Here is a list of a changes with the latest E310 filesystem (UHD v3.15.0.0) that can affect customer usage and applications:
ni-e31x-$serial. This makes it easier to identify devices. You can change the hostname by modifying the /etc/hostname file and rebooting.FPGA bit/bin/rpt file name and image target:
| FPGA type | Old filename | New filename |
| IDLE Image (power saving mode) SG1 | usrp_e3xx_fpga_idle.bit | usrp_e310_sg1_idle_fpga.bit |
| IDLE Image (power saving mode) SG3 | usrp_e3xx_fpga_idle_sg3.bit | usrp_e310_sg3_idle_fpga.bit |
| NORMAL Image SG1 | usrp_e310_fpga.bit | usrp_e310_sg1_fpga.bit |
| NORMAL Image SG3 | usrp_e310_fpga_sg3.bit | usrp_e310_sg3_fpga.bit |
The names of the FPGA build targets have been modified but the old FPGA targets would continue to work as before. The generated bit files names in the build directory will be new as mentioned above.
| FPGA Image Flavor | SFP+ Port 0 Interface |
| 1G (Default) | 1 Gigabit Ethernet |
| XG | 10 Gigabit Ethernet |
| AA | Aurora |
[sudo] uhd_images_downloader
uhd_image_loader -a type=e3xx,addr=<IP Address>,fpga=XG
Checklist:
For E310:
$ ls /dev/serial/by-id /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_DQ0041HO-if00-port0
For E320:
$ ls /dev/serial/by-id /dev/serial/by-id/usb-FTDI_Dual_RS232-HS-if00-port0 /dev/serial/by-id/usb-FTDI_Dual_RS232-HS-if01-port0 /dev/serial/by-id/usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6A6C-if00-port0 /dev/serial/by-id/usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6A6C-if01-port0
For E310:
For E320:
Note: The device's hostname is derived from its serial number by default (ni-<e31x/e320>-<SERIAL>). You can change the hostname by modifying the /etc/hostname file and rebooting.
eth0 (DHCP):
    [Match]
    Name=eth0
    [Network]
    DHCP=v4
    [DHCPv4]
    UseHostname=false
E320 has an extra SFP+ (sfp0) port which is configured with static address 192.168.10.2/24. The configuration for the sfp0 port is stored in /etc/systemd/networkd/sfp0.network.
sfp0 (static):
    [Match]
    Name=sfp0
    [Network]
    Address=192.168.10.2/24
    [Link]
    MTUBytes=9000
Note: Care needs to be taken when editing these files on the device, since vi / vim sometimes generates undo files (e.g. /etc/systemd/networkd/sfp0.network~), that systemd-networkd might accidentally pick up.
master_clock_rate=13.2e6, rx_rate=4.4e6master_clock_rate=19.6e6, rx_rate=6.4e6The E320 ships without a root password set. It is possible to ssh into the device by simply connecting as root, and thus gaining access to all subsystems. To set a password, run the command
$ passwd
on the device.
$ uhd_images_downloader
$ uhd_image_loader --help
| addr | IPv4 address of primary SFP+/RJ-45 port to connect to | addr=192.168.30.2 |
| master_clock_rate | Master Clock Rate in Hz. Default is 16 MHz. | master_clock_rate=30.72e6 |
Like other USRPs, the E310 series has RF and motherboard sensors. When using uhd::usrp::multi_usrp, the following API calls are relevant to interact with the sensor API:
temp_fpga: temperature (in Celsius) of the FPGA dietemp_mb: temperature (in Celsius) of the motherboardref_locked: This will check that all the daughter boards have locked to the reference clock.Like other USRPs, the E320 series has RF and motherboard sensors. When using uhd::usrp::multi_usrp, the following API calls are relevant to interact with the sensor API:
temp_internal: temperature (in Celsius) of Temperature Sensor on boardtemp_fpga: temperature (in Celsius) of the FPGA dietemp_rf_channelA: temperature (in Celsius) near power amplifier RF Atemp_rf_channelB: temperature (in Celsius) near power amplifier RF Btemp_main_power: temperature (in Celsius) near power supplygps_locked: GPS lockgps_time: GPS time in seconds sin ce the epchgps_tpv: A TPV report from GPSd serialized as JSONgps_sky: A SKY report from GPSd serialized as JSONref_locked: This will check that all the daughter boards have locked to the external/internal reference clock.fan: get fan speed (in rpm)Mender is a third-party software that enables remote updating of the root file system without physically accessing the device (see also the Mender website). Mender can be executed locally on the device, or a Mender server can be set up which can be used to remotely update an arbitrary number of USRP devices. Mender servers can be self-hosted, or hosted by Mender (see mender.io for pricing and availability).
$ reboot
$ mender commit
$ systemctl start salt-minion
apt install salt-master if the server is an Ubuntu system), and make sure the Salt master is running./etc/salt/minion file on the device by editing the master: line.systemctl start salt-minion.salt-key -a $hostname where $hostname is the name of the minion.Note: Do not source high currents (more than 5 mA) per pin. The GPIOs are not designed to drive high loads!
Note: Unlike the X300 series, the E3XX series does not have user-programmable daughterboard GPIOs. The front-panel GPIOs can still be used to track the ATR state of the radios, though (see below).
e320_bist -h
e320_bist gpsdo
$ mkdir uhd # Create a new, empty directory called uhd $ sshfs user@yourcomputer:src/uhd uhd # This will mount ~/src/uhd from the remote machine to ~/uhd on the device
$ mkdir build_mpm $ cd build_mpm # You are now in /home/root/build_mpm $ cmake -DMPM_DEVICE=e320 ../uhd/mpm $ make -j2 install # This will take several minutes
$ $CC -dumpmachine
$ cmake -DCMAKE_TOOLCHAIN_FILE=../host/cmake/Toolchains/oe-sdk_cross.cmake -DCMAKE_INSTALL_PREFIX=/usr .. # Add any CMake options you desire $ make # You can run make -j12 to compile on 12 processes at onceNote: The UHD you are cross-compiling will not run on your host computer (the one where you're doing the development). Compiling UHD regularly on your host computer (with MPMD enabled) will allow you to talk to your device.
The device provides a 3.3V supply voltage to an external antenna connected to the GPS port of your device. Note that this supply voltage is turned off in order to safe power upon destruction of the software object.
The pins are as follows:
and for the charger:
Type:
Receive
| RX Port | RX Filter (MHz) | VCTXRX2_V1,V2 | VCRX2_V1,V2 | RX2_BANDSEL[2:0] | RX2B_BANDSEL[1:0] | RX2C_BANDSEL[1:0] |
| TRX-A | < 450 | 01 | 10 | 101 | XX | 01 |
| TRX-A | 450 – 700 | 01 | 10 | 011 | XX | 11 |
| TRX-A | 700 – 1200 | 01 | 10 | 001 | XX | 10 |
| TRX-A | 1200 – 1800 | 01 | 10 | 000 | 01 | XX |
| TRX-A | 1800 – 2350 | 01 | 10 | 010 | 11 | XX |
| TRX-A | 2350 – 2600 | 01 | 10 | 100 | 10 | XX |
| TRX-A | 2600 – 6000 | 01 | 01 | XXX | XX | XX |
| RX2-A | 70 – 450 | TT | 01 | 101 | XX | 01 |
| RX2-A | 450 – 700 | TT | 01 | 011 | XX | 11 |
| RX2-A | 700 – 1200 | TT | 01 | 001 | XX | 10 |
| RX2-A | 1200 – 1800 | TT | 01 | 000 | 01 | XX |
| RX2-A | 1800 – 2350 | TT | 01 | 010 | 11 | XX |
| RX2-A | 2350 – 2600 | TT | 01 | 100 | 10 | XX |
| RX2-A | >= 2600 | TT | 10 | XXX | XX | XX |
Transmit
| TX Port | TX Filter (MHz) | VCTXRX2_V1,V2 | TX_ENABLE2A,2B | TX_BANDSEL[2:0] |
| TRX-A | < 117.7 | 10 | 01 | 111 |
| TRX-A | 117.7 – 178.2 | 10 | 01 | 110 |
| TRX-A | 178.2 – 284.3 | 10 | 01 | 101 |
| TRX-A | 284.3 – 453.7 | 10 | 01 | 100 |
| TRX-A | 453.7 – 723.8 | 10 | 01 | 011 |
| TRX-A | 723.8 – 1154.9 | 10 | 01 | 010 |
| TRX-A | 1154.9 – 1842.6 | 10 | 01 | 001 |
| TRX-A | 1842.6 – 2940.0 | 10 | 01 | 000 |
| TRX-A | >= 2940.0 | 11 | 10 | XXX |
Receive
| RX Port | RX Filter (MHz) | VCTXRX1_V1,V2 | VCRX1_V1,V2 | RX1_BANDSEL[2:0] | RX1B_BANDSEL[1:0] | RX1C_BANDSEL[1:0] |
| TRX-B | < 450 | 10 | 01 | 100 | XX | 10 |
| TRX-B | 450 – 700 | 10 | 01 | 010 | XX | 11 |
| TRX-B | 700 – 1200 | 10 | 01 | 000 | XX | 01 |
| TRX-B | 1200 – 1800 | 10 | 01 | 001 | 10 | XX |
| TRX-B | 1800 – 2350 | 10 | 01 | 011 | 11 | XX |
| TRX-B | 2350 – 2600 | 10 | 01 | 101 | 01 | XX |
| TRX-B | 2600 – 6000 | 10 | 10 | XXX | XX | XX |
| RX2-B | 70 – 450 | TT | 01 | 100 | XX | 10 |
| RX2-B | 450 – 700 | TT | 01 | 010 | XX | 11 |
| RX2-B | 700 – 1200 | TT | 01 | 000 | XX | 01 |
| RX2-B | 1200 – 1800 | TT | 01 | 001 | 10 | XX |
| RX2-B | 1800 – 2350 | TT | 01 | 011 | 11 | XX |
| RX2-B | 2350 – 2600 | TT | 01 | 101 | 01 | XX |
| RX2-B | >= 2600 | TT | 10 | XXX | XX | XX |
Transmit
| TX Port | TX Filter (MHz) | VCTXRX1_V1,V2 | TX_ENABLE1A,1B | TX1_BANDSEL[2:0] |
| TRX-B | < 117.7 | 00 | 01 | 111 |
| TRX-B | 117.7 – 178.2 | 00 | 01 | 110 |
| TRX-B | 178.2 – 284.3 | 00 | 01 | 101 |
| TRX-B | 284.3 – 453.7 | 00 | 01 | 100 |
| TRX-B | 453.7 – 723.8 | 00 | 01 | 011 |
| TRX-B | 723.8 – 1154.9 | 00 | 01 | 010 |
| TRX-B | 1154.9 – 1842.6 | 00 | 01 | 001 |
| TRX-B | 1842.6 – 2940.0 | 00 | 01 | 000 |
| TRX-B | >= 2940.0 | 11 | 10 | XXX |
| GPIO | Mini HDMI (Type C) | HDMI (Type A) |
| Data[0] | Data 0+ - Pin 8 | Pin 7 |
| Data[1] | Data 0- - Pin 9 | Pin 9 |
| Data[2] | Clock 0+ - Pin 11 | Pin 10 |
| Data[3] | Clock 0- - Pin 12 | Pin 12 |
| Data[4] | CEC - Pin 14 | Pin 13 |
| Data[5] | SCL - Pin 15 | Pin 15 |
| Data[6] | SDA - Pin 16 | Pin 16 |
| Data[7] | Utility - Pin 17 | Pin 14 |
EEPROM flags can be set with
$ eeprom-set-flags 0xFLAGS
| Bit | Description |
| 0 | Auto-boot (1=on) |
| 1 | Fan (1=present) |
| 2 | TPM (0=present) |
| 3 | Enclosure (1=present) |
$ eeprom-set-flags 0x3
| Slave 0 | 4000_0000 - 4000_3fff | - | Ethernet DMA SFP (only for E320) |
| Slave 1 | 4000_4000 - 4000_4fff | misc-enet-regs | Ethernet registers SFP (only for E320) |
| Slave 2 | 4001_0000 - 4001_3fff | mboard-regs | Motherboard control |
| Slave 3 | 4001_4000 - 4001_41ff | dboard-regs | Daughterboard control |
| Slave 0 | axi_eth_dma | 4000_0000 - 4000_4fff | Ethernet DMA | RW | See Linux Driver (only on E320) |
| Slave 1 | e320_mgt_io_core | 4000_4000 | PORT_INFO | RO | SFP port information |
| e320_mgt_io_core | 4000_4004 | MAC_CTRL_STATUS | RW | Control 10gE and Aurora mac | |
| e320_mgt_io_core | 4000_4008 | PHY_CTRL_STATUS | RW | Phy reset control | |
| e320_mgt_io_core | 4000_400C | MAC_LED_CTL | RW | Used by ethtool to indicate port | |
| e320_mgt_io_core | 4000_4020 | AURORA_OVERUNS | RO | - | |
| 4000_600c | [1] my_icmp_type, [0] my_icmp_code | - | |||
| Slave 2 | e3xx_core | 4001_0000 | COMPAT_NUM | R | FPGA Compat Number |
| 4001_0018 | CLOCK_CTRL | - | |||
| [0] | pps select (internal 10 MHz) | RW | One-hot encoded pps_select to use the internal PPS from GPSDO | ||
| [1] | pps select (external 10 MHz) | RW | One-hot encoded pps_select to use the external PPS. | ||
| [2] | refclk_select (internal/external 10 MHz) | RW | refclk_select=0 for internal (GPSDO) 10 MHz, refclk_sel=1 for external 10 MHz. | ||
| [11:0] | FPGA temperature | RO | - | ||
| 4001_0028 | SFP_PORT_INFO | RO | Same as port_info register 0x4000_4000 | ||
| 4001_002C | FP_GPIO_CTRL | RW | - | ||
| 4001_0030 | FP_GPIO_MASTER | RW | GPIO master select bits. One bit per GPIO. LSB is for GPIO 0. Set bit to 0 for Radio, 1 for PS. | ||
| 4001_0034 | FP_GPIO_RADIO_SRC | RW | Radio channel source select bits. Two bits per GPIO. Bits [1:0] are for GPIO 0. Set to 00 for channel 0, 01 for channel 1, etc. | ||
| 4001_0038 | GPS_CTRL | RW | E320 Only | ||
| [0] | GPS_PWR_EN | RW | Power on GPSDO | ||
| [1] | GPS_RST_N | RW | - | ||
| [2] | GPS_INITSURV_N | RW | - | ||
| 4001_003C | GPS_STATUS | RO | GPSDO Status, E320 Only | ||
| [0] | GPS_LOCK | RO | Returns 1 if GPSDO is locked | ||
| [1] | GPS_ALARM | RO | - | ||
| [2] | GPS_PHASELOCK | RO | - | ||
| [3] | GPS_SURVEY | RO | - | ||
| [4] | GPS_WARMUP | RO | - | ||
| 4001_0040 | DBOARD_CTRL | RO | - | ||
| 4001_0044 | DBOARD_STATUS | RO | - | ||
| Slave 4 | 4001_4000 | 4001_41FF | Daughterboard Registers | - | Don't exist now. TBD |
