Building and Installing UHD from source
Build Dependencies
C++ Compiler
  • GCC >= 6.3.0
  • Clang >= 6.0.0
  • MSVC >= 15.0; the free version works. Users need to install the "Desktop Development with C++" Workload for Visual Studio. On Windows, it can be found in: Tools -> Get Tools and Features... -> Workloads -> Windows
CMake
For Windows users, copy the CMake file to Program Files, e.g. C:\Program Files\cmake-3.13.4-win32-x86. The CMake path, e.g. C:\Program Files\cmake-3.13.4-win32-x86\bin needs to be added to the environment variables.
Boost
The Boost binary installer must be selected to match the architecture of Windows being run.
LibUSB
The directory to which you extract libusb must not contain spaces. This is to say that C:\local\lib usb-1.0.22 will cause compile issues moving forward.
Python
  • Purpose: Used by mako build time, and utility scripts and the Python API at runtime
  • Minimum Version: 3.5
  • Usage: build time + runtime utility scripts (required)
  • Download URL: http://www.python.org/download/
  • Comments for Windows Users:
    • The Python binary installer must be selected to match the system processor. Although, the 32-bit Python version can be used with 32-bit or 64-bit Windows system, it is recommended to match between Python and Windows installers. If the system is occupied with 64-bit Windows and x64-based processor, the Windows x86-64 MSI Installer -> python-version.amd64.msi needs to be used.
    • The Python path needs to be added to the environment variables.
    • Install fundamental packages for Python: On Windows Terminal, navigate to Python scripts folder, e.g. C:\local\Python37\Scripts, and execute the following commands to install requests and numpy packages, respectively:
      pip3 install requests pip3 install numpy pip3 install ruamel.yaml pip3 install setuptools
    • For curses package installation:
      • Download URL: https://www.lfd.uci.edu/~gohlke/pythonlibs/
      • Download a package that is similar to the Python version, Windows System, and system processor and copy it to Python scripts folder. For example, for Python 3.7, 64-bit Windows, and x64-based processor, download the curses-2.2-cp37-cp37m-win_amd64.whl.
      • Install the package dependency, wheel package:
      pip3 install wheel
      • Install the curses package and include it to Python scripts:
      python3 -m pip3 install curses-2.2-cp37-cp37m-win_amd64.whl
Mako
  • Purpose: source code generation
  • Minimum Version: 0.4.2
  • Usage: build time (required)
  • Download URL: http://www.makotemplates.org/download.html
  • Alternative method: You can use pip3 or easy_install to install Mako from PyPi. To install it using 'pip3' on Windows, navigate to Python scripts folder, e.g. C:\local\Python37\Scripts, and run the following command:
    pip3 install mako
Doxygen
NSIS
  • Purpose: create Windows installers. It is used to create binary packages of UHD enabling easy distribution and installation of UHD, associated utilities, and examples.
  • Recommended Version: 3.04
  • Usage: build time (optional)
  • Download URL (Windows): https://nsis.sourceforge.io/Download
Git
On Windows, install Cygwin from https://www.cygwin.com/ with Git support to checkout the repository or install msysGit from http://code.google.com/p/msysgit/downloads/list.
Setting up the dependencies on Ubuntu
sudo apt-get install autoconf automake build-essential ccache cmake cpufrequtils doxygen ethtool \
g++ git inetutils-tools libboost-all-dev libncurses5 libncurses5-dev libusb-1.0-0 libusb-1.0-0-dev \
libusb-dev python3-dev python3-mako python3-numpy python3-requests python3-scipy python3-setuptools \
python3-ruamel.yaml
Setting up the dependencies on Fedora
sudo yum -y install boost-devel libusb1-devel doxygen python3-docutils python3-mako python3-numpy python3-requests python3-ruamel-yaml python3-setuptools cmake make gcc gcc-c++
or
sudo dnf -y install boost-devel libusb1-devel doxygen python3-docutils python3-mako python3-numpy python3-requests python3-ruamel-yaml python3-setuptools cmake make gcc gcc-c++
Getting the source code
The UHD source is stored in a git repository. To download it, follow these instructions:
Our source code repository contains of the following branches:
  • master: This is the main development branch, with updated new features and bug fixes.
  • UHD-*: These branches are created from master upon a release or release candidate. They are used to create releases within a stable release cycle, and usually only receive bugfixes. For example, all 3.14.* releases are taken from the same branch (UHD-3.14). These branches usually no longer receive updates once the following major release branch is created (for example, when the UHD-3.14 branch was created, the UHD-3.13 branch would only receive updates under special circumstances).
  • UHD-*.LTS: These are long-term support branches. They serve the same purpose as the other UHD-* branches, but generally receive bugfixes for much longer.
Using PyBOMBS
$ pybombs install uhd
Build Instructions (Unix)
Generate Makefiles with CMake
cd <uhd-repo-path>/host
mkdir build
cd build
cmake ../
  • For a custom install prefix: -DCMAKE_INSTALL_PREFIX=<install-path>
  • To install libs into lib64: cmake -DLIB_SUFFIX=64
Example usage:
Ubuntu 20.04 note: When building for Ubuntu 20.04, you may run into errors such as this during CMake's generation stage:
CMake Error in python/CMakeLists.txt:
Imported target "Boost::chrono" includes non-existent path
"/include"
in its INTERFACE_INCLUDE_DIRECTORIES.  Possible reasons include:
  The path was deleted, renamed, or moved to another location.
  An install or uninstall procedure did not complete successfully.
  The installation package was faulty and references files it does not
  provide.
These errors occur when CMake finds filesystem items by following the /bin symlink to /usr/bin and thus incorrectly calculating the root path for various directories needed by the build.
If you encounter this issue, ensure that /usr/bin appears before /bin in the PATH environment variable of the process executing CMake. Alternatively, you can pass the CMAKE_FIND_ROOT_PATH configuration variable to CMake with a value of /usr to point it to the right starting directory for filesystem item searches.
Example usage:
cmake -DCMAKE_FIND_ROOT_PATH=/usr ../
Build and install
make
make test # This step is optional
sudo make install
Setup the library path (Linux)
sudo ldconfig
Compiling for ARM platforms
When compiling for ARM platforms, the assumption is made that NEON extensions are available if the arm_neon.h header is found. However, this might not be true, e.g., when cross-compiling for an arm7l target (e.g., the Odroid XU4) using a standard SDK. In this case, it's necessary to tell CMake to disable NEON extensions:
cmake -DNEON_SIMD_ENABLE=OFF [...]
Build Instructions (Windows)
Generate the project with CMake
  • Make sure the version of Python that CMake detects matches the version you want it to be (check the PYTHON_VERSION variable)
  • Open the CMake GUI.
  • Set the path to the source code: <uhd-repo-path>/host.
  • Set the path to the build directory (this may require creating the folder \build\): <uhd-repo-path>\host\build.
  • Make sure that the paths do not contain spaces.
  • Check the Advanced checkbox.
  • Click "Configure".
    • Set "Microsoft Visual Studio 10" as the compiler. Select the recent MSVC that is available on the machine.
    • Click “Finish” and allow CMake to Generate
  • Set or add the build variables with type PATH
    • Boost_INCLUDE_DIR should point to the PATH where the Boost .hpp files are, e.g. C:\local\boost_version\
    • Boost_LIBRARY_DIR should point to the pre-built libraries, e.g. C:\local\boost_version\lib64-msvc-14.0)
  • If a release UHD build is required:
    • Click on "Generate", and a project file will be created in the build directory.
  • If a debug UHD build is required:
    • Click on Grouped
    • Click on CMAKE
    • Look for the parameter CMAKE_BUILD_TYPE: Release and change it to CMAKE_BUILD_TYPE: Debug.
Compile and Install with Visual Studio
  • Open the <uhd-repo-path>\host\build\ALL_BUILD.vcxproj in visual studio, generate the project. Watch the output console for errors.
  • If you did not specify a CMAKE_INSTALL_PREFIX where your user has write privileges, you must close Visual Studio, run it again with Administrator Privileges, and open ALL_BUILD.vcxproj.
  • Right click on the INSTALL project in the project explorer, generate it. Watch the output console for errors.
LibUSB notes
On Windows, CMake does not have the advantage of pkg-config, so we must manually tell CMake how to locate the LibUSB header and lib.
  • From the CMake GUI, select "Advanced View".
  • Set or add the following entry with type PATH LIBUSB_INCLUDE_DIRS to the directory for libusb.h, e.g. C:\local\libusb-1.0.22\include\libusb-1.0.
  • Set or add the following entry with type FILEPATH LIBUSB_LIBRARIES to the full path for libusb-1.0.lib, e.g. C:\local\libusb-1.0.22\MS64\dll\libusb-1.0.lib.
  • Recommend the static libusb-1.0.lib to simplify runtime dependencies.
  • Check the box to enable USB support, click "Configure" and "Generate".
Note: On Windows, LibUSB v1.0.19 is required to use most USB3 controllers.
Build the project in MSVC
  • Open the generated project file in MSVC, e.g. C:\cygwin64\home\admin\uhd\host\build\UHD.sln.
  • Change the build type from "Debug" to "Release".
  • Select the "Build All" target, right-click, and choose "Build".
  • Select the install target, right-click, and choose "Build".
Build the project in MSVC (command line)
cd <uhd-repo-path>\host\build
DevEnv uhd.sln /build Release /project ALL_BUILD
DevEnv uhd.sln /build Release /project INSTALL
Compiling a binary installer
  • Building the "PACKAGE" project will produce a binary installer if NSIS is installed. This installer will be for either 64 bit or 32 bit as chosen during the CMake step.
  • Select the "PACKAGE" project in the Solution Explorer, right-click, and choose "Build".
Setup the PATH environment variable
Add the UHD bin path to PATH% (usually C:\Program Files\UHD\bin)
X11/XQuartz or Terminal
Xcode
xcode-select --install
Background Dependencies
sudo port install uhd
sudo port uninstall uhd
NOTE: Other package managers (e.g., Fink, HomeBrew) will require different commands than the above to install all dependencies and then remove the UHD install. Please consult the specific package manager in use for how to do these commands properly; they will not be covered here.
Compiling UHD from Source
$ mkdir build
$ cd build
$ CC=/usr/bin/llvm-gcc CXX=/usr/bin/llvm-g++ cmake -DCMAKE_INSTALL_PREFIX=/opt/local -DPYTHON_EXECUTABLE=/opt/local/bin/python2.7 -DPYTHON_INCLUDE_DIR=/opt/local/Library/Frameworks/Python.framework/Versions/2.7/Headers -DPYTHON_LIBRARY=/opt/local/Library/Frameworks/Python.framework/Versions/2.7/Python ../host
$ make
$ make test
To install the build, issue
$ sudo make install
Post-Install Tasks
  • After installing, you might want to download the FPGA images packages by running uhd_images_downloader on the command line, or one of these executables (the actual path may differ based on your installation):
    • Linux: /usr/local/lib/uhd/utils/uhd_images_downloader.py
    • Windows: C:\Program Files\share\uhd\utils\uhd_images_downloader.py
    • Mac OS X: In MacPorts, when UHD is installed the images are automatically downloaded and installed into their proper location. For any other package manager or install method, you should execute the uhd_images_downloader.py script to get the images installed appropriately.
  • For USB-Based devices, make sure to read USB Transport (LibUSB) for platform-specific post-installation tasks.
Building applications that require UHD using CMake
find_package(UHD "3.10.0")
Static Builds
