fosphor_block_control.hpp
1//
2// Copyright 2020 Ettus Research, a National Instruments Brand
3//
4// SPDX-License-Identifier: GPL-3.0-or-later
5//
6
7#pragma once
8
9#include <uhd/config.hpp>
11
12namespace uhd { namespace rfnoc {
13
20};
21
100{
101public:
103
104 // Block registers
105 static const uint32_t REG_ENABLE_ADDR;
106 static const uint32_t REG_CLEAR_ADDR;
107 static const uint32_t REG_RANDOM_ADDR;
108 static const uint32_t REG_DECIM_ADDR;
109 static const uint32_t REG_OFFSET_ADDR;
110 static const uint32_t REG_SCALE_ADDR;
111 static const uint32_t REG_TRISE_ADDR;
112 static const uint32_t REG_TDECAY_ADDR;
113 static const uint32_t REG_ALPHA_ADDR;
114 static const uint32_t REG_EPSILON_ADDR;
115 static const uint32_t REG_WF_CTRL_ADDR;
116 static const uint32_t REG_WF_DECIM_ADDR;
117
124 virtual void set_enable_histogram(const bool enable_histogram) = 0;
125
132 virtual bool get_enable_histogram() const = 0;
133
140 virtual void set_enable_waterfall(const bool enable_waterfall) = 0;
141
148 virtual bool get_enable_waterfall() const = 0;
149
155 virtual void clear_history() = 0;
156
164 virtual void set_enable_dither(const bool enable_dither) = 0;
165
172 virtual bool get_enable_dither() const = 0;
173
181 virtual void set_enable_noise(const bool enable_noise) = 0;
182
189 virtual bool get_enable_noise() const = 0;
190
201 virtual void set_histogram_decimation(const uint16_t decimation) = 0;
202
209 virtual uint16_t get_histogram_decimation() const = 0;
210
218 virtual void set_histogram_offset(const uint16_t offset) = 0;
219
226 virtual uint16_t get_histogram_offset() const = 0;
227
235 virtual void set_histogram_scale(const uint16_t scale) = 0;
236
243 virtual uint16_t get_histogram_scale() const = 0;
244
256 virtual void set_histogram_rise_rate(const uint16_t rise_rate) = 0;
257
264 virtual uint16_t get_histogram_rise_rate() const = 0;
265
277 virtual void set_histogram_decay_rate(const uint16_t decay_rate) = 0;
278
285 virtual uint16_t get_histogram_decay_rate() const = 0;
286
296 virtual void set_spectrum_alpha(const uint16_t alpha) = 0;
297
305 virtual uint16_t get_spectrum_alpha() const = 0;
306
315 virtual void set_spectrum_max_hold_decay(const uint16_t epsilon) = 0;
316
324 virtual uint16_t get_spectrum_max_hold_decay() const = 0;
325
332 virtual void set_waterfall_predivision(
333 const fosphor_waterfall_predivision_ratio waterfall_predivision) = 0;
334
341 virtual fosphor_waterfall_predivision_ratio get_waterfall_predivision() const = 0;
342
354 virtual void set_waterfall_mode(const fosphor_waterfall_mode waterfall_mode) = 0;
355
362 virtual fosphor_waterfall_mode get_waterfall_mode() const = 0;
363
373 virtual void set_waterfall_decimation(const uint16_t waterfall_decimation) = 0;
374
381 virtual uint16_t get_waterfall_decimation() const = 0;
382};
383
384}} // namespace uhd::rfnoc
Definition: fosphor_block_control.hpp:100
Definition: noc_block_base.hpp:42
Definition: config.h:70
Definition: fosphor_block_control.hpp:15
Definition: fosphor_block_control.hpp:14
Definition: build_info.hpp:12
#define RFNOC_DECLARE_BLOCK(CLASS_NAME)
Definition: noc_block_base.hpp:21
