sensors.h File Reference
#include <uhd/config.h>
#include <uhd/error.h>
Typedefs
typedef struct uhd_sensor_value_t * uhd_sensor_value_handle
 C-level interface for a UHD sensor. More...
Enumerations
enum  uhd_sensor_value_data_type_t { UHD_SENSOR_VALUE_BOOLEAN = 98 , UHD_SENSOR_VALUE_INTEGER = 105 , UHD_SENSOR_VALUE_REALNUM = 114 , UHD_SENSOR_VALUE_STRING = 115 }
 Sensor value types. More...
Functions
UHD_API uhd_error uhd_sensor_value_make (uhd_sensor_value_handle *h)
 Make an empty UHD sensor value. More...
UHD_API uhd_error uhd_sensor_value_make_from_bool (uhd_sensor_value_handle *h, const char *name, bool value, const char *utrue, const char *ufalse)
 Make a UHD sensor from a boolean. More...
UHD_API uhd_error uhd_sensor_value_make_from_int (uhd_sensor_value_handle *h, const char *name, int value, const char *unit, const char *formatter)
 Make a UHD sensor from an integer. More...
UHD_API uhd_error uhd_sensor_value_make_from_realnum (uhd_sensor_value_handle *h, const char *name, double value, const char *unit, const char *formatter)
 Make a UHD sensor from a real number. More...
UHD_API uhd_error uhd_sensor_value_make_from_string (uhd_sensor_value_handle *h, const char *name, const char *value, const char *unit)
 Make a UHD sensor from a string. More...
UHD_API uhd_error uhd_sensor_value_free (uhd_sensor_value_handle *h)
 Free the given sensor handle. More...
UHD_API uhd_error uhd_sensor_value_to_bool (uhd_sensor_value_handle h, bool *value_out)
 Get the sensor's value as a boolean. More...
UHD_API uhd_error uhd_sensor_value_to_int (uhd_sensor_value_handle h, int *value_out)
 Get the sensor's value as an integer. More...
UHD_API uhd_error uhd_sensor_value_to_realnum (uhd_sensor_value_handle h, double *value_out)
 Get the sensor's value as a real number. More...
UHD_API uhd_error uhd_sensor_value_name (uhd_sensor_value_handle h, char *name_out, size_t strbuffer_len)
 Get the sensor's name. More...
UHD_API uhd_error uhd_sensor_value_value (uhd_sensor_value_handle h, char *value_out, size_t strbuffer_len)
 Get the sensor's value. More...
UHD_API uhd_error uhd_sensor_value_unit (uhd_sensor_value_handle h, char *unit_out, size_t strbuffer_len)
 Get the sensor's unit. More...
UHD_API uhd_error uhd_sensor_value_data_type (uhd_sensor_value_handle h, uhd_sensor_value_data_type_t *data_type_out)
UHD_API uhd_error uhd_sensor_value_to_pp_string (uhd_sensor_value_handle h, char *pp_string_out, size_t strbuffer_len)
 Get a pretty-print representation of the given sensor. More...
UHD_API uhd_error uhd_sensor_value_last_error (uhd_sensor_value_handle h, char *error_out, size_t strbuffer_len)
 Get the last error logged by the sensor handle. More...
Typedef Documentation
◆ uhd_sensor_value_handle
typedef struct uhd_sensor_value_t* uhd_sensor_value_handle
See uhd::sensor_value_t for more details.
NOTE: Using a handle before calling a make function will result in undefined behavior.
◆ uhd_sensor_value_data_type_t
Sensor value types.
Enumerator
Function Documentation
◆ uhd_sensor_value_data_type()
UHD_API uhd_error uhd_sensor_value_data_type ( uhd_sensor_value_handle  h,
uhd_sensor_value_data_type_t data_type_out
◆ uhd_sensor_value_free()
UHD_API uhd_error uhd_sensor_value_free ( uhd_sensor_value_handle h)
Attempting to use the handle after calling this handle will result in a segmentation fault.
◆ uhd_sensor_value_last_error()
UHD_API uhd_error uhd_sensor_value_last_error ( uhd_sensor_value_handle  h,
char *  error_out,
hsensor handle
error_outstring buffer in which to place error
strbuffer_lenbuffer length
◆ uhd_sensor_value_make()
UHD_API uhd_error uhd_sensor_value_make ( uhd_sensor_value_handle h)
The purpose of this call is to populate the handle with a valid sensor value object. Querying this object will always yield 'false'. Typically, this sensor value object will never be used, but it will allow the handle object to be used with sensor functions later on.
hthe sensor handle in which to place sensor
UHD error code
◆ uhd_sensor_value_make_from_bool()
UHD_API uhd_error uhd_sensor_value_make_from_bool ( uhd_sensor_value_handle h,
const char *  name,
bool  value,
const char *  utrue,
const char *  ufalse
namesensor name
valuesensor value
utruestring representing "true"
ufalsestring representing "false"
UHD error code
◆ uhd_sensor_value_make_from_int()
UHD_API uhd_error uhd_sensor_value_make_from_int ( uhd_sensor_value_handle h,
const char *  name,
int  value,
const char *  unit,
const char *  formatter
hthe sensor value in which to place sensor
namesensor name
valuesensor value
unitsensor unit
formatterprintf-style format string for value string
UHD error code
◆ uhd_sensor_value_make_from_realnum()
UHD_API uhd_error uhd_sensor_value_make_from_realnum ( uhd_sensor_value_handle h,
const char *  name,
double  value,
const char *  unit,
namesensor name
valuesensor value
unitsensor unit
UHD error code
◆ uhd_sensor_value_make_from_string()
UHD_API uhd_error uhd_sensor_value_make_from_string ( uhd_sensor_value_handle h,
const char *  name,
const char *  value,
const char *  unit
namesensor name
valuesensor value
unitsensor unit
UHD error code
◆ uhd_sensor_value_name()
UHD_API uhd_error uhd_sensor_value_name ( uhd_sensor_value_handle  h,
char *  name_out,
NOTE: This function will overwrite any string in the given buffer before inserting the sensor name.
hsensor handle
name_outstring buffer in which to place name
◆ uhd_sensor_value_to_bool()
UHD_API uhd_error uhd_sensor_value_to_bool ( uhd_sensor_value_handle  h,
bool *  value_out
◆ uhd_sensor_value_to_int()
UHD_API uhd_error uhd_sensor_value_to_int ( uhd_sensor_value_handle  h,
int *  value_out
◆ uhd_sensor_value_to_pp_string()
UHD_API uhd_error uhd_sensor_value_to_pp_string ( uhd_sensor_value_handle  h,
char *  pp_string_out,
NOTE: This function will overwrite any string in the given buffer before inserting the string.
hsensor handle
pp_string_outstring buffer in which to place pp_string
◆ uhd_sensor_value_to_realnum()
UHD_API uhd_error uhd_sensor_value_to_realnum ( uhd_sensor_value_handle  h,
double *  value_out
◆ uhd_sensor_value_unit()
UHD_API uhd_error uhd_sensor_value_unit ( uhd_sensor_value_handle  h,
char *  unit_out,
NOTE: This function will overwrite any string in the given buffer before inserting the sensor unit.
hsensor handle
unit_outstring buffer in which to place unit
◆ uhd_sensor_value_value()
UHD_API uhd_error uhd_sensor_value_value ( uhd_sensor_value_handle  h,
char *  value_out,
NOTE: This function will overwrite any string in the given buffer before inserting the sensor value.
hsensor handle
value_outstring buffer in which to place value
