmt_payload ( mgmt_payload &&  rhs)
default
◆ add_hop()
void uhd::rfnoc::chdr::mgmt_payload::add_hop ( const mgmt_hop_t hop)
◆ deserialize() [1/2]
void uhd::rfnoc::chdr::mgmt_payload::deserialize ( const uint64_t *  buff,
size_t  num_elems
◆ deserialize() [2/2]
size_t  num_elems,
const std::function< uint64_t(uint64_t)> &  conv_byte_order
◆ get_chdr_w()
chdr_w_t uhd::rfnoc::chdr::mgmt_payload::get_chdr_w ( ) const
◆ get_hop()
const mgmt_hop_t & uhd::rfnoc::chdr::mgmt_payload::get_hop ( size_t  i) const
◆ get_length()
size_t uhd::rfnoc::chdr::mgmt_payload::get_length ( ) const
◆ get_num_hops()
size_t uhd::rfnoc::chdr::mgmt_payload::get_num_hops ( ) const
◆ get_proto_ver()
uint16_t uhd::rfnoc::chdr::mgmt_payload::get_proto_ver ( ) const
◆ get_size_bytes()
size_t uhd::rfnoc::chdr::mgmt_payload::get_size_bytes ( ) const
◆ get_src_epid()
sep_id_t uhd::rfnoc::chdr::mgmt_payload::get_src_epid ( ) const
◆ hops_to_string()
const std::string uhd::rfnoc::chdr::mgmt_payload::hops_to_string ( ) const
◆ operator=()
mgmt_payload & uhd::rfnoc::chdr::mgmt_payload::operator= ( const mgmt_payload rhs)
default
◆ operator==()
bool uhd::rfnoc::chdr::mgmt_payload::operator== ( const mgmt_payload rhs) const
◆ pop_hop()
mgmt_hop_t uhd::rfnoc::chdr::mgmt_payload::pop_hop ( )
◆ populate_header()
void uhd::rfnoc::chdr::mgmt_payload::populate_header ( chdr_header header) const
◆ serialize() [1/2]
size_t uhd::rfnoc::chdr::mgmt_payload::serialize ( uint64_t *  buff,
) const
◆ serialize() [2/2]
) const
◆ set_chdr_w()
void uhd::rfnoc::chdr::mgmt_payload::set_chdr_w ( chdr_w_t  chdr_w)
◆ set_header()
void uhd::rfnoc::chdr::mgmt_payload::set_header ( sep_id_t  src_epid,
uint16_t  protover,
chdr_w_t  chdr_w
◆ set_proto_ver()
void uhd::rfnoc::chdr::mgmt_payload::set_proto_ver ( uint16_t  proto_ver)
◆ set_src_epid()
void uhd::rfnoc::chdr::mgmt_payload::set_src_epid ( sep_id_t  src_epid)
◆ to_string()
const std::string uhd::rfnoc::chdr::mgmt_payload::to_string ( ) const
