uhd::transport::managed_buffer Class Referenceabstract
Inheritance diagram for uhd::transport::managed_buffer:
uhd::transport::managed_recv_buffer uhd::transport::managed_send_buffer
typedef boost::intrusive_ptr< managed_buffersptr
 managed_buffer (void)
virtual ~managed_buffer (void)
virtual void release (void)=0
UHD_INLINE void commit (size_t num_bytes)
template<class T >
UHD_INLINEcast (void) const
UHD_INLINE size_t size (void) const
template<typename T >
UHD_INLINE boost::intrusive_ptr< T > make (T *p, void *buffer, size_t length)
 Create smart pointer to a reusable managed buffer. More...
int ref_count ()
Public Attributes
boost::detail::atomic_count _ref_count
Protected Attributes
void * _buffer
size_t _length
◆ managed_buffer()
uhd::transport::managed_buffer::managed_buffer ( void  )
◆ ~managed_buffer()
virtual uhd::transport::managed_buffer::~managed_buffer ( void  )
◆ cast()
template<class T >
UHD_INLINE T uhd::transport::managed_buffer::cast ( void  ) const
Get a pointer to the underlying buffer.
a pointer into memory
◆ commit()
UHD_INLINE void uhd::transport::managed_buffer::commit ( size_t  num_bytes)
Use commit() to re-write the length (for use with send buffers).
num_bytesthe number of bytes written into the buffer
◆ make()
UHD_INLINE boost::intrusive_ptr< T > uhd::transport::managed_buffer::make ( T *  p,
void *  buffer,
size_t  length
◆ ref_count()
int uhd::transport::managed_buffer::ref_count ( )
◆ release()
virtual void uhd::transport::managed_buffer::release ( void  )
Signal to the transport that we are done with the buffer. This should be called to release the buffer to the transport object. After calling, the referenced memory should be considered invalid.
◆ size()
UHD_INLINE size_t uhd::transport::managed_buffer::size ( void  ) const
Get the size of the underlying buffer.
the number of bytes
◆ _buffer
void* uhd::transport::managed_buffer::_buffer
◆ _length
size_t uhd::transport::managed_buffer::_length
◆ _ref_count
boost::detail::atomic_count uhd::transport::managed_buffer::_ref_count
