uhd::rfnoc::fosphor_block_control Class Referenceabstract
#include <uhd/rfnoc/fosphor_block_control.hpp>
Inheritance diagram for uhd::rfnoc::fosphor_block_control:
virtual void set_enable_histogram (const bool enable_histogram)=0
virtual bool get_enable_histogram () const =0
virtual void set_enable_waterfall (const bool enable_waterfall)=0
virtual bool get_enable_waterfall () const =0
virtual void clear_history ()=0
virtual void set_enable_dither (const bool enable_dither)=0
virtual bool get_enable_dither () const =0
virtual void set_enable_noise (const bool enable_noise)=0
virtual bool get_enable_noise () const =0
virtual void set_histogram_decimation (const uint16_t decimation)=0
virtual uint16_t get_histogram_decimation () const =0
virtual void set_histogram_offset (const uint16_t offset)=0
virtual uint16_t get_histogram_offset () const =0
virtual void set_histogram_scale (const uint16_t scale)=0
virtual uint16_t get_histogram_scale () const =0
virtual void set_histogram_rise_rate (const uint16_t rise_rate)=0
virtual uint16_t get_histogram_rise_rate () const =0
virtual void set_histogram_decay_rate (const uint16_t decay_rate)=0
virtual uint16_t get_histogram_decay_rate () const =0
virtual void set_spectrum_alpha (const uint16_t alpha)=0
virtual uint16_t get_spectrum_alpha () const =0
virtual void set_spectrum_max_hold_decay (const uint16_t epsilon)=0
virtual uint16_t get_spectrum_max_hold_decay () const =0
virtual void set_waterfall_predivision (const fosphor_waterfall_predivision_ratio waterfall_predivision)=0
virtual fosphor_waterfall_predivision_ratio get_waterfall_predivision () const =0
virtual void set_waterfall_mode (const fosphor_waterfall_mode waterfall_mode)=0
virtual fosphor_waterfall_mode get_waterfall_mode () const =0
virtual void set_waterfall_decimation (const uint16_t waterfall_decimation)=0
virtual uint16_t get_waterfall_decimation () const =0
static const uint32_t REG_ENABLE_ADDR
static const uint32_t REG_CLEAR_ADDR
static const uint32_t REG_RANDOM_ADDR
static const uint32_t REG_DECIM_ADDR
static const uint32_t REG_OFFSET_ADDR
static const uint32_t REG_SCALE_ADDR
static const uint32_t REG_TRISE_ADDR
static const uint32_t REG_TDECAY_ADDR
static const uint32_t REG_ALPHA_ADDR
static const uint32_t REG_EPSILON_ADDR
static const uint32_t REG_WF_CTRL_ADDR
static const uint32_t REG_WF_DECIM_ADDR
Fosphor Control Class
The Fosphor Block is an RFNoC block that accepts FFT data as signed complex 16-bit data and produces two streams of eight-bit data, a stream of histogram data and a stream of waterfall data.
Histogram
Each time the Fosphor block receives an FFT input packet, the power values in each of the N frequency bins are quantized into one of 64 power bins (X axis represents individual FFT frequency bins; Y axis represents the power bins):
63                                .
 0  . . . . . . . .     . . .           . .     . . . . . . .
    0 1 2 3 4 5 - - - - - - - - - - - - - - - - - - - - - - N-1
Each time an FFT power value is quantized to a bin, the bin count is increased by one (illustrated by a '+'):
63                                +
 0  + + + + + + + +     + + +           + +     + + + + + + +
As more FFT packets are received, the counts in each bin accumulate. Over time, the count in the 'closest' power bin to each sample in the FFT accumulates at the highest rate. However, adjacent power bins' counts may increase due to quantization noise and variances in the input FFT signal (highest counts illustrated by '*', followed by '+' and '.'):
63                              . * +
 0  * * * * * * * * + + * * * +       + * * + + * * * * * *
The Fosphor block also calculates the average power level and maximum power level encountered in each FFT frequency bin. The rate at which the accumulated counts, average power level, and maximum power level values rise and fall over time is configurable.
An instance of histogram data output consists of 66 packets:
  • 64 packets, one per quantized power level, of N values, representing the accumulated count for each frequency bin for that particular quantized power level;
  • One packet of N values, representing the average power level in each frequency bin; and
  • One packet of N values, representing the maximum power level in each frequency bin.
Waterfall
The waterfall stream consists of history data of either the average or maximum power level values in each bin, depending on the selected waterfall mode. In max hold mode, each waterfall packet consists of N values, representing the maximum power level in each frequency bin. The rate that packets are produced relative to the number of input FFT packets is configurable via the waterfall decimation parameter.
In average mode, each waterfall packet consists of N values, representing the sum of the average power level in each frequency bin accumulated between packets. (Thus, if the decimation rate is increased, the values returned are higher than if the decimation rate is decreased.) The waterfall predivision ratio parameter can be used to scale the values prior to accumulation to counteract this effect.
These streams are intended to be inputs to the GNU Radio Fosphor display block, which renders the streams in a entertaining graphical format.
◆ clear_history()
virtual void uhd::rfnoc::fosphor_block_control::clear_history ( )
Clear the Fosphor block's stored history
Clears the accumulated history in the Fosphor block, resetting average and max hold values.
◆ get_enable_dither()
virtual bool uhd::rfnoc::fosphor_block_control::get_enable_dither ( ) const
Get the dither enable flag
Returns the current dither enable value.
Dither enable/disable flag
◆ get_enable_histogram()
virtual bool uhd::rfnoc::fosphor_block_control::get_enable_histogram ( ) const
Get the histogram stream enable flag
Returns the current histogram enable value.
Histogram stream enable/disable flag
◆ get_enable_noise()
virtual bool uhd::rfnoc::fosphor_block_control::get_enable_noise ( ) const
Get the noise enable flag
Returns the current noise enable value.
Noise enable/disable flag
◆ get_enable_waterfall()
virtual bool uhd::rfnoc::fosphor_block_control::get_enable_waterfall ( ) const
Get the waterfall stream enable flag
Returns the current waterfall enable value.
◆ get_histogram_decay_rate()
virtual uint16_t uhd::rfnoc::fosphor_block_control::get_histogram_decay_rate ( ) const
Get the histogram decay rate factor
Returns the current histogram decay rate factor.
The histogram decay rate factor
◆ get_histogram_decimation()
virtual uint16_t uhd::rfnoc::fosphor_block_control::get_histogram_decimation ( ) const
Get the histogram decimation factor
Returns the current histogram decimation factor.
Histogram decimation factor
◆ get_histogram_offset()
virtual uint16_t uhd::rfnoc::fosphor_block_control::get_histogram_offset ( ) const
Get the histogram offset factor
Returns the current histogram offset factor.
The histogram offset factor
◆ get_histogram_rise_rate()
virtual uint16_t uhd::rfnoc::fosphor_block_control::get_histogram_rise_rate ( ) const
Get the histogram rise rate factor
Returns the current histogram rise rate factor.
The histogram rise rate factor
◆ get_histogram_scale()
virtual uint16_t uhd::rfnoc::fosphor_block_control::get_histogram_scale ( ) const
Get the history scale factor
Returns the current histogram scale factor.
The histogram scale factor
◆ get_spectrum_alpha()
virtual uint16_t uhd::rfnoc::fosphor_block_control::get_spectrum_alpha ( ) const
Get the power level moving average weighting
Returns the weighting that is applied to older samples when calculating the average power level for each FFT frequency bin.
The power level moving average weighting
◆ get_spectrum_max_hold_decay()
virtual uint16_t uhd::rfnoc::fosphor_block_control::get_spectrum_max_hold_decay ( ) const
Get the maximum hold decay rate
Returns the rate at which the maximum value for each FFT frequency bin decays.
The maximum hold decay rate
◆ get_waterfall_decimation()
virtual uint16_t uhd::rfnoc::fosphor_block_control::get_waterfall_decimation ( ) const
Returns the current waterfall decimation factor.
The waterfall decimation factor
◆ get_waterfall_mode()
virtual fosphor_waterfall_mode uhd::rfnoc::fosphor_block_control::get_waterfall_mode ( ) const
Get the waterfall mode setting
Returns the current waterfall mode setting.
The waterfall mode setting
◆ get_waterfall_predivision()
virtual fosphor_waterfall_predivision_ratio uhd::rfnoc::fosphor_block_control::get_waterfall_predivision ( ) const
Get the waterfall predivision ratio
Returns the current waterfall predivision ratio.
◆ set_enable_dither()
virtual void uhd::rfnoc::fosphor_block_control::set_enable_dither ( const bool  enable_dither)
Set the dither enable flag
Enables or disables dithering. Dithering adds quantization error to the incoming signal.
enable_ditherDither enable/disable flag
◆ set_enable_histogram()
virtual void uhd::rfnoc::fosphor_block_control::set_enable_histogram ( const bool  enable_histogram)
Set the histogram stream enable flag
Enables or disables the stream of histogram data from the block.
enable_histogramHistogram stream enable/disable flag
◆ set_enable_noise()
virtual void uhd::rfnoc::fosphor_block_control::set_enable_noise ( const bool  enable_noise)
Set the noise enable flag
Enables or disables the addition of random noise to the incoming signal.
enable_noiseNoise enable/disable flag
◆ set_enable_waterfall()
virtual void uhd::rfnoc::fosphor_block_control::set_enable_waterfall ( const bool  enable_waterfall)
Set the waterfall stream enable flag
Enables or disables the stream of waterfall data from the block.
enable_waterfallHistogram stream enable/disable flag
◆ set_histogram_decay_rate()
virtual void uhd::rfnoc::fosphor_block_control::set_histogram_decay_rate ( const uint16_t  decay_rate)
Set the histogram decay rate factor
Sets the rate at which the hit count in each frequency and power bin decreases when not accumulating (i.e., there are no hits in the particular bin). The lower the value, the more slowly the values decrease, leading to a phosphorescent-like effect on the Fosphor display similar to the gradual fading of a CRT display when the electron beam is extinguished.
decay_rateThe histogram decay rate factor to apply
◆ set_histogram_decimation()
virtual void uhd::rfnoc::fosphor_block_control::set_histogram_decimation ( const uint16_t  decimation)
Set the histogram decimation factor
Sets the ratio of histogram outputs to FFT packet inputs. For every decimation FFT input packets, one histogram output cluster (64 histogram packets, plus a maximum and average values packet) is produced. The minimum value for decimation is 2.
decimationHistogram decimation factor
◆ set_histogram_offset()
virtual void uhd::rfnoc::fosphor_block_control::set_histogram_offset ( const uint16_t  offset)
Set the histogram offset factor
Sets the offset factor to apply to FFT power levels before determining the appropriate histogram bin.
offsetThe histogram offset factor to apply
◆ set_histogram_rise_rate()
virtual void uhd::rfnoc::fosphor_block_control::set_histogram_rise_rate ( const uint16_t  rise_rate)
Set the histogram rise rate factor
Sets the rate at which the hit count in each frequency and power bin increases when accumulating (i.e., there are hits in the particular bin). The higher the value, the more quickly the values increase, leading to a phosphorescent-like effect on the Fosphor display similar to the gradual illumination of a CRT display in the area where the electron beam is pointing.
rise_rateThe histogram rise rate factor to apply
◆ set_histogram_scale()
virtual void uhd::rfnoc::fosphor_block_control::set_histogram_scale ( const uint16_t  scale)
Set the histogram scale factor
Sets the scale factor to apply to FFT power levels before determining the appropriate histogram bin. The scaling factor is scale / 256.
scaleThe histogram scale factor to apply
◆ set_spectrum_alpha()
virtual void uhd::rfnoc::fosphor_block_control::set_spectrum_alpha ( const uint16_t  alpha)
Set the power level moving average weighting
Sets the weighing to be applied to the average power level value for each FFT frequency bin. The higher the value, the higher the weight is given to older samples (and thus the more slowly the average values change over time in each bin).
alphaThe power level moving average weighting to apply
◆ set_spectrum_max_hold_decay()
virtual void uhd::rfnoc::fosphor_block_control::set_spectrum_max_hold_decay ( const uint16_t  epsilon)
Set the maximum hold decay rate
Sets the rate at which the maximum value for each FFT frequency bin decays. The higher the value, the faster the decay rate. A value of 0 retains the maximum values indefinitely.
epsilonThe histogram scale factor to apply
◆ set_waterfall_decimation()
virtual void uhd::rfnoc::fosphor_block_control::set_waterfall_decimation ( const uint16_t  waterfall_decimation)
Set the waterfall decimation factor
Sets the ratio of waterfall outputs to FFT packet inputs. For every waterfall_decimation FFT input packets, one waterfall output packet is produced. The minimum value for waterfall_decimation is 2.
waterfall_decimationThe waterfall decimation factor to apply
◆ set_waterfall_mode()
virtual void uhd::rfnoc::fosphor_block_control::set_waterfall_mode ( const fosphor_waterfall_mode  waterfall_mode)
Set the waterfall mode setting
Sets the source of the waterfall history data. When waterfall_mode is set to MAX_HOLD, the waterfall data is comprised of the max power values from each FFT frequency bin. When waterfall_mode is set to AVERAGE, the waterfall data is comprised of the accumulated average value from each FFT frequency bin between waterfall output packets.
waterfall_modeThe waterfall mode setting
◆ set_waterfall_predivision()
virtual void uhd::rfnoc::fosphor_block_control::set_waterfall_predivision ( const fosphor_waterfall_predivision_ratio  waterfall_predivision)
Set the waterfall predivision ratio
Sets the scaling factor applied to waterfall values.
waterfall_predivisionThe waterfall predivision ratio to apply
◆ REG_ALPHA_ADDR
const uint32_t uhd::rfnoc::fosphor_block_control::REG_ALPHA_ADDR
◆ REG_CLEAR_ADDR
const uint32_t uhd::rfnoc::fosphor_block_control::REG_CLEAR_ADDR
◆ REG_DECIM_ADDR
const uint32_t uhd::rfnoc::fosphor_block_control::REG_DECIM_ADDR
◆ REG_ENABLE_ADDR
const uint32_t uhd::rfnoc::fosphor_block_control::REG_ENABLE_ADDR
◆ REG_EPSILON_ADDR
const uint32_t uhd::rfnoc::fosphor_block_control::REG_EPSILON_ADDR
◆ REG_OFFSET_ADDR
const uint32_t uhd::rfnoc::fosphor_block_control::REG_OFFSET_ADDR
◆ REG_RANDOM_ADDR
const uint32_t uhd::rfnoc::fosphor_block_control::REG_RANDOM_ADDR
◆ REG_SCALE_ADDR
const uint32_t uhd::rfnoc::fosphor_block_control::REG_SCALE_ADDR
◆ REG_TDECAY_ADDR
const uint32_t uhd::rfnoc::fosphor_block_control::REG_TDECAY_ADDR
◆ REG_TRISE_ADDR
const uint32_t uhd::rfnoc::fosphor_block_control::REG_TRISE_ADDR
◆ REG_WF_CTRL_ADDR
const uint32_t uhd::rfnoc::fosphor_block_control::REG_WF_CTRL_ADDR
◆ REG_WF_DECIM_ADDR
const uint32_t uhd::rfnoc::fosphor_block_control::REG_WF_DECIM_ADDR
