uhd::transport::usb_device_handle Class Referenceabstract
#include <uhd/transport/usb_device_handle.hpp>
Inheritance diagram for uhd::transport::usb_device_handle:
typedef std::shared_ptr< usb_device_handlesptr
typedef std::pair< uint16_t, uint16_t > vid_pid_pair_t
virtual ~usb_device_handle (void)
virtual std::string get_serial () const =0
virtual std::string get_manufacturer () const =0
virtual std::string get_product () const =0
virtual uint16_t get_vendor_id () const =0
virtual uint16_t get_product_id () const =0
virtual bool firmware_loaded ()=0
static std::vector< usb_device_handle::sptrget_device_list (uint16_t vid, uint16_t pid)
static std::vector< usb_device_handle::sptrget_device_list (const std::vector< usb_device_handle::vid_pid_pair_t > &vid_pid_pair_list)
Device handle class that represents a USB device Used for identifying devices on the USB bus and selecting which device is used when creating a USB transport. A minimal subset of USB descriptor fields are used. Fields can be found in the USB 2.0 specification Table 9-8 (Standard Device Descriptor). In addition to fields of the device descriptor, the interface returns the device's USB device address.
Note: The USB 2.0 Standard Device Descriptor contains an index rather then a true descriptor serial number string. This interface returns the actual string descriptor.
◆ vid_pid_pair_t
typedef std::pair<uint16_t, uint16_t> uhd::transport::usb_device_handle::vid_pid_pair_t
◆ ~usb_device_handle()
virtual uhd::transport::usb_device_handle::~usb_device_handle ( void  )
virtual
◆ firmware_loaded()
virtual bool uhd::transport::usb_device_handle::firmware_loaded ( )
Test whether the firmware is loaded on the device.
true if firmware is loaded
◆ get_device_list() [1/2]
static std::vector< usb_device_handle::sptr > uhd::transport::usb_device_handle::get_device_list ( const std::vector< usb_device_handle::vid_pid_pair_t > &  vid_pid_pair_list)
◆ get_device_list() [2/2]
static std::vector< usb_device_handle::sptr > uhd::transport::usb_device_handle::get_device_list ( uint16_t  vid,
uint16_t  pid
Return a vector of USB devices on this host
a vector of USB device handles that match vid and pid
◆ get_manufacturer()
virtual std::string uhd::transport::usb_device_handle::get_manufacturer ( ) const
Return the device's manufacturer identification string
a string describing the device's manufacturer string
◆ get_product()
virtual std::string uhd::transport::usb_device_handle::get_product ( ) const
Return the device's product identification string
a string describing the device's product string
◆ get_product_id()
virtual uint16_t uhd::transport::usb_device_handle::get_product_id ( ) const
Return the device's Product ID (usually assigned by manufacturer)
a Product ID
◆ get_serial()
virtual std::string uhd::transport::usb_device_handle::get_serial ( ) const
Return the device's serial number
a string describing the device's serial number
◆ get_vendor_id()
virtual uint16_t uhd::transport::usb_device_handle::get_vendor_id ( ) const
Return the device's Vendor ID (usually assigned by the USB-IF)
a Vendor ID
