uhd::usrp Namespace Reference
Namespaces
namespace  cal
namespace  gpio_atr
Classes
struct  component_file_t
class  dboard_base
struct  dboard_eeprom_t
class  dboard_id_t
class  dboard_iface
struct  dboard_iface_special_props_t
 Special properties that differentiate this daughterboard slot. More...
class  dboard_manager
class  fe_connection_t
class  multi_usrp
class  rx_dboard_base
struct  subdev_spec_pair_t
class  subdev_spec_t
class  tx_dboard_base
class  xcvr_dboard_base
Typedefs
typedef std::vector< component_file_tcomponent_files_t
typedef uhd::dict< std::string, std::string > mboard_eeprom_t
Functions
UHD_API bool operator== (const dboard_id_t &lhs, const dboard_id_t &rhs)
UHD_API bool operator== (const fe_connection_t &lhs, const fe_connection_t &rhs)
UHD_API bool operator== (const subdev_spec_pair_t &, const subdev_spec_pair_t &)
 overloaded comparison operator for subdev_spec_pair_t More...
Typedef Documentation
◆ component_files_t
◆ mboard_eeprom_t
typedef uhd::dict<std::string, std::string> uhd::usrp::mboard_eeprom_t
The motherboard EEPROM object.
The specific implementation knows how to read and write the EEPROM for various USRPs. By itself, this class is nothing but a thin wrapper around a string -> string dictionary.
Note that writing to an object of type mboard_eeprom_t does not actually write to the EEPROM. Devices have their own APIs to read/write from the EEPROM chips themselves. Most devices will write the EEPROM itself when the according property is updated.
Function Documentation
◆ operator==() [1/3]
UHD_API bool uhd::usrp::operator== ( const dboard_id_t lhs,
const dboard_id_t rhs
Comparator operator overloaded for dboard ids. The boost::equality_comparable provides the !=.
lhsthe dboard id to the left of the operator
rhsthe dboard id to the right of the operator
true when the dboard ids are equal
◆ operator==() [2/3]
UHD_API bool uhd::usrp::operator== ( const fe_connection_t lhs,
const fe_connection_t rhs
Comparator operator overloaded for fe_connection_t. The boost::equality_comparable provides the !=.
lhsthe fe_connection_t to the left of the operator
rhsthe fe_connection_t to the right of the operator
true when the fe connections are equal
◆ operator==() [3/3]
UHD_API bool uhd::usrp::operator== ( const subdev_spec_pair_t ,
