uhd::rfnoc::property_base_t Class Referenceabstract
#include <uhd/rfnoc/property.hpp>
Inheritance diagram for uhd::rfnoc::property_base_t:
uhd::rfnoc::property_t< double > uhd::rfnoc::property_t< size_t > uhd::rfnoc::dirtifier_t uhd::rfnoc::property_t< data_t >
enum  access_t { NONE , RO = 0x1 , RW = 0x3 , RWLOCKED = 0x5 }
 property_base_t (const std::string &id, const res_source_info &source_info)
virtual ~property_base_t ()
const std::string & get_id () const
 Gets the ID (name) of this property. More...
const res_source_infoget_src_info () const
 Return the source info for this property. More...
virtual bool is_dirty () const =0
 Query this property's dirty flag. More...
virtual bool is_valid () const =0
 Query this property's valid flag. More...
bool read_access_granted () const
 Returns true if this property can be read. More...
bool write_access_granted () const
 Returns true if this property can be written to. More...
access_t get_access_mode () const
 Return the current access mode. More...
virtual bool equal (property_base_t *rhs) const =0
 Return true if rhs has the same type and value. More...
virtual std::unique_ptr< property_base_tclone (res_source_info)
 Create a copy of this property. More...
virtual void force_dirty ()=0
virtual void set_from_str (const std::string &new_val_str)=0
Friends
class prop_accessor_t
Base class for properties
◆ access_t
Enumerator
NONE
Neither reading nor writing to this property is permitted.
RO
Read-Only.
RW
Read-Write.
RWLOCKED
Write is locked. This lets you call set(), but only if the value is unchanged.
◆ property_base_t()
uhd::rfnoc::property_base_t::property_base_t ( const std::string &  id,
const res_source_info source_info
◆ ~property_base_t()
virtual uhd::rfnoc::property_base_t::~property_base_t ( )
◆ clone()
virtual std::unique_ptr< property_base_t > uhd::rfnoc::property_base_t::clone ( res_source_info  )
◆ equal()
virtual bool uhd::rfnoc::property_base_t::equal ( property_base_t rhs) const
◆ force_dirty()
virtual void uhd::rfnoc::property_base_t::force_dirty ( )
◆ get_access_mode()
access_t uhd::rfnoc::property_base_t::get_access_mode ( ) const
◆ get_id()
const std::string & uhd::rfnoc::property_base_t::get_id ( ) const
◆ get_src_info()
const res_source_info & uhd::rfnoc::property_base_t::get_src_info ( ) const
◆ is_dirty()
virtual bool uhd::rfnoc::property_base_t::is_dirty ( ) const
◆ is_valid()
virtual bool uhd::rfnoc::property_base_t::is_valid ( ) const
◆ read_access_granted()
bool uhd::rfnoc::property_base_t::read_access_granted ( ) const
◆ set_from_str()
virtual void uhd::rfnoc::property_base_t::set_from_str ( const std::string &  new_val_str)
Set this property's value using a string
This requires the underlying property type to be convertible from a string.
Exceptions
uhd::runtime_errorif the underlying type has no conversion from a string
Implemented in uhd::rfnoc::dirtifier_t, uhd::rfnoc::property_t< data_t >, uhd::rfnoc::property_t< double >, and uhd::rfnoc::property_t< size_t >.
◆ write_access_granted()
bool uhd::rfnoc::property_base_t::write_access_granted ( ) const
Friends And Related Function Documentation
◆ prop_accessor_t
friend class prop_accessor_t
friend
